Old 11-19-2019, 03:46 PM   #1
StraightOuttaCanadaEh
Wes
Perrin Engine Mount concerns (UPDATED)
Got the latest updated Perrin engine mounts and the engine sounds like it wants to jump out of the engine bay. There are a lot of thuds and vibrations at idle, very ugly sounding. Took it back to the mechanic to find out if one of them is loose and nope, he says he triple checked everything.
I did notice when the engine is warmed up the effect is less pronounced and right now it's routinely below freezing here in Toronto. It just so happened that my first drive with the mounts was when the car was warmed up and I remember thinking wow, this is not bad at all.
So for those who have had this mount or any mounts installed, is it normal to have this much racket going on at idle? Do certain mods make it worse? I have the Perrin/Whiteline trans support and bushing combo, and Whiteline diff outrigger and subframe bushings.
Is there a bit of a break in period? Do cold weather/rougher idle when engine is cold make this effect less pronounced?
Is there any weight to the hearsay that Fluidamrp pulley mitigates the NVH?
Thanks!
UPDATE: okay after a long drive, I can confidently say the crazy knocking sound is caused by the rough cold idle. Once the engine is hot, there are no crazy noises, even at idle. The only problem so far is a nasty gurgling rasp that is noticeable on acceleration, especially from 3K rpm onwards, but that may be due to the trans support, as it seems to come from directly below the trans tunnel. I put my back seats up and that helped the noise and I have to say, noises aside, the effect is very nice.
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
DarkPira7e (11-19-2019)
Old 11-19-2019, 03:49 PM   #2
Joveen
Joveen's Avatar
Drives: Bone stock
Subd. I wanted to buy these mounts and still plan on doing so. I think mounts do take a lil bit to break in.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 11-19-2019, 04:13 PM   #3
norcalpb
norcalpb's Avatar
I mean you’re daily driving with Perrin mounts in freezing weather.
They probably harden up in the cold and will shake the hell out of the engine.
Old 11-19-2019, 04:18 PM   #4
JD001
JD001's Avatar
Drives: Subaru BRZ
I have the STI Group N mounts (engine and transmission), temperature has touched 3c so far, no issues. I'm loving them.
Old 11-19-2019, 04:21 PM   #5
Joveen
Joveen's Avatar
Drives: Bone stock
Any links to those? I cant find them anywhere
Old 11-19-2019, 04:43 PM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I didn't realize your location. Being so cold, I think it makes more sense, especially since your chassis will also creak and vibrate more until it's warmed up. I know when I drive my car and it's -15F out, nothing sounds good.
Old 11-19-2019, 04:44 PM   #7
Joveen
Joveen's Avatar
Drives: Bone stock
I those were regular sti mounts.
Old 11-19-2019, 04:47 PM   #8
JD001
JD001's Avatar
Drives: Subaru BRZ
Sorry wrong link..
https://sprintingharejdm.co.uk/ST410...20ST41022AS010
https://sprintingharejdm.co.uk/ST41020AS000
Old 11-19-2019, 04:48 PM   #9
gpvecchi
gpvecchi's Avatar
Yes, absolutely perfect. Just a clicking noise from the gearbox support on open/close throttle.
Old 11-19-2019, 04:50 PM   #10
JD001
JD001's Avatar
Drives: Subaru BRZ
I don't even get any clicking sounds..
Old 11-19-2019, 04:51 PM   #11
DarkPira7e
DarkPira7e's Avatar
@Joveen They're on almost every site that sells parts for our cars, they're just called STI mounts. I don't think there's any difference between " Group N" and "regular" STI mounts for our platform as far as I have seen.
https://www.ft86speedfactory.com/sti...l#.XdRjcldKh1M
https://www.ft86speedfactory.com/sti...l#.XdRjXFdKh1M
Joveen (11-19-2019)
Old 11-19-2019, 04:57 PM   #12
Joveen
Joveen's Avatar
Drives: Bone stock
I just confused when it said Sti vs Group N mounts. That's why thought these engine mounts were just sti and not group n.
The Following User Says Thank You to Joveen For This Useful Post:
Old 11-19-2019, 05:01 PM   #13
i8ur911
Drives: 17 BRZ Series.Yellow
STI and Group N are different durometers. They are different, but I think even the STI mounts are considered an "upgrade" over the standard mounts in the 86 chassis.
i8ur911 is offline   Reply With Quote
Old 11-19-2019, 05:03 PM   #14
DarkPira7e
DarkPira7e's Avatar
Where are you finding a different durometer rating for the STI Group N mounts on our platform? I know on other Subaru chassis this is true, but for ours there seems to be no difference. I'm not being argumentative, I'm just hoping you're right.
Plumbus (09-07-2020)
Reliability concerns after major warranty engine repair? guanqi89 Engine, Exhaust, Transmission 10 07-10-2018 09:40 PM
Wtb frs/brz sti engine mount bartuc Want-To-Buy Requests 0 01-05-2018 06:17 PM
FS: Mtec Shift Springs / Perrin Support Mount / Perrin Shifter Mount andy86 Transmission and Driveline 6 05-25-2017 01:26 AM
Perrin Trans Mount and Perrin Shifter Bushing 00vsmcoupe Transmission and Driveline 1 03-09-2016 10:02 AM
sti engine mounts, oem engine/tranny mount, oem radiator sickmint79 Engine, Exhaust, Bolt-Ons 0 08-08-2015 03:15 PM
