Old 11-13-2019, 10:14 PM   #1
nochilljay
Drives: 2015 Subaru BRZ Limited
Smoke from driver side bank
Just did a figure it out yourself heater core bypass because I think there's a leak on the cabin side of the firewall. Also tried searching so please don't crucify me.
This problem started before the heater core bypass.
I've been losing coolant for a month or so now, temps have crept up twice, I'm trying to keep adding water until I can afford to fix this problem and change the coolant.
Like I said, smoke coming from driver side of engine bay, source seems to be from under the engine. Weird smell, smells like something in between coolant, oil, burning wires and even a little bit of a clutch smell, though I think I might have burnt the clutch a little the first time I noticed it, haven't gotten too much of that since. When the AC kicks on it seems to go away but I'm not sure if that's just airflow from the pulley pushing it somewhere else or not.
15 BRZ limited with 63k-ish. Going to try to daily my bike until I can fix it. Thanks in advance (hopefully).
Sent from my SM-G960U using Tapatalk
nochilljay is offline   Reply With Quote
Old 11-14-2019, 01:23 PM   #2
subaru
Drives: STI
Sounds like your head gasket has failed at the very least. Either way you have a serious problem and driving the car further is likely to grenade the motor and leave least parts salvageable as possible. High temperatures and coolant loss is bad bad. Park the car if you can.
subaru is offline   Reply With Quote
Wtb brz driver side headlight and driver side fender ikeryder13 Want-To-Buy Requests 1 10-06-2016 06:18 PM
LED SIDE MARKERS Clear and Smoke styles F-T Exterior Parts - Lighting 48 05-28-2015 01:22 PM
driver side Windows cant contrl by driver side button athlon816 Issues | Warranty | Recalls / TSB 12 12-13-2014 10:06 AM
Pic Request: WRB with smoke side markers. m.wood0213 Cosmetic Modification (Interior/Exterior/Lighting) 2 09-20-2013 07:10 PM
**GB Clear/Smoke LED Side Marker ** nigel-jdmparts Groupbuys 484 07-07-2013 08:32 PM
