Old 12-06-2019, 03:45 AM   #1
pher.da.rico
Drives: 2018 Premium Black silica BRZ
STUCK ON OFT STAGE 2 !!
I don’t know if this specific topic has been covered but I really need help. So I’ve been running my stage 2 e85 tune for a while now no problems but recently I broke my V2 0FT i’m trying to source a screen and try to repair it but if worse come to worse. Would I be ok switching to ECUTEK and writing over that tune it with the help of a pro tuner or do I HAVE to tune it with my OFT before switching over. I’m not worried about warranty I just wanna be able to optimize my tune with peace of mind. Thank you for your time !!
pher.da.rico is offline   Reply With Quote
Old 12-06-2019, 04:05 AM   #2
kev0
Drives: '14
https://www.digikey.com/product-deta...E6NuDYE9hVpMz4
^ that is the screen you will need to replace your OFT V2 screen. It's a very simple process.
Nope, you can't flash an EcuTek tune over your OFT tune. EcuTek will give you a ECU mismatch error code. It happened to me when I forgot to unmarry my OFT.
Worst comes to worst, you can go to dealership and have them flash your car back to stock tune, but that will render your OFT useless. I do not recommend doing this. Only do it if it is your only option. Make sure you have 91 or 93 in the tank before going to dealership.
kev0 is offline   Reply With Quote
The Following User Says Thank You to kev0 For This Useful Post:
Tcoat (12-06-2019)
Old 12-06-2019, 04:08 AM   #3
pher.da.rico
Thanks man imma order that screen an update you from there !! Thank you !
Old 12-06-2019, 02:32 PM   #4
mrjj
Drives: GT86 2013
You can read or re-flash with a Tactrix OpenPort. It's probably cheaper than the Ecutek option.
mrjj is offline   Reply With Quote
Old 12-06-2019, 06:14 PM   #5
steve99
Drives: FT86
As above cheapest way out of your problem will bw buy tactrix $170 usa and flash with that
Old 12-06-2019, 10:28 PM   #6
pher.da.rico
Where would I go from there if need be ? Would I stick with the tactrix or then switch to ecutek? Excuse my ignorance
Old 12-07-2019, 12:35 AM   #7
steve99
Drives: FT86
Neither oft or tactrix lock ecu like ecutek or BRZEdit.
So is no problem to flash with tactrix then reflash with oft or the other way round
Old 12-07-2019, 05:46 AM   #8
pher.da.rico
Do you guys know of anyone that tunes on the OFT platform?
Old 12-07-2019, 06:15 AM   #9
kev0
Drives: '14
@steve99 and http://site.wayneroms.com:8000/ are two that I know.
Old 12-07-2019, 06:18 AM   #10
pher.da.rico
@steve99 if I could get some insight and a custom tune I’d appreciate it ! I’m from SoCal
What about you guys @kev0
Old 12-07-2019, 07:06 AM   #11
steve99
Drives: FT86
Just message me i can custom tune on oft , tactrix or ecutek for you
Full Blown's New Build for the 2015 Season Stage 3 (2.19L motor) + Stage 3 Turbo kit FullBlown Forced Induction 47 06-20-2018 02:38 AM
FRS single stage vs dual stage driver's airbag mhiscott Issues | Warranty | Recalls / TSB 2 09-23-2017 03:43 PM
Exedy Stage 1 Failure: Advice + Stage 2 Questions Pneub Engine, Exhaust, Transmission 4 07-18-2016 09:24 PM
FBM Stage 1 Cams w/ Stage 2 Head Results 743HP! FullBlown Forced Induction 119 03-24-2015 10:16 PM
Questions about upgrading the avo stage 1 turbo kit to stage 1.5 and 2 Astroboy Forced Induction 4 03-01-2014 07:29 PM
