Old 10-31-2019, 03:32 PM   #1
Ckirkbrz
Drives: 2013 suabru brz
Osv solenoid
So my brz is in for the recall .. so I told em to change the clutch and plugs..the y called me today and said that one of the 4 osv solenoid is failing and that it messed up a wiring harness..so now they say roughly a 1000 to change all 4.. do this sound legit???.. they charged me 800 for the clutch flywheel Tob and plugs..thought?
Sent from my Pixel 3 XL using Tapatalk
Ckirkbrz is offline   Reply With Quote
Old 10-31-2019, 04:47 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That does not sound right. I would go down there and ask to see the part in question and the wiring harness. It almost sounds like they damaged it. I don't see how a bad OSV would lead to a harness issue.
Tcoat (10-31-2019)
Old 10-31-2019, 04:57 PM   #3
A quick search shows that there are many issues with OSV solenoids in Subaru's but I have never seen it come up on here before. As No said I would want to see some evidence.
Old 10-31-2019, 04:59 PM   #4
AutoNewb
Drives: 2014 Subaru BRZ Sterling Silver
Yeah..... I don't quite understand this relating to the harness. Failing OSV's/OSV's usually result in a CEL of P0016, P0017, P000A, and there is another I forget. I had a few cam issues at 86k miles. CEL just magically showed up one day. Went to an awesome shop near me. They found out that my timing was advancing too much. When they opened everything up, they found out a faulty OCV, cam gear, and ECU was causing the timing issue. After they replaced them everything returned back to normal.
If you TL;DL then ask them to go through it with you physically, see what is actually happening. I think they arent telling you something or they are trying to cover their asses for something they did. Is there a CEL? Is timing advancing or retarding beyond what it should be? Questions to ask them.
AutoNewb is offline   Reply With Quote
The Following User Says Thank You to AutoNewb For This Useful Post:
Tcoat (10-31-2019)
Old 10-31-2019, 05:21 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Whatever OP chooses to do, I wouldn't go in hot and bothered, armed with info from the internet. I would just ask to see the parts. Thinking about it I guess the pins from the Osv could have got stuck in the harness connector, but I doubt it. Or maybe an internally shorted osv could have melted the harness? It will be pretty apparent looking at it.
Tcoat (10-31-2019)
Old 10-31-2019, 06:15 PM   #6
Ckirkbrz
Hey so I just found this article which is pretty much spot on with what they said happened
https://www.autoserviceprofessional....desktop-view=1
The Following 2 Users Say Thank You to Ckirkbrz For This Useful Post:
Grady (11-01-2019), NoHaveMSG (10-31-2019)
Old 10-31-2019, 06:22 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Good find
Old 10-31-2019, 07:30 PM   #8
Ckirkbrz
Thanks everyone for the responses..I really appreciate the help
The Following User Says Thank You to Ckirkbrz For This Useful Post:
Old 11-01-2019, 06:43 PM   #9
Grady
Grady's Avatar
Old 11-01-2019, 06:44 PM   #10
Grady
Grady's Avatar
If that is the case, I would push to see if Subaru would give you some concession on this repair.
WTB: Used Perrin Cam Solenoid Guard MicheleAbbate Want-To-Buy Requests 0 06-26-2017 06:56 PM
Need Boost Solenoid Connector GsxrMe Forced Induction 1 01-16-2017 06:41 AM
Canister purge solenoid aero.kit Engine, Exhaust, Transmission 1 08-31-2014 03:19 PM
EVAP Solenoid Ryan P Forced Induction 0 06-25-2014 09:43 AM
Gearshift solenoid issue Gotchaman Engine, Exhaust, Transmission 0 12-30-2013 06:32 PM
