Old 11-01-2019, 02:06 PM   #71
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
You guys should be giving Blub to some professional youtubers like Matt Farrah or Speed Academy. You probably wont need the advertising, but to showcase what these coilovers do on an 86.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Westen86 For This Useful Post:
RToyo86 (11-15-2019), wparsons (11-01-2019)
Old 11-01-2019, 03:02 PM   #72
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by WC-BRZ View Post
How does one make an informed/educated decision on which coilovers to pick in this price range? There's the ASTs, MCS and JRZs within this range and for someone fairly inexperienced it can be a bit overwhelming.
If you can't get a ride along or test drive or get a rec from someone experienced who you know and trust you are straight up relying on anonymous internet opinion, basic specs on the product, and past reputation. No solution is perfect for every user, odds are you'll be gambling based on reputation, budget, and some assumptions on what you think will work best. 949s got a great rep, lots of people will buy based on past experiences with their products, but nobody hits 100% customer satisfaction.
ineedyourdiddly
Old 11-11-2019, 12:38 AM   #73
AngelGT86Racer
AngelGT86Racer's Avatar
Drives: 2013 FR-S, 2007 Acura TL 5AT
Originally Posted by Icecreamtruk View Post
Not trying to be a prick but although body roll is not always bad, or at least as bad as people make it out to be, it has very little to do with weight transfer. You could have a car with no suspension (a kart) and during cornering, you would still have the majority of your weight on the outside tires. Also, while body roll isnt always bad, its never good. In an ideal world, you would have a car with a suspension soft enough that you can go over bumps and kerbs but stiff enough so that the car has no roll at all whatsoever. Usually impossible, unless the car's CoG and roll center are both at ground height, which is also physically impossible. So at the end of the day, its all a compromise and depends a lot on the car's setup, the tracks you drive at, and the driver preference and skill as well.
You are correct. Weight transfer, as a mathematical representation, does not even take spring rate into account. Even some of the stiffest race cars I've seen still have notable body lean, even though the suspension is not compressing. This becomes a function of your center of gravity, roll center heights, and track width. The whole car leans as a unit with the suspension. That's unavoidable unless your center of gravity is below your roll center(which is basically impossible).
2013 FR-S Raven, AutoX/Track/Daily Driver
Build: Angel's Dual Duty FR-S Build
YouTube: Angel Christov
AngelGT86Racer is offline   Reply With Quote
The Following 2 Users Say Thank You to AngelGT86Racer For This Useful Post:
Icecreamtruk (11-11-2019), wparsons (11-13-2019)
Old 11-15-2019, 07:24 PM   #74
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Options
Custom spring rates, Hyperco
700/600 Hoosier 255/40/17 ~ 285/30/18
500/500 Race - Track or autocross focused, 40~100tw race or 200tw UHP
350/300 Sport - For high grip street tires, 200tw. Casual autocross or HPDE
175/150 Touring - Street comfort, not for 200tw or race tires
Looking at the spring packages from the 175/150 Touring rates vs the 500/500, I'm assuming that the damping was designed initially with the 500 lbin springs in mind (mainly track tire and performance focused). Then you tested to see what spring rates would produce the most comfortable ride to come up with the "touring rates" for the same damper sweep (at the lowest damping pressure setting)?
Seeing that the dampers are single adjust, assuming a rebound adjustment, how much of the compression damping is increased with the single adjust adjustments? How does it effect ride comfort? How different is the comfort-ability going form the 150 to the 300lbin springs?
Do you guys have anything set up with the sport spring rates at the shop to demo? I'd like to come check them out.
Intent > Content
Old 11-15-2019, 07:47 PM   #75
949 Racing
FT86Club Official Vendor
949 Racing's Avatar
Drives: Miata, GT350, FR-S
-We started by dynoing some OEM shocks and the Sachs.
-Then we drove the OEM and Sachs, determining what area of the damping needed to change to improve ride on the soft end and grip/control on the stiff end. -
-We then give precise damping force targets to Tractive for the prototypes.
-We then being on street and track testing with a variety of spring rates, tires, alignment settings.
Pure bred race shocks for pro motorsports have a narrow "sweep". Meaning the range from full soft to full stiff is narrow, steps between clicks are very small. Pro team take a shock engineer to the track and revalve as needed. With all Xidas, we expand that sweep and make the steps between each click much broader. The damping plots on Xidas are non linear for compression and rebound. Both sides are digressive. Rebound side steps are pretty linear. Compression side doesn't change much at all until the last 5-8 clicks towards full stiff where low (piston) speed force ramps up. We seem to be the only high end shock supplier doing this type of valving. That's how we can get good street ride quality and responsiveness but still have perefct race level damping. The tradeoff is the steps between clicks are larger on Xidas than they would be on say a Pirelli World Challenge car. The reality is nobody reading this has high end data acquisition on their 86 or is capable of discerning the tiny steps between clicks on a pure race shock valving profile.
