Old 11-17-2019, 04:22 PM   #1
localhost
Drives: Edelbrock SC 2015 FR-S 6MT
FIXED: Installed Edelbrock SC. Now car is throwing CELs
So I installed an Edelbrock SC last week and everything was going great until I started getting these CELs: P0171, P117B, and P1170. I've checked all the wiring for the injectors and they seem connected tightly and are clocked correctly as well.
I'm running the CARB tune from Edelbrock but I do have a catless Gruppe-S header (while waiting for my local tuner to give me an appointment for a custom tune). I'm not sure if that is making the system throw these codes. There's a chance its related by the looks of this thread (post #4): http://www.ft86club.com/forums/showthread.php?p=1618213
The only other thing I can think of is a bad battery (according to post #14 on this thread: http://www.ft86club.com/forums/showthread.php?p=2128963). I've had to jump my car several times over the last month, and have had it go completely dead about 3 to 4 times as well due to my fault but I've also fully charged it with nothing connected at least 2 times over the last week. These codes keep coming back though. I'm getting a new battery in a few hours to see if that fixes anything though.
Interesting to note though: car still drives completely fine. I haven't smelled any gas or anything sitting in the car. CELs also don't happen while driving (after clearing it), and all 3 times it has happened I had just gotten into the car and turned it on and was idling waiting for things to warm up.
Any idea on what this might be would be super appreciated
EDIT: Went to buy a battery and monitored LTFT and STFT. LTFT was basically 40% any time I went near the throttle. STFT was mostly 0 but ranged between -5 to +11. I'm now leaning towards this tune really not liking the catless header. At idle, LTFT is 18.8 and STFT is 0.
Edit: Datalog: https://datazap.me/u/rb28dett/nov-17-cruise
FIXED: https://www.ft86club.com/forums/show...5&postcount=79
localhost is offline   Reply With Quote
Old 11-17-2019, 04:30 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Did you make sure every bolt is tight for the DI bracket? I would double check them
Old 11-17-2019, 04:43 PM   #3
localhost
Sorry I'm not sure which bracket you're referring to. If you mean the entire fuel rail assembly with the injectors to the manifold, then yes. I torqued them down to 10 ft-lbs like the instruction manual said.
Old 11-17-2019, 04:49 PM   #4
How is this a warranty or recall/tsb related issue?
ROFL it's Waffle (11-27-2019)
Old 11-17-2019, 04:50 PM   #5
DarkPira7e
DarkPira7e's Avatar
If you're standing in front of the car, it's the black steel bracket that the direct injection ecu bolts to on the left side. I'm sure you were thorough, it's just something to double check as it's not an uncommon issue after having removed the intake plenum to install a supercharger
Old 11-17-2019, 04:51 PM   #6
localhost
Ah crap. I clicked on the wrong forum. Totally my bad
The Following User Says Thank You to localhost For This Useful Post:
Ultramaroon (11-17-2019)
Old 11-17-2019, 04:53 PM   #7
localhost
Ah gotcha. I will double check this because one of the coolant hoses from the SC assembly does sit on top of that bracket and at one point before installing did cause one of those 4 connectors to come loose.
Old 11-17-2019, 05:22 PM   #8
localhost
I double checked the bracket and it was tight. No movement at all. The connectors on the back were all also completely seated and locked in place.
Connectors: https://i.imgur.com/VRWgCsM.jpg
Bracket: https://i.imgur.com/FmrgCLO.jpg
Old 11-17-2019, 05:31 PM   #9
Issues | Warranty | Recalls / TSB
Well it is an "issue".
localhost (11-17-2019)
Old 11-17-2019, 07:20 PM   #10
kev0
Drives: '14
I'm battling the exact same codes as you for the past 3 months. Tightened DI bracket and everything. I have the Sprintex SC though. Codes come back about 2-3 days of driving after clearing it.
kev0 is offline   Reply With Quote
Old 11-17-2019, 07:53 PM   #11
Exhaust leak or a hose blown off of the intake manifold.
BirdTRD (11-26-2019)
Old 11-17-2019, 08:02 PM   #12
localhost
Could you also see similar symptoms with an aftermarket header with a tune designed for a stock one, or is it purely because of a loose intake/exhaust leak?
Old 11-17-2019, 08:07 PM   #13
I don't know but a good test would be to reinstall the stock header. You have the ecutek tools, right?
Old 11-17-2019, 08:15 PM   #14
localhost
Yeah, definitely going back to the stock header is a good test - just a real pain haha. And yes, I do have the Ecutek cable and software.
I've emailed my local tuner to see if they can fit me in since I'm fairly certain it just needs to be custom tuned to compensate for the header but I'm not sure if they even do any tuning in the winter.
CELs and not cranking 86 driver Issues | Warranty | Recalls / TSB 8 09-28-2017 01:08 PM
Odd CELS. Karl07 Issues | Warranty | Recalls / TSB 4 10-08-2016 07:53 PM
Unichip stock map to avoid CELs pwells Software Tuning 3 12-28-2013 02:57 AM
Engine Mods and CELs Captain Snooze Engine, Exhaust, Transmission 2 04-08-2013 10:13 PM
Cam Gear Related CELs - How many miles? uspspro Issues | Warranty | Recalls / TSB 16 10-22-2012 02:57 PM
