#43 | |
Drives: 2015 Subaru BRZ Aozora Edition
Subaru clutch filed to Nissan input shaft? That would simplify clutch + flywheel combo Sent from my iPhone using Tapatalk |
#44 |
Love your style. I have plenty of fancy schmancy tools but my half-round diamond jewelers file is always within reach.
#45 | |
Thanks so much for the advice. One final question, what did you machine on the flywheel? Planning on going boost over the course of this winter and will use my first faulty trans bell housing in this project Sent from my iPhone using Tapatalk |
#46 |
#47 |
I’m currently just trying to source someone’s broken transmission as the final piece to action this project.
What did you do for clutch line? Sent from my iPhone using Tapatalk |
#48 |
Because compromise ®
Drives: Red Herring
I'm intrigued by the tax implications of this statement.
#49 | |
Awesome info. Do you think using the factory release bearing(replaced with new/aftermarket) would be doable as well? Tilton Hydraulic release looks decent too Sent from my iPhone using Tapatalk |
#50 |
#51 | |
Did you take any pictures looking toward the inside of the bell housing by chance? Excited for this project. Should “bulletproof” a boosted track brz. |
#52 | |
Okay sweet. So the BRZ bellhousing and CD009 lines up good for the most part? Some areas straight weld and some areas you utilized spare aluminum to bridge from CD009 to bellhousing? Sent from my iPhone using Tapatalk |
#53 | |
Awesome appreciate the help I could see the bearing retainer was far too big for the BRZ bellhousing but that solution seems straight forward. You cut the CD009 at the second mould “ring” correct? Curious to what you did for reverse lockout. This is a sweet project you took on Sent from my iPhone using Tapatalk |
#54 |
Let the fun begin
![]() Sent from my iPhone using Tapatalk |
#55 |
My CD009 ended up coming with a driveshaft as well happy days. Found someone local that will adapt it cheaply for the BRZ.
Stock BRZ throw out bearing looks like it’ll work perfectly. Debating ordering a custom clutch or filing down a stage 3 clutch I buy. Unsure if its worth the risk LOL. Couldn’t be more pumped to get this show on the road thanks for all the help SolidSnake ![]() ![]() Sent from my iPhone using Tapatalk |
#56 | |
I’m getting the 350 driveshaft retubed by a local company to the correct length, $300 but well worth it IMO. I’m looking into reinforcing the fork after feeling the difference between the BRZ & 350 forks. BRZs feels like a twig in comparison. Sent from my iPhone using Tapatalk |
| Help! Best option to fix this? | timmydatooth | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 04-04-2017 02:33 PM |
| brz lip kit option | Davesta619 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 06-12-2016 11:46 PM |
| Which is the best FI option? | gt8613 | Forced Induction | 20 | 01-03-2014 01:21 PM |
| New F/I option | SnapOv3st3r | Forced Induction | 41 | 03-24-2013 09:44 PM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 07:54 PM |