Touring or Race is what we will offer. Blub has race rates on it now. Call or email to schedule a ride at the shop or see us at the track where we always
offer rides.
949 Racing is offline   Reply With Quote
The Following 2 Users Say Thank You to 949 Racing For This Useful Post:
solidONE (11-16-2019), tvrbob86 (12-26-2019)
Old 11-16-2019, 02:18 AM   #76
solidONE
solidONE's Avatar
offer rides.
Nice solution for this very common issue for us enthusiast who rank suspension a priority but still want something versatile enough to be comfortable to commute on and still kick ass in the canyons and on track. Less of a compromise, except for the having to change out the springs part.
Will definitely come visit you guys. Thanks!
Intent > Content
Old 11-16-2019, 05:34 AM   #77
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
...highest offset camber chips...
View from rear:
Zero
-5 deg
The Following 4 Users Say Thank You to Captain Snooze For This Useful Post:
ruturaj001 (03-18-2025), turbofan (01-07-2020), Var (01-07-2020), wparsons (03-10-2020)
Old 11-26-2019, 03:02 PM   #78
turbofan
949Racing Support
turbofan's Avatar
Drives: 1999 Mazda Miata Turbo
Had a great weekend of testing at Chuckwalla Valley Raceway. Goals were NA record and 86 Cup Mod class record, and Sonny & Blub achieved those goals. Lap times and video are found in Blub's thread here: https://www.ft86club.com/forums/show...&postcount=300
With that mission accomplished we put some of the top 86Cup and 86 Drive Challenge (Norcal) drivers in Blub so they could experience Xidas and the setup in general from the driver seat.
Mike Kang from CSG
Kevin Schweigert - 86Cup Mod class points leader with his Supercharged 86 on Tein SRC
Joe McGuigan - 86DC/86Cup Mod class driver, instructor, master of sportsmanlike conduct (thanks again Joe)
Tor Anderson - 86Cup Stock class driver
All drivers got a full session each in Blub. All drivers were separated by roughly a second, a testament to the drivability and forgiveness of the setup.
All commented at how stable Blub felt, particularly over kerbs and bumps. Tor's first words were "This is a HOOT!"
Ed @ 949Racing
949Racing
Supermiata
EMAIL US at info@949racing.com
turbofan is offline   Reply With Quote
The Following 3 Users Say Thank You to turbofan For This Useful Post:
Code Monkey (11-26-2019), solidONE (12-03-2019), wparsons (01-07-2020)
Old 01-07-2020, 01:39 PM   #79
blown
Drives: ft86
Any update on the active ones?
blown is offline   Reply With Quote
Old 01-07-2020, 01:43 PM   #80
949 Racing
949 Racing's Avatar
We tend to update only when we have actionable information. No ETA for 86 ACE at this time. Standard single adjustable still in final steps of R&D.
The Following User Says Thank You to 949 Racing For This Useful Post:
Old 01-16-2020, 10:21 AM   #81
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Any update on release date?
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 01-16-2020, 12:12 PM   #82
949 Racing
949 Racing's Avatar
Same as our previous post, no ETA. We are eager to get these on the shelf and start selling them but until we have something firm, it's better not to guess.
Currently fine-tuning details with the camber adjusting chips and end link bracket.
Old 03-10-2020, 12:19 AM   #83
blown
Drives: ft86
Anything new?
Old 03-10-2020, 12:21 AM   #84
turbofan
949Racing Support
turbofan's Avatar
I promise we will post when we have more information regarding availability.
Pinky swear.
Ed @ 949Racing
949Racing
Supermiata
The Following User Says Thank You to turbofan For This Useful Post:
949 racing, blub, xida
BC Racing Coilovers, Tax Season Specials! WE stock BC Racing @OAKOS! OAKOS Automotive Brakes, Suspension, Chassis 162 04-17-2017 04:14 PM
*** Feal Suspension, Megan Racing, BC Racing, KSport, ISIS Coilovers - ON SALE!!! *** Sonic Motor Brakes, Suspension, Chassis 489 07-29-2016 03:15 PM
WTB: Ksport Control Pro Coilovers or BC Racing Extreme Low Coilovers ProjectBrz Brakes, Suspension, Chassis 1 04-15-2014 01:21 AM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 09:56 PM
