Old 11-29-2019, 08:45 AM   #1
j_ros94
Drives: 2017 Subaru BRZ
Not going into gears
Is it normal during cold weather that my car won't shift into gears?
Sent from my SM-G960W using Tapatalk
j_ros94 is offline   Reply With Quote
Old 11-29-2019, 10:16 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
yep. i usually have to rev-match 1st while rolling to a stop at stop signs to get it to go in, or sit at a complete stop for 5 seconds to make it go in. 2nd will begrudgingly go in after that, 3rd/4th, i usually have no problems with
j_ros94 (11-29-2019)
Old 11-29-2019, 10:29 AM   #3
jflogerzi
jflogerzi's Avatar
Completely normal. Once warmed up it gets better.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Old 11-29-2019, 10:41 AM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Motul gear300 trans fluid fixed this for me. Even at -25f it shifts well initially. My ebrake on the other hand..
Old 11-29-2019, 10:42 AM   #5
j_ros94
Great thanks. I thought my clutch might have gone bad or something
Old 11-29-2019, 11:40 AM   #6
j_ros94
Would being boosted having 330 whp affect that?
Old 11-29-2019, 11:51 AM   #7
soundman98
soundman98's Avatar
braggarts weigh more.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Captain Snooze (12-05-2019), Ultramaroon (11-29-2019)
Old 11-29-2019, 11:53 AM   #8
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
No
Old 11-29-2019, 12:29 PM   #9
jflogerzi
jflogerzi's Avatar
No
Unless the TOB is shot...
Old 11-29-2019, 12:32 PM   #10
j_ros94
I dont think so but I gotta check now
Old 11-29-2019, 12:33 PM   #11
j_ros94
I did replace the clutch to a stage 3
Old 11-29-2019, 12:38 PM   #12
jflogerzi
jflogerzi's Avatar
Then you should be fine
Old 11-29-2019, 12:57 PM   #13
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Still having 330 hp would not matter. A shot TOB would be the same at any hp level. And a shot TOB would be the same regardless of weather.
Not what OP was asking.
Old 11-29-2019, 01:06 PM   #14
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
if you have trouble try n->2->1 i do that when i first start up getting out of where if live. once you get a little heat in it youll be fine
Breadman is offline   Reply With Quote
The Following User Says Thank You to Breadman For This Useful Post:
Larphraulen (12-05-2019)
Even Gears rns294 Engine, Exhaust, Transmission 1 04-12-2017 09:52 AM
Any one have 5.29 gears yet ? ogie Oglethorpe Engine, Exhaust, Transmission 13 09-17-2016 11:17 AM
Anybody change rear gears or trans gears yet? ramosryan Scion FR-S / Toyota 86 GT86 General Forum 2 06-13-2014 12:48 AM
2nd gears a b*tch Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 32 01-29-2013 05:09 PM
