Old 12-09-2019, 11:24 AM   #1
Bardia
Drives: 2014 FRS
Revs go up and stay for seconds before dropping
Hello members
Sorry if I'm asking a question that was asked before or smth but I couldn't really find a solution to it that tailored to my issue.
I bought a '14 FR-S back in January 2019, took it in for Throttle Body cleaning and Fuel Injection cleaning service in Late November. After the service, every time I come to a stop and press the clutch in, the revs go up and stay between 2K-3K for like 2 seconds before dropping, the car also tends to hold the gas for me when I drive as it keeps revving when I let go of the throttle. Legit makes my manual feel like an unpredictable auto. Car is completely stock too!!
Anyone have any solutions to this or can suggest some solutions ? I am about to call and grill Don Valley Toyota
UPDATE:
Disconnected the battery for 30 minutes, let the car relearn and the problem went away. A special Thank you to all those involved in this thread.
Bardia is offline   Reply With Quote
Old 12-09-2019, 11:27 AM   #2
j_ros94
Drives: 2017 Subaru BRZ
Mine also does this im here to see whats going on too.
Sent from my SM-G960W using Tapatalk
j_ros94 is offline   Reply With Quote
Old 12-09-2019, 11:30 AM   #3
Bardia
Drives: 2014 FRS
Did the dealer do the same service for yours too ?
Old 12-09-2019, 11:36 AM   #4
j_ros94
No mine happened on its own but mine is boosted.
Mine happens in first gear with the clutch in. If im behind someone on a stop sign i dont put it in neutral i just stay in first gear but the rpms stay at 1.5-2k before it drops.
Old 12-09-2019, 11:43 AM   #5
Bardia
Drives: 2014 FRS
I am gonna go out on a limp and say maybe, just maybe, hypothetically my throttle body is like kinda not closing when I let off the gas, hopefully not the case.
Old 12-09-2019, 02:36 PM   #6
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
My advice is to grab a scanner and do a code clear. You may not have codes but doing a clear will reset adaptive values. If you don't have one disconnect the battery and reconnect after 30 minutes.
My thought is that your engine computer is running on old adaptive values from before throttle body cleaning and is having trouble re learning.
With less carbon build-up there would be more airflow at any given percentage of throttle opening which would make sense given your symptoms. More air, more rpm.
The shop should have done this when they did the work but maybe didn't.
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
The Following 3 Users Say Thank You to ActionMaxon For This Useful Post:
gravitylover (12-09-2019), HKz (12-09-2019), humfrz (12-09-2019)
Old 12-09-2019, 05:55 PM   #7
I reckon the linkage to the carburetor is binding. Oil up the pivot points.
Oh wait, where am I -
Oh, OK, here I am. -
I'd suggest you go with ol @ActionMaxon 's suggestion.
Old 12-09-2019, 08:44 PM   #8
Jordanwolf
Rice King
Jordanwolf's Avatar
It's definitely an overflow blinker fluid reservoir. Disconnect the exhaust, open your trunk and drain blinker fluid.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 12-09-2019, 09:18 PM   #9
steve99
Drives: FT86
Check for intake leaks ie check all intake hoses especially ones under intake manifold.
Remove intake hose, with ignition on but engine stopped have a mate press accelerator to floor then release check the throttle butrerfly moves freely full range
Disconnect battery for 30 minutes reconnect, start car let it idle with no throttle input for at least 2 minutes. Check again for fault
The Following 2 Users Say Thank You to steve99 For This Useful Post:
humfrz (12-09-2019), Ultramaroon (12-10-2019)
Old 12-09-2019, 09:35 PM   #10
This is a serious thread - behave yourself -
Jordanwolf (12-09-2019)
Old 12-10-2019, 01:07 AM   #11
Bardia
Drives: 2014 FRS
Thank you for your solution; I will try it within this week and report back on the same thread.
Old 12-10-2019, 01:09 AM   #12
Bardia
Drives: 2014 FRS
Do I need to change my muffler bearings while I am at it ? Also my 2nd transmission decoupled supreme is throwing check brakes codes 😂😂😂
It is actually funny though, feels like an auto
Old 12-10-2019, 01:27 AM   #13
Bardia
Drives: 2014 FRS
[QUOTE=steve99;3281813]Check for intake leaks ie check all intake hoses especially ones under intake manifold.
Disconnect battery for 30 minutes reconnect, start car let it idle with no throttle input for at least 2 minutes. Check again for fault[/QUOTE
Hmm thank you, Imma follow yours and actionmaxtons solution, hopefully it all comes out fine. Good part is that it is in storage for the next two months.
Old 12-10-2019, 08:50 AM   #14
Jordanwolf
Rice King
Jordanwolf's Avatar
[quote=Bardia;3281871]
Are you making it a track/race car, or just a hobby car?
Glorious Honda.
OFT - Revs not dropping to idle after WOT and letting off gas justinco Software Tuning 14 01-11-2017 09:38 PM
Where do you keep your revs? ScionFrsFan Scion FR-S / Toyota 86 GT86 General Forum 54 06-11-2015 12:07 AM
What's causing slow dropping revs? hchi rku Engine, Exhaust, Transmission 15 03-08-2014 06:39 AM
2.5L with lower revs/more torque, or 2.0L with higher revs? Superhatch Engine, Exhaust, Transmission 124 08-28-2013 12:20 PM
0-60 in 6.1 seconds? SUB-FT86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 57 01-04-2012 10:14 PM
