Old 04-26-2019, 07:34 PM   #15
Bolobao
Drives: 2022 GR86, 2013 BRZ (sold)
Originally Posted by BPM View Post
No loose connections, steering angle sensor is working, the tech was able to do a zero point calibration. Nothing looks bent. Would this code come on due to improper bleeding when the used abs module was installed? The subaru techs told me the modules do need to be reprogrammed if a new unit goes in but unsure about a used unit (whether it can be reprogrammed).
This code wouldn’t come on due to improper bleeding.
Sorry, I misspoke earlier about the continuity check between the steering angle sensor and ESP unit. I forgot the SAS is connected to the Electronic Power Steering ECU, which then broadcasts this info over CAN-BUS. So SAS and ESP aren’t connected directly. However, I still think it’s worth investigating if the SAS is faulty - I’d try reinstalling the original ESP and try replacing the SAS if possible.
@steve99 is right - the ESP ECUs on these cars aren’t paired to a specific vehicle or VIN. It should be plug and play assuming the replacement is also from a similar vehicle variant (same transmission, etc). Since this fault is present with both, I’d do your troubleshooting with the original unit.
Good luck, let us know if you figure it out.
Bolobao is offline   Reply With Quote
Old 07-09-2019, 03:41 PM   #16
kev0
Drives: '14
@BPM did you ever figure this out? I got the C1288 code right after I flashed my car with a Moto East tune.
kev0 is offline   Reply With Quote
Old 10-29-2019, 09:24 AM   #17
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
did you get this ever sorted out?
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Old 11-04-2019, 10:58 AM   #18
Soloside
Originally Posted by solidsnake11 View Post
Did you have an wheel alignment done? Is your steering wheel straight driving straight?
car's straight.
was just a tune thing, nothing mechanical. all fixed now
2014 Subaru BRZ
Old 11-04-2019, 04:36 PM   #19
steve99
Drives: FT86
Originally Posted by Soloside View Post
car's straight.
Were you on ecutek ? Ive had similar stuff happen with racerom 10,
and 11, hopefulpy new ver 11.1 raceeom sort this out
Old 11-05-2019, 10:45 AM   #20
Soloside
was racerom issue. mike squared it right away
2014 Subaru BRZ
The Following User Says Thank You to Soloside For This Useful Post:
steve99 (11-05-2019)
abs, module, tsc, vsc
EcuTek programming kit h@zmat Engine, Exhaust, Bolt-Ons 4 03-09-2017 08:15 PM
Key FOB programming milkesfrs Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 10-21-2015 03:56 PM
Key fob programming sambrz BRZ First-Gen (2012+) — General Topics 4 10-08-2015 10:08 AM
WTT - 2014 Scion Bespoke Nav Module for Toyota AHA Nav Module Danklvr Audio/Visual, Electronics, Infotainment, NAV 1 09-04-2014 05:57 PM
