Old 11-19-2019, 05:59 PM   #1
withease
crappyFRS
Drives: 2013 Scion FRS 10 Series
Door Panel Speaker Cover Removal?
Hey guys I'm new to forums so sorry if this has been answered already. I've done as much research as I can and I know it's as simple as removing my door panel to figure this out but I know one of you has the answer.
I've been carbon fiber skinning a lot of my parts with real twill weave carbon (looks beautiful). I've done my cluster cover, door grips, ac pillars, and a few other parts. I'd like to do the speaker covers.
Mine are stock, I know you can buy actual covers (red-stitched leather/Alcantara) that go over the stock door speakers, but can I actually take off the stock plastic so I can skin it?
I've been checking it out pulling on it and it seems that it is removable but might be bolted/clipped on from the inside of the door panel.
Or, is it actually attached to the door panel as one piece? Meaning I would have to cut it out then glue it back on to accomplish this.
Thanks for the help!
PS my instagram is @crappyFRS if DMing me might be easier I can send a video or something to explain exactly what I mean.
withease is offline   Reply With Quote
Old 11-19-2019, 06:23 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
EDIT: Sorry I was thinking about the knee pad covers.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 11-19-2019, 06:36 PM   #3
ojuniour
ojuniour's Avatar
Drives: Subaru BRZ 2017
If you are talking about these..it seems like it is snapped in. I'm not sure if you would have to fully remove the door though
Sent from my ONEPLUS A6013 using Tapatalk
ojuniour is offline   Reply With Quote
Old 11-19-2019, 06:51 PM   #4
withease
crappyFRS
Those leather ones look like they definitely pull off. @8RZ okay I'm gonna trust you I'll try yanking them off in the morning. Just doesn't seem like the normal plastic ones pull of I was pulling on it before wasn't really budging...
Old 11-19-2019, 08:05 PM   #5
new2subaru
Weight Weenie
Drives: 15 FR-S
https://www.ft86club.com/forums/showthread.php?t=27471
I'm fairly certain they're screwed on from the inside.
Old 11-19-2019, 08:27 PM   #6
jbsali
jbsali's Avatar
Drives: 2014 Subaru BRZ (Limited)
they are 100% screwed on from the inside. you will have to remove the door card.
jbsali is offline   Reply With Quote
Old 11-19-2019, 08:46 PM   #7
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
^^^This. Just remove the panel. It takes two seconds.
Old 11-20-2019, 12:08 PM   #8
withease
crappyFRS
Thanks for the help fellas! I'll post some pics on my profile when complete should look pretty cool
door panels, interior, speaker cover
OEM Speaker Panel Knee Pad ryuusei Interior Parts (Incl. Lighting) 8 10-16-2019 02:59 PM
Door Panel Vinyl Removal Jordan Silveira Cosmetic Modification (Interior/Exterior/Lighting) 0 12-06-2017 04:02 PM
86 Door Panel Knee Pads/Speaker Grilles Chillz Interior Parts (Incl. Lighting) 7 02-14-2016 08:25 PM
VIDEO GUIDE - Build your own door speaker mounts using the factory speaker shells. The Sentinel DIY (Do-It-Yourself) Guides 3 01-28-2016 05:39 PM
Inner dorr panel removal regal Cosmetic Modification (Interior/Exterior/Lighting) 2 08-22-2014 11:17 PM
