Old 11-14-2019, 08:27 PM   #62959
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
To lower compression you would have to increase the combustion chamber volume at TDC. Since piston and rod heights are fixed the only way to increase chamber volume is to alter the stroke.
NoHaveMSG is offline
p1l0t (11-15-2019)
Old 11-14-2019, 09:47 PM   #62960
Also to add... stroke changes, so not only compression ratio change, but displacement changes (bore x stroke)? So is it more (or less) than 2 liter?
Yes.
Ultramaroon is offline
Old 11-14-2019, 09:53 PM   #62961
I suggest mentally picturing the system on end and consider how the cylinder bore and crankshaft axis of rotation are both fixed.
Old 11-14-2019, 10:05 PM   #62962
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
[ame]https://www.youtube.com/watch?v=Qffp-38_ycE[/ame]
MS, CSCS, TSAC-F, CPT
weederr33 is offline
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
Dadhawk (11-15-2019), NoHaveMSG (11-14-2019)
Old 11-14-2019, 10:37 PM   #62963
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I'm lucky if they even put the plates on the rack and wipe down their equipment when done at my gym. The evening crowd is lazy.
spike021 (11-14-2019)
Old 11-14-2019, 11:15 PM   #62964
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
I'm lucky if they even put the plates on the rack and wipe down their equipment when done at my gym. The everyone is lazy.
fixed it
Clutch Dog is offline
The Following 5 Users Say Thank You to Clutch Dog For This Useful Post:
soundman98 (11-16-2019), spike021 (11-14-2019), Spuds (11-15-2019), Ultramaroon (11-15-2019), weederr33 (11-14-2019)
Old 11-14-2019, 11:35 PM   #62965
Lantanafrs2
Drives: 2013 frs red
What is the point of variable compression ratio?
Lantanafrs2 is offline
Old 11-14-2019, 11:39 PM   #62966
Lower CR under boost. Higher when cruising with cracked throttle. CR profile is tailored to further maximize ignition advance across a wider range of operating conditions. (gamut?)
Now I'm going to go study to see if I'm in the ballpark.
NoHaveMSG (11-15-2019), soundman98 (11-16-2019), Spuds (11-15-2019)
Old 11-15-2019, 12:02 AM   #62967
Ok, yeah, I'm a smartypants.
Old 11-15-2019, 12:49 AM   #62968
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Higher pressure results in less losses to entropy during combustion. In theory you want the highest compression you can get at all times. But the limiting factor is the tendency of gasoline/air to detonate when you compress it too quickly. By decreasing the maximum pressure, you decrease the rate of compression. Thus allowing higher rpm, advancing timing, and more fuel/air (higher boost) at higher temperatures.
Being able to tune the compression ratio gives you the best of both worlds in the same engine.
Spuds is offline
Lantanafrs2 (11-15-2019), Ultramaroon (11-15-2019)
Old 11-15-2019, 01:21 AM   #62969
- you peaked!
humfrz is offline
Old 11-15-2019, 01:55 AM   #62970
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Marketing.
https://www.caranddriver.com/feature...-fuel-economy/
EAGLE5 is offline
The Following User Says Thank You to EAGLE5 For This Useful Post:
Old 11-15-2019, 02:25 AM   #62971
- you peaked!
I did about 20 years ago.
Old 11-15-2019, 02:48 AM   #62972
Well, seeeeeeeeeeee
humfrz is offline
