Drives: GT86
Gearshift solenoid issue
Hi all
Perplexing problem. GT86 with an autobox, the solenoid that releases the shifter when the brake is pressed failed( burnt out) and was replaced but it still won't activate on brake, so the override has to be used ( push button). Ecu shows no issues, brake switch and main ecu changed with no difference. Anybody experienced similar. From what I understand the solenoid is fed power straight from the main ecu. Could anyone confirm which wire on the ecu to test for continuity? Assuming the wiring is okay, any other ideas why power would not be fed? Cheers |
| BRZ/FR-S Gunma plant aware of these Solenoid, Cam, CEL problems? | 07stealth350z | Issues | Warranty | Recalls / TSB | 24 | 11-18-2015 07:44 PM |
| BRZ Nav MP3 issue | TheRipler | Electronics | Audio | NAV | Infotainment | 5 | 09-06-2013 02:21 PM |
| Serious issue with FRS!!!!. | _F-R-S_ | Issues | Warranty | Recalls / TSB | 16 | 08-28-2012 10:08 AM |
| Anyone having this issue? | zoomzoomers | BRZ First-Gen (2012+) — General Topics | 11 | 08-09-2012 11:19 PM |
| Thread size and pitch on gearshift knob. | SilentMike | Engine, Exhaust, Transmission | 8 | 02-02-2012 02:20 PM |
