Old 11-16-2019, 11:21 PM   #211
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Meh. I am used to it.
Well.. way to fucking give up old man.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 3 Users Say Thank You to Dave-ROR For This Useful Post:
Spuds (11-17-2019), Tcoat (11-16-2019), Ultramaroon (11-16-2019)
Old 11-16-2019, 11:32 PM   #212
Besides if I moved south I would have to deal with people from Florida.
Spuds (11-17-2019), WolfpackS2k (11-20-2019)
Old 11-16-2019, 11:37 PM   #213
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
You have to anyways. On here at least.
And you could always pick a state a couple higher.. avoid the Floridians on a daily basis but not deal with fake cocaine.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Tcoat (11-16-2019)
Old 11-16-2019, 11:43 PM   #214
Not sure moving a bit further north would improve things over Florida.
Old 11-16-2019, 11:53 PM   #215
You know that paradise is in the PNWUS. You've seen my engine bay.
Old 11-16-2019, 11:54 PM   #216
But that would be moving way north of where I live now.
This is getting confusing.
soundman98 (11-16-2019)
Old 11-16-2019, 11:56 PM   #217
Haha... right?
Old 11-17-2019, 04:21 AM   #218
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by GrantedTaken View Post
Interesting you were able to see that. All the ricer n00bs on this forum said it is normal to NOT be able to see the pads without removing the wheels.
That's when I posted the photo and heads exploded here, since everyone is basically in high school on their first car.
Now that I have new pads, I will take a look and see how much pad is exposed with 100% pad, and if any of it is visible from the outside, without removing the wheels.
Using your analogy, your comprehension of how brakes work must be at preschool level.
weederr33 (11-17-2019)
Old 11-17-2019, 09:32 AM   #219
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
I replaced my front pads this weekend. At 50k, my pads has tons of meat left. Probably 30% left. Caliper slide pin grease was also perfect. I left the OEM rotors alone, they're probably good for 100k+.
I'm not even going to bother checking the rear pads.
After I replaced the pads, I looked into those slots. You could not see any pad material, just the rotors.
There is literally no way to see the pads from those peep holes. Whoever designed that should be fired.
The only way to check pads is to remove the open caliper.
I've steered clear of this dumpster fire a while, but seeing as I was bored waiting for a load in the washer to finish while sipping coffee, I wad giving this thread a once over.
No you can't see the pads, yes on most cars you can, this isn't special or worth whining about. This is basically the same caliper Subaru had been using on almost all of their cars for the last... 10+ years at least. There is just more metal on the caliper bracket than on a Corolla for example, it hides the pad, how terrible that the brake hardware would be beefier.
But back to my reason for finally posting:
A pad slap on a rusty 50k rotor? That's amateur crap. If you're not going to replace the rotors, at least have them resurfaced. You strutted in here like a big man throwing the ricer insult around but you can't even do a basic brake job right. Laughable.
Last edited by RZNT4R; 11-17-2019 at 10:07 AM. Reason: correcting autocomplete crap and brain farts
The Following 3 Users Say Thank You to RZNT4R For This Useful Post:
humfrz (11-17-2019), weederr33 (11-17-2019), Will BRZ (11-18-2019)
Old 11-17-2019, 09:56 AM   #220
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
No you can't see the pads, yes on most cars you can, this isn't special or worth whining about. This is basically the same caliper Subaru had been using on almost all of their cars for the last... 10+ years at least. There it's just more metal on the caliper bracket than on a Corolla for example, it hides the pad, how terrible that the brake hardware would be beefier.
A pad slap on a rusty 50k rotor? That's amateur crap. If you're not going to replace the rotors, at least have them resurfaced. You strutted in here like a big man throwing the ricer insult around but you can't even make a basic brake job right. Laughable.
MS, CSCS, TSAC-F, CPT
Old 11-18-2019, 12:05 AM   #221
highway7
Drives: FRS 2013
Learn to put the jack stands on properly next time
highway7 is offline   Reply With Quote
Old 11-18-2019, 11:16 AM   #222
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
But...he told us he has more tools than us, to go along with all that experience working on far superior, high-end German cars. And a brand new set of those useless 'mechanic's' gloves that they sell at AutoZone for everyone who wants to pretend they're on a pit crew...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following User Says Thank You to venturaII For This Useful Post:
Tcoat (11-18-2019)
Old 11-18-2019, 11:52 AM   #223
Was going to comment on the gloves and then figured maybe I was the only one that didn't use them these days so better keep my mouth shut.
venturaII (11-18-2019)
Old 11-18-2019, 12:01 PM   #224
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I use nitrile latex gloves for anything car related. I have 5 boxes laying around from work. Same for detailing projects.
Those thicker gloves are handy if you are turning wrenches in the cold. They lack dexterity which I'm not a big fan of.
I remember being 17 buying a pair of those and then immediately ruining them because oil and fabric don't mix. Lesson learned..
The Following User Says Thank You to RToyo86 For This Useful Post:
soundman98 (11-19-2019)
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff IBill4You Want-To-Buy Requests 2 06-13-2015 03:02 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
