Old 07-20-2012, 10:46 AM   #1051
thejevans
Rugger Extraordinaire
thejevans's Avatar
Drives: 1997 Miata, R.I.P. 2013 Red FR-S
Originally Posted by Spaceywilly View Post
Good to know I'm not missing anything over there... stopped reading that junk a few years ago
Don't get me wrong, they've gotten better. It's just that when they screw up (I don't see it often, but maybe I'm blind), it's very annoying how they go about the situation. I can't leave anyways, i hang out on #oppositelock too much.
thejevans is offline   Reply With Quote
Old 07-20-2012, 10:53 AM   #1052
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by Don@Accelerated View Post
Will most likely move the compression to 10-10.5. Seems to be a good area we use in alot of other cars. You'll have alot of low end grunt and still be able to maintain alot of cylinder pressure.
-Don
Few questions, how do you plan on moving the compression? Will the motor be able to handle 8psi? I know we're all just shooting in the dark here but you might know a bit more than we do at this point. I'm trying to make hard decisions right now because I'd like to run 8psi, it would be an absolute dream. I'm just fearing for the motors life. Do internals need to be upgraded for 8psi? Or can we just grab a manifold/head gasket and a new clutch and call it a day.
I either need to unsubscribe from this thread RIGHT NOW or start preparing my list of supporting mods. And I personally don't want to dip into upgrading internals.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 07-20-2012, 10:57 AM   #1053
Opposed
Drives: 2013 Asphalt FR-S
Originally Posted by Synack View Post
Few questions, how do you plan on moving the compression? Will the motor be able to handle 8psi? I know we're all just shooting in the dark here but you might know a bit more than we do at this point. I'm trying to make hard decisions right now because I'd like to run 8psi, it would be an absolute dream. I'm just fearing for the motors life. Do internals need to be upgraded for 8psi? Or can we just grab a manifold gasket and a new clutch and call it a day.
Usually by changing to lower compression pistons. Thicker headgaskets can be used as well, but are not known for their reliability...
Opposed is offline   Reply With Quote
Old 07-20-2012, 10:58 AM   #1054
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Drives: BRZ Premium 6MT (SWP)
Now I need to take out a home equity loan to buy my turbo, suspension, rims, and tires.
First I need to buy a house, though.
Edit: will this kit fit the BRZ? Different nose, HID ballasts, etc.
Symbiont is offline   Reply With Quote
Old 07-20-2012, 11:01 AM   #1055
Synack
Boosted
Synack's Avatar
Drives: Sideways
Yeah I was going to go with the thicker head gasket regardless, I'm pretty sure. Anything that helps is good. I'm trying to avoid pistons.
Old 07-20-2012, 11:02 AM   #1056
Don@Accelerated
Don@Accelerated's Avatar
I don't believe we'll be upgrading internals at 8psi. The boost doesn't mean much against cyl pressure. I'm more concerned about making to much power and to much cylinder pressure.
Remember this is STG 1, Basic kit, or whatever you want to call it.
I'm sure at some point here not in the far future i'll have very advanced HP setups.
I do have Pistons and Rods currently in the works. Manley approached me yesterday to do their R&D testing for them, so we will be considering that as well. Theres no doubt I'll have bulletproof engine setups here. I am first and foremost an engine builder before all the other things we do!
Don@Accelerated is offline   Reply With Quote
Old 07-20-2012, 11:05 AM   #1057
Synack
Boosted
Synack's Avatar
Drives: Sideways
So you're saying you believe it should handle 8psi with no problem?
Old 07-20-2012, 11:10 AM   #1058
Don@Accelerated
My car is BRZ
Old 07-20-2012, 11:15 AM   #1059
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
My car is BRZ
BRZ guys are used to being left out since everyone's using the FR-S/GT86 for development. :P
The Following User Says Thank You to Draco-REX For This Useful Post:
Exhaust (07-20-2012)
Old 07-20-2012, 11:23 AM   #1060
Don@Accelerated
Little Article grabbed from Jalopnik. I've never heard of them, but I guess there are a little off on the truth, but O well. Its an editorial, since when does the news report Truth!
http://jalopnik.com/subaru-brz/
Old 07-20-2012, 11:54 AM   #1061
Draco-REX
Corner Junkie
Draco-REX's Avatar
I think the sweet spot will be 235-240whp. That should equate to around 280 at the crank, putting the car at a nice round 10:1 lb/hp ratio.
Old 07-20-2012, 11:59 AM   #1062
mastertech86
mastertech86's Avatar
Drives: 2009 scion tc turbo
this article is the prime example why you gotta do research before you consider instead of believe the first article you find. these guys clearly didnt read anything related to this build and disgusts me reading what they wrote in that article....SMH
mastertech86 is offline   Reply With Quote
Old 07-20-2012, 12:07 PM   #1063
#87
I usually post drunk
#87's Avatar
They just posting buzz words trying to get hits to make the $$$, like most sites these days
#87 is offline   Reply With Quote
Old 07-20-2012, 12:08 PM   #1064
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
im sure you nwill end up with a 400whp car within a year, especially if you ve been approched by Manley..
Silverdub is offline   Reply With Quote
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 11:24 AM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-03-2012 11:24 PM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 07:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 08:14 PM
