Old 11-17-2019, 10:28 PM   #3277
Decep
Drives: 2013 FR-S Series 10
Originally Posted by Colin86 View Post
I don't have an El header, but I'm on stock clutch and spun a dynojet to the tune of 330whp and 240wtq with e85. Roughly 25k miles on the car, 5k of that supercharged.
Clutch slips a slight bit occasionally in 6th when I go to pass on the highway, does absolutely fine through a whole day at the roadcourse even while shifting into 5th for the longer straights. Don't think it'll last forever, but so far so good.
You know what, i get a slight stumble in 6th gear when passing sometimes. I didn't realize it could be the clutch slipping.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 11-18-2019, 10:44 PM   #3278
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
E85, stock blower pulley, delicious tune with the mk1+ fuel pressure sensor upgrade. Was at cruise 2 hours into a trip and sudden knock then blown engine. No previous signs of issues.
B T is offline   Reply With Quote
Old 11-19-2019, 08:33 PM   #3279
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Complete with rod no 3 creating a nice viewing hole in the block between the ac compressor and throttle body?
Old 11-21-2019, 12:46 PM   #3280
B T
Kiske, close, but I think it was cylinder #2, LH side front from driver seat.
Old 11-21-2019, 10:34 PM   #3281
Decep
^ That blows...how many miles total were you supercharged?
Anyone get their $500 rebate yet? I sent mine in end of September and nothing yet :/
edit: sorry for the unintended supercharger pun
RCE SS-1 Coilovers
Corsa Catback
Old 11-22-2019, 01:29 PM   #3282
BA9092
Captain Slow
BA9092's Avatar
Drives: '18 BRZ Limited PP 6MT ISM
I'm still waiting for mine too. Mailed it out in September as well.
BA9092 is offline   Reply With Quote
Old 11-22-2019, 01:47 PM   #3283
toast
Drives: 14 BSP Edelbrock BRZ
Email them. They are pretty terrible about it. When I got mine supposedly they went out in a big batch and were all mailed wrong. Not sure how that happens, but as soon as I emailed them I got it quickly.
toast is offline   Reply With Quote
Old 11-22-2019, 02:15 PM   #3284
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
You should make a build thread on here. How are you liking the SC?
tehShirt is offline   Reply With Quote
Old 11-22-2019, 03:09 PM   #3285
BA9092
Captain Slow
BA9092's Avatar
I haven't installed it yet. It's still sitting in my garage.
I've just been crazy busy. I purchased it sooner than anticipated to take advantage of their rebate.
The Following User Says Thank You to BA9092 For This Useful Post:
tehShirt (11-23-2019)
Old 11-22-2019, 04:39 PM   #3286
Decep
Maybe i will do that. Mail in rebates being what they are, im sure they are counting on people forgetting they ever sent them in.
RCE SS-1 Coilovers
Corsa Catback
Old 11-23-2019, 08:24 AM   #3287
tehShirt
tehShirt's Avatar
That temptation would be too much for me. Hopefully you get time soon to do the install!
The Following User Says Thank You to tehShirt For This Useful Post:
BA9092 (11-23-2019)
Old 11-24-2019, 10:15 PM   #3288
Decep
Scratch that last post, just got my rebate in the mail on Friday. $$$
RCE SS-1 Coilovers
Corsa Catback
The Following User Says Thank You to Decep For This Useful Post:
CSG Mike (11-25-2019)
Old 11-25-2019, 10:08 PM   #3289
toast
PSA for stock headers
Wanted to wait and see if this was the problem and now can confirm it is.
If you are running the stock headers with this kit check the state of your precat. I've been working with Zach at CSG on my tune. Everything was dialed in except for a very rich condition and stumble when leaving a stop in first gear. Only showed up under low flow conditions below 1400 rpm. Tried swapping the AFR sensor, made it a little better but didn't get rid of it. Zach eventually got me a map that worked but he had to do a custom map that takes the car out of closed loop in that area. I switched to a Tomei header over the weekend and all the issues are gone.
The image below is a boroscope pic of the precat. The cat material is failing and clogged in about the middle 20% and it changed the flow enough that the reported AFR was reading very rich and making the car stumble when the closed loop system overcompensated, sending the AFR to 16 or so. These precats aren't designed for the higher heat from this kit.
The Following 5 Users Say Thank You to toast For This Useful Post:
BertoFT (11-26-2019), BirdTRD (11-27-2019), HachiRokuX (11-26-2019), Mr_Eyo (11-27-2019), StraightOuttaCanadaEh (11-26-2019)
Old 11-26-2019, 06:28 PM   #3290
BA9092
Captain Slow
BA9092's Avatar
Got mine today!
I emailed them about it Monday morning and got the check this afternoon.
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
