Old 12-03-2019, 08:24 AM   #1
j_ros94
Drives: 2017 Subaru BRZ
Idle rpm drop
I heard its normal if ac is on and the idle rpm drop but mine drops if i just turn the fan on for the heat. Is this normal too?
Sent from my SM-G960W using Tapatalk
j_ros94 is offline   Reply With Quote
Old 12-03-2019, 08:33 AM   #2
tomm.brz
Drives: brz 2017 hksv2
Stock tune is often pretty unstable during idle
Old 12-03-2019, 08:35 AM   #3
j_ros94
Im boosted and tuned so i was wondering if that could cause my idle rpm to drop with the fan on
Old 12-03-2019, 08:55 AM   #4
tomm.brz
Does it do like that just lately?
Best would be an idle log
Old 12-03-2019, 08:57 AM   #5
j_ros94
No its been doing that since i installed it but they said its normal just needed confirmation since its winter and i need the heat. Lol dont want my car stalling on a red light cuz of it
Old 12-03-2019, 09:16 AM   #6
kev0
Drives: '14
manual or auto? Just blip the throttle if you feel like you're about to stall. It sounds like the problem is your tune or you have a vacuum leak. We need a log to make sure.
kev0 is offline   Reply With Quote
Old 12-03-2019, 09:26 AM   #7
j_ros94
Manual. I wish it was my tune but sasha from on point says he doesnt see anything but ill record a log
Old 12-03-2019, 11:36 AM   #8
tobin
tobin's Avatar
Drives: '13 BRZ
My stock 2013 does it as well.
tobin is offline   Reply With Quote
Old 12-03-2019, 12:27 PM   #9
When you turn the fan on with defrost settings on the AC kicks in to dry the air even though it is on a warm setting. This gives you the normal small displacement engine drop in RPM. Perfectly normal. Try turning it onto just the floor settings and a bet you get no drop.
Old 12-03-2019, 12:34 PM   #10
j_ros94
Interesting ill try that next time
Old 12-03-2019, 01:49 PM   #11
Gunman
Drives: 2019 Mazda Miata RF
My 2013 auto would dip every time I came to a stop, with ,or without ac on. In sport mode it was worse, since it would hold the downshift longer. If I came to a quick stop in sport, I could stall it.
Old 12-03-2019, 01:58 PM   #12
radroach
Drives: car
@Gunman I read people saying this all the time. I have a feeling there is a fault that isn't tripping a CEL.
Also for reference, when I had an ABS CEL / limp mode, my idle would dip and nearly stall anytime I would brake to a stop.
Old 12-03-2019, 08:52 PM   #13
Decep
Drives: 2013 FR-S Series 10
custom tuned edelbrock, almost always a rock solid 900 rpm idle (obviously the tuner raised it). whats your "normal" idle?
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 12-03-2019, 09:05 PM   #14
Xinnie
Xinnie's Avatar
Drives: 2015 FR-S, 1997 328iS
floats around 900 give or take 50
custom tuned jrsc
Xinnie is offline   Reply With Quote
Idle Drop When I Tap Gas Pedal Skeneypoo Issues | Warranty | Recalls / TSB 14 11-09-2017 02:40 PM
Rpm drop at idle 19eightysix Issues | Warranty | Recalls / TSB 11 03-06-2015 10:03 PM
brake pump at idle rmp drop? subaruferrucci Issues | Warranty | Recalls / TSB 8 12-07-2012 04:45 PM
Reported idle-drop and crickets - got turned away empower-auto Issues | Warranty | Recalls / TSB 11 10-21-2012 12:36 PM
Start-Up Idle Drop (VIDEO) MidnightMonkey Issues | Warranty | Recalls / TSB 18 10-02-2012 02:54 AM
