CANADA Canada
Old 10-05-2019, 01:30 AM   #1
JDM_Import
Drives: Boosted Toyobaru
RaceGas in Canada HP+++
You can get RaceGas in the GTA now. The gains are similar to E85 and alot safer then water/methanol injection.
You'll need a dyno tune and one can of RaceGas additive in your tank.
If you're boosted and tuned for 94 octane you will achieve aproximately 99 Octane with RaceGas additive which will increase torque/horsepower (+20 - 40)
I've been thinking of going this route... Anyone else doing this?
JDM_Import is offline   Reply With Quote
Old 10-11-2019, 07:07 PM   #2
86driftcar
86driftcar's Avatar
RaceGas? Never even heard of this in Canada
Is it similar gains to E85 or water methanol injection?
86driftcar is offline   Reply With Quote
The Following User Says Thank You to 86driftcar For This Useful Post:
JDM_Import (11-18-2019)
Old 10-11-2019, 09:16 PM   #3
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
I am always sceptical of products that make claims like this.
The marketing literature make it seem to work like a high performance octane booster. I can find no sign that it's safe for catalytic converters or general emissions equipment. I can't find any independent testing outside of their own webpage to verify octane claims although other similar products exist and DO seem to have some verified independent testing. I actually expect this product is one of these with a different label as is often the case with these things.
Lynxis is offline   Reply With Quote
The Following 3 Users Say Thank You to Lynxis For This Useful Post:
86driftcar (12-08-2019), JDM_Import (11-18-2019), Tcoat (10-16-2019)
Old 12-08-2019, 12:08 PM   #4
JDM_Import
I haven't done a RaceGas tune yet but I have a buddy who did and gained +35hp and +20lb-ft
The Following User Says Thank You to JDM_Import For This Useful Post:
Old 12-08-2019, 01:02 PM   #5
86driftcar
86driftcar's Avatar
That's impressive considering all you need is a dyno tune + RaceGas. I would think Water/Methanol is alot more expensive and unsafe.
Old 12-08-2019, 04:50 PM   #6
new2subaru
Weight Weenie
Drives: 15 FR-S
With what additional parts, if any?
I find it hard to believe 8oz of anything will do that. Straight Benzene/Toluene/Alcohol/Plutonium can't do that. What is in that magical 8oz of liquid?
The Following User Says Thank You to new2subaru For This Useful Post:
Tcoat (12-09-2019)
Old 12-09-2019, 01:39 AM   #7
Turbo
Drives: FR-S Turbo
That's the octane booster I run, Glenn.
Not cheap - but it allows me to run 91 octane fuel on track with my 94 octane tune when 94 isn't available at a pump nearby. Sasha from Onpoint Dyno runs it - so that's a pretty big vote of confidence in the product working right there.
It contains some naughty chemicals though (notably MMT), so it's not street legal.
As I recall, I need basically an entire can to top a full tank of 91 up to 94.
Royal Purple makes a similar additive that's quite a bit cheaper and is also MMT based. Haven't seen any actual dyno tests - but the butt dyno results felt identical to me.
Turbo is offline   Reply With Quote
The Following User Says Thank You to Turbo For This Useful Post:
JDM_Import (12-29-2019)
Old 12-09-2019, 05:48 AM   #8
new2subaru
Weight Weenie
Drives: 15 FR-S
Thanks for the clarification, Brian. That's a hefty price to pay to go from 91-94. Is there no Petro 94 around anywhere?
I had the ratios wrong. I misread their ad here;
https://performanceimprovements.com/products/rg100032
MMT was removed from fuels a long time ago for many reasons, as I'm sure you know. Posted for others.
https://www.canada.ca/en/health-cana...-gasoline.html
Ethanol would be a better option I think. Logistics is the main issue and cost, of course.
Old 12-19-2019, 03:03 AM   #9
Turbo
Drives: FR-S Turbo
Currently, there is no 94 octane fuel in the area around Grand Bend, but that should be changing. I've been talking with one of the local gas stations, and they are looking at bringing in a higher octane fuel for the summer. Most likely something in the 94-98 octane range, as the track only carries 100 Octane+ options right now. As I understand they are currently deciding whether it will be drum based or stored in a new tank underground.
I believe the street price is about $40 a can, so "Race Gas" brand is not cheap. But it works. The 91->94 price jump probably equates to about $10 a tank at the station for comparison. The plus here is you could run a ZERO ethanol fuel (which some people like) and still get 94 octane.
Can't do that with Ultra 94 since it's actually more than 10% ethanol.
As for using ethanol as an additive - the problem here is that while it does raise octane it has a much lower energy content per unit volume than gasoline. It is also highly hygroscopic. MMT brings a SHIT PILE of energy to the table, in addition to the octane bump. Our cars are also very sensitive to ethanol - it's the reason our fuel pumps chirp like crickets.
MMT was removed solely due to tree huggers. Anything else you read is more or less a sales pitch.
The Following 2 Users Say Thank You to Turbo For This Useful Post:
JDM_Import (12-29-2019), JohnH (08-09-2020)
Old 12-19-2019, 06:18 AM   #10
Lantanafrs2
Drives: 2013 frs red
You can get RaceGas + tune in the GTA now. The gains are similar to E85 and alot safer then water/methanol injection.
This will achieve aprox. 99 Octane which will increase horsepower (+20-40 HP)
20 to 40? That's a pretty wide spread there. Probably more like 15
Lantanafrs2 is offline   Reply With Quote
Old 12-21-2019, 04:36 PM   #11
Lynxis
Lynxis's Avatar
You can see those sorts of gains if you're boosted but otherwise, it's more like 10-15.
The Following User Says Thank You to Lynxis For This Useful Post:
JDM_Import (12-27-2019)
Old 12-27-2019, 07:32 AM   #12
JDM_Import
Who said anything about 8oz of RaceGas? You need boost and 32oz of RaceGas to make that kinda power.
Old 12-27-2019, 07:36 AM   #13
JDM_Import
Dyno numbers dont lie, especially when you have before and after dyno runs for comparison... you'd be surprised what a boosted BRZ gains with RaceGas
Old 12-27-2019, 08:02 AM   #14
JDM_Import
I should have been more specific here. For anyone interested Yes I saw the dyno results before and after. I will try to acquire that and post it here. This was done on a 2018 twin with a 210 Sprintex supercharger.
To be precise, 32oz of RaceGas additive gained 20lb-ft and 37whp. Timing was pulled back as soon knock was introduced so its conservatively tuned.
Need a favor from a Canadian BRZ owner, (Canadian Base model with Manual Trans)) boomslang CANADA 1 09-07-2014 11:24 PM
Road Race Engineering(RRE) FRS Custom Tune StancedLifestyle Software Tuning 0 03-25-2014 01:41 PM
Road Race Engineering Tune Wes Software Tuning 6 03-23-2014 02:25 PM
Visconti Tuning: EcuTek STG1 Pumpgas + E85 + RaceGas Calibrations Visconti Engine, Exhaust, Bolt-Ons 177 12-24-2013 01:29 AM
because racegas Silverdub Forced Induction 14 06-07-2013 07:50 PM
