Old 10-26-2019, 08:03 PM   #1
Rabrooks
Rabrooks's Avatar
Drives: 2020 Subaru BRZ
Broken cam head and sprocket. What caused it
Tearing down my engine and found this. Also found a spun rod bearing. 2013 frs 123k miles
What would cause it
Rabrooks is offline   Reply With Quote
Old 10-26-2019, 09:00 PM   #2
Lantanafrs2
Drives: 2013 frs red
Was valve spring recall done?
Lantanafrs2 is offline   Reply With Quote
Old 10-27-2019, 12:58 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
It could be a few things besides the common causes.
Some times it's due to poor metals, weak spots in the forging, machining, installation or just a bad luck.
Old 10-27-2019, 01:07 AM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
sumptin' got stuck. dat der stuckn' borked da cam geer.
Old 10-27-2019, 09:25 PM   #5
What would cause it
Did the spun rod bearing lock up the engine?
Old 11-07-2019, 08:54 PM   #6
Rabrooks
Rabrooks's Avatar
No, Turns out the bearing was bad but didnt hurt the rod or the crank throw.
The knock was coming from the broken intake cam sprocket.
The Following User Says Thank You to Rabrooks For This Useful Post:
humfrz (11-07-2019)
Intake Cam Sprocket failure hanabie Issues | Warranty | Recalls / TSB 5 02-25-2019 07:46 PM
First Drive - CEL - Cam Sprocket Fix TeamSweet86 Issues | Warranty | Recalls / TSB 113 09-30-2018 09:49 AM
For Sale: FA20 Engine w/ Broken Head leets4uc3 Arizona 7 08-29-2018 03:23 PM
Timing chain sprocket tooth broke Jamesallen45 Issues | Warranty | Recalls / TSB 9 08-28-2018 04:24 AM
FA20 Cam Sprocket Question pleong Engine, Exhaust, Transmission 4 01-24-2015 08:48 AM
