Old 12-02-2019, 07:52 AM   #15
hpanju
hpanju's Avatar
Drives: 2016 Subaru BRZ
Originally Posted by j_ros94 View Post
Is it normal during cold weather that my car won't shift into gears?
Sent from my SM-G960W using Tapatalk
Being from north of Toronto I just had this exact same problem LOL. Always found that going into second then first helped.
hpanju is offline   Reply With Quote
The Following User Says Thank You to hpanju For This Useful Post:
j_ros94 (12-02-2019)
Old 12-02-2019, 08:16 AM   #16
j_ros94
Drives: 2017 Subaru BRZ
Lol I'll try this out since i am from toronto
j_ros94 is offline   Reply With Quote
Old 12-02-2019, 08:43 AM   #17
Has anybody said it is normal?
Old 12-02-2019, 08:48 AM   #18
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Yes. Post#3
Old 12-02-2019, 01:21 PM   #19
dholloway543
Software Hobbiest
Drives: 2015 FRS
Millers 75w-90NT is best
From my experience good cold shifting low sheer resistance. i.e. putting in gear
Motul gear300 is second best
good cold shifting. med sheer resistance. a little harder to get into gear but still good
I wouldnt use any other fluid in the trans if you want cold shifting.
dholloway543 is offline   Reply With Quote
Old 12-02-2019, 02:27 PM   #20
Would being boosted having 330 whp affect that?
Well, HELL yes, you can't have EVERYTHING!
Old 12-02-2019, 02:31 PM   #21
StraightOuttaCanadaEh
Wes
I sort of had this problem and I just kept switching out trans fluid. First I tried Motul, then Redline, then Motul again. Gradually it went away and I never ever find it difficult to put it into gear anymore, no matter the weather
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Old 12-02-2019, 09:47 PM   #22
soundman98
ProCrastinationConsultant
soundman98's Avatar
Yes. Post#3
or post #2...
Old 12-03-2019, 09:17 PM   #23
Sapphireho
Famous Potatoes
Sapphireho's Avatar
or post #2...
Lol. Sorry. Your rev match talk threw me off. I have a problem rev matching with a cold motor.
Old 12-03-2019, 10:55 PM   #24
soundman98
soundman98's Avatar
it's technically rev-matching, but i'm not revving above 1500rpm at the most.
i noticed a while back that if i held the stick against the syncro while everything was cold and it didn't want to go into 1st, it would go as soon as the revs matched. so i just barely blip the throttle to get the motor falling in revs the same time the car is coming to a stop to widen the 'sweet spot', and not push so hard on cold syncro's.
Tcoat (12-04-2019)
Old 12-04-2019, 08:20 AM   #25
BlueLine
Drives: 2013 Rally Blue w/Bronze wheels MT
If you upgraded the clutch and pressure plate you may have a bad fork
Vyse | How fast can you afford to go | Etc...
BlueLine is offline   Reply With Quote
Old 12-04-2019, 07:07 PM   #26
First off, it's an "engine" - not a "motor".
Second off, YOU are the one that drug your car to the cold climate -
Old 12-04-2019, 08:23 PM   #27
soundman98
soundman98's Avatar
at what point does an engine become a motor? between the electronic fuel injection, spark timing, cam adjusters, and alternators, our engine wouldn't run without creating it's own electricity!
therefore, our cars must have a engin-otor!
solidsnake11 (12-04-2019)
Old 12-04-2019, 11:33 PM   #28
Now, now, the Internet tells me that:
"Motor and engine are interchangeable in standard English. In some engineering jargons, the two words have different meanings, in which engine is a device that burns or otherwise consumes fuel, changing its chemical composition, and a motor is a device driven by electricity, air, or hydraulic pressure, which does not change the chemical composition of its energy source".
Therefore:
All motors are engines but not all engines are motors.
Got it?
Now, I got to get on with paying my bills. Yes, I pay them by check, not auto deduction. Why? It's a throwback to the times when I couldn't pay them all at the same time. Started by paying the ones that said "final notice".
BlueLine (12-06-2019), soundman98 (12-04-2019)
Even Gears rns294 Engine, Exhaust, Transmission 1 04-12-2017 09:52 AM
Any one have 5.29 gears yet ? ogie Oglethorpe Engine, Exhaust, Transmission 13 09-17-2016 11:17 AM
Anybody change rear gears or trans gears yet? ramosryan Scion FR-S / Toyota 86 GT86 General Forum 2 06-13-2014 12:48 AM
2nd gears a b*tch Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 32 01-29-2013 05:09 PM
