Drives: Drives like a crab.
Catted Mid pipe project
Hi everyone,
I need your insights on a odd idea I just had. What I want: - To benefit from the extra power a catless header allows (think Ace header / Tuning Development UK with a tune) with an reasonable amount of exhaust smell What I need: - To still pass inspection (Europe - Belgium / they don't fuck around with CO emissions). I can manage to get the exhaust pretty hot before passing inspection. What I though of: - Adding one or two 100/200 cell cats on the midpipe. I believe the stock cat header is a 400-cell right? Why? Because it looks like the easiest way to relocate a cat. My questions: - Would adding those cat down the line get the aforementioned effects I'm looking for? Thanks in advance for your inputs. |
#2 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Just swap the OEM back in when inspections come around. It's what people doing in California and other strict emission states here.
#3 |
You know there's a secondary cat in the front pipe already, right? Are you talking about adding one after that, or another in front of it in the front pipe?
#4 |
Rust bucket enthusiast
Be wary that the center pipe section is recessed into the car's body, it's not like you have a ton of room to fit a wide cat in. They may penalize you anyway because the catalyzer is only effective when it's closer to the heat source.
| The Following User Says Thank You to DarkPira7e For This Useful Post: | wparsons (11-05-2019) |
#5 |
#6 | |
I'm looking for something that could look OEM and therefore pass inspection, that gets rid of the smell and that allows me to mount a catless header (and benefit from the better exhaust scavenging and more aggressive tune). I often read that the placement of the cat on the header is only to insure faster heat up process and that the stock cat is a 400-cell one. Would adding one 200-cell or two 100-cell down the line achieve this? |
#7 |
Drives: Crapcan
If you omit the cat in the header and add a second cat to the mid pipe in addition to the one that is already there, I do not believe the second one would get hot enough to be effective. That is just a guess though. Only way to know is to try.
#8 |
Drives: 2014 GT86
I guess that if header is coated & wrapped to retain heat inside more, then more of heat can be passed to cats in midpipe aswell, no?
#9 |
Drives: Crapcan
Increased heat, increases NOx emissions. So as long as it is not knocking NOx out of range that may work. Would be nice if OP had access to a private shop with an exhaust gas analyzer. Only way to know for sure is to try.
#10 |
If all you're worried about is smell, keep the stock front pipe, or get one with a high flow cat in it. Problem solved.
| The Following User Says Thank You to wparsons For This Useful Post: | JD001 (11-06-2019) |
#11 | |
If the cat is placed just a bit after the FP cap, then, it could get up to temp as well as the FP cat does, couldn't it? |
#12 |
Drives: 13 mt fr-s
It sounds like you should just keep the exhaust stock... and supercharge.
#13 | |
What front pipe though? There's two cats stock, one in the header and one in the front pipe. The catback is after the front pipe.
#14 |
Don't worry, I know the exhaust like my pocket, ahah!
I mean, would adding a 100/200-cell cat after the second cat do the trick? I don't care if the care smells when it warms up. As long as, when it's warm, the smell is gone, then mission accomplished. But would I benefit from the added performance of a catless header? Just by "moving" the first cat down the line and swapping it for a sportier one? Supercharging... I would love that! But hey, this is Belgium... Change your rims and you won't pass inspection. That's half true though. |
| FS: P&L catted & coated EL header, Perrin catted front pipe and res 2.5" catback | Turbowned | Engine, Exhaust, Bolt-Ons | 13 | 08-11-2019 11:54 PM |
| catted header or catted front pipe? | gabeg86 | Engine, Exhaust, Transmission | 28 | 10-13-2015 12:32 PM |
| Catted header or catted front pipe? | wilfredwong | Engine, Exhaust, Transmission | 5 | 02-09-2015 06:11 PM |
| Group Buy: TSUDO Performance Hi-Flow catted Test Pipe/Front Pipe/ Downpipe | JonMotoring | Groupbuys | 65 | 08-27-2013 12:33 PM |
| P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? | Xdragonxb0i | Engine, Exhaust, Transmission | 23 | 04-24-2013 12:29 PM |
