Old 11-19-2019, 01:31 PM   #253
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Heavy, padded, leather faced, woven gloves? To change pads? If so then... well... OK.
Well, I actually have never changed just pads, now that I think about it. Usually includes rotors, or I need the brake off to get at something else like wheel studs. Yes on thick gloves for rusty rotors.
Old 11-19-2019, 01:54 PM   #254
Originally Posted by venturaII View Post
Apparently the whole concept of the right tool for the job doesn't apply to gloves. As long as you have some on that make you look like a pro all is good no matter how much they interfere with the task.
Old 11-19-2019, 02:00 PM   #255
The point was that the gloves he used are not suitable for the task of CHANGING PADS not that people should not use gloves. I thought I had clarified that point but I guess not.
Screw it, I am going to go fill my washer fluid up
Old 11-19-2019, 02:19 PM   #256
JD001
JD001's Avatar
Drives: Subaru BRZ
Will you be wearing gloves when filling washer bottle?
Old 11-19-2019, 02:23 PM   #257
As pictured.
Old 11-19-2019, 02:23 PM   #258
JD001
JD001's Avatar
Drives: Subaru BRZ
Just got me thinking about the headlights washer.. does it work at the same time as the windscreen washer? I ask as I have never seen washer residue on the front bumper of the car.. but the headlights are always clean...
Old 11-19-2019, 02:25 PM   #259
JD001
JD001's Avatar
Drives: Subaru BRZ
As pictured.
And I thought it was a library photo. Impressive protection!! I presume that the safety data sheet for the washer fluid specifies such protection.
Old 11-19-2019, 02:29 PM   #260
No it says you don't need it but if I am going to wear gloves I am gonna look good doing it!
Old 11-19-2019, 02:33 PM   #261
JD001
JD001's Avatar
Drives: Subaru BRZ
Yep, I think you will look great.. I like the yellow sections... Very coming.. shame the yellow bits weren't orange.. just don't go splashing washer fluid on your trousers.. gloves and wet patches on trousers not a good look..
Old 11-19-2019, 02:36 PM   #262
Old 11-19-2019, 02:39 PM   #263
JD001
JD001's Avatar
Drives: Subaru BRZ
Don't forget your face..
Old 11-19-2019, 02:42 PM   #264
Old 11-19-2019, 02:45 PM   #265
JD001
JD001's Avatar
Drives: Subaru BRZ
Okaaaay... I'm sensing that you may have a mild but strange fetish to dress up when tinkering with your Lava..
Old 11-19-2019, 06:00 PM   #266
new2subaru
Weight Weenie
Drives: 15 FR-S
I hate brake fluid
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff IBill4You Want-To-Buy Requests 2 06-13-2015 03:02 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
