Old 11-04-2019, 10:49 AM   #29
It was so much easier before the expansion tanks showed up. Your overflow just pissed out on the road and every couple of months you took the rad cap off (when engine was cold) and checked the level. If it was low you threw some water in and that was that.
But, but ……??
* why only take the cap off when it's cold?
* how much water should I add?
* shouldn't I be adding some alcohol too?
* what do you mean to cover the core?
* what does the core look like?
* how much to add over the core?
* what if I put too much in?
Wait one - I can't find the hood release to even get started!
Busybee (11-04-2019), Tcoat (11-04-2019)
Old 11-04-2019, 10:55 AM   #30
Valid points there Hum!
Can you imagine the chaos:
Busybee (11-04-2019), humfrz (11-04-2019), soundman98 (11-04-2019), Ultramaroon (11-04-2019)
Old 11-04-2019, 08:18 PM   #31
Ya, folks, I need some help - my 56 chevy just blew up!
Last night, I had just put some aftermarket tail lights in (DIY) and left the wires bare because I wasn't sure which way was wired right. As I took a test drive, I noticed I was low on gas. I left my lights on while I gassed up - and my car just blew up - and I don't know why - HELP -
Tcoat (11-04-2019)
Old 11-04-2019, 08:21 PM   #32
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Most probably it’s the gas! Brand? Price? Outside temp? Can you give details? )))
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
The Following User Says Thank You to Busybee For This Useful Post:
Tcoat (11-04-2019)
Old 11-04-2019, 08:43 PM   #33
It was a hot (94 degrees F), humid (103%) night in Missouri, down at Westbrook's ESSO. The gas was regular leaded, that's all they had and the price was 27.9 cents per gallon.
Any help? -
Old 11-12-2019, 11:53 PM   #34
highway7
Drives: FRS 2013
Known problem with this car. I top off the coolant every year or so with dealership OEM coolant. No overheating problems.
To everyone suggesting that it's due to the water "evaporating". Has anyone actually use a coolant strength tester? Yes the reservoir isn't air tight but neither has any other car I've owned, and none of my previous cars have ever lost significant amounts of coolant, even in decades.
highway7 is offline   Reply With Quote
The Following User Says Thank You to highway7 For This Useful Post:
Busybee (11-13-2019)
Old 11-12-2019, 11:57 PM   #35
soundman98
ProCrastinationConsultant
soundman98's Avatar
i've got a theory, bear with me for a minute.
are you stick or auto?
if you're stick, do you somewhat follow the 'eco' light, and attempt to keep revs under 2k when possible?
do you ever do rolling 2nd gear starts?
Old 11-13-2019, 01:48 AM   #36
86MLR
86MLR's Avatar
What's a "eco light"
I believe someone earlier mentioned alcohol.....
Meh
On topic: can I use blinker fluid instead of coolant, if so, do I just use the standard clear blinker fluid.
I have heard on the interwebs that the green coloured blinker fluid supplies the most gains though, 7 hpatw, there's dyno plots somewhere, although, I'm skeptical about this, science would dictate that red blinker fluid would supply the most gains, not green.
Thoughts????
The Following User Says Thank You to 86MLR For This Useful Post:
sato (10-27-2021)
Old 11-13-2019, 02:10 AM   #37
Meh
Thoughts????
- you got that ALL wrong - it's the BLUE blinker fluid that is to be used -
The forum goes down for a day or two and you guys just lose all your knowledge -
86MLR (11-13-2019), sato (10-27-2021)
Old 11-13-2019, 04:12 AM   #38
86MLR
86MLR's Avatar
Thanks for the tip
Actually working during the day, and not trolling this forum, is not healthy for my psyche
I almost sold the 86 and purchased another Skyline because SAU australia never goes down for more than the time it takes to make a coffee.
Heaven forbid I actually have a productive day at work.
Thank Jebus I have some good drones that work hard to make me look good.
humfrz (11-13-2019)
Old 11-13-2019, 10:52 AM   #39
You left the same coolant in for "decades"?
The amount of loss is so miniscule it would not show on a tester.
humfrz (11-13-2019)
Old 11-13-2019, 02:19 PM   #40
That would depend on what kind of tester you are using -
The last time I tried to use my old tester, the rubber bulb disintegrated in my hand when I squeezed it -
bcj (11-13-2019)
Old 11-13-2019, 05:21 PM   #41
highway7
Drives: FRS 2013
Decade"s" is an exaggeration, but I have family cars whom the coolant has never been touched in 13 years and the level is perfectly fine. While with this car, I find myself topping up the coolant every 9 months or so.
Old 11-13-2019, 05:29 PM   #42
For heavens sake, don't change the coolant now! It's like back in the day, when detergent oil first came out, peoples cars using non-detergent oil didn't leak until they put detergent oil in it -
soundman98 (11-13-2019)
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 08:21 PM
Real-time Oil temperature Analysis - Pre/Post Coolant Loop Oil Cooler Install The Sentinel Engine, Exhaust, Transmission 92 03-09-2015 05:20 PM
first time running Slick tires... Pedal dance or normal 5sec trac off? dejxx Tracking / Autocross / HPDE / Drifting 6 11-16-2014 04:07 PM
Normal Engine Coolant Temps? Dezoris Engine, Exhaust, Transmission 1 04-05-2013 03:17 PM
