Old 10-31-2019, 12:16 PM   #29
Flunoir
Drives: stanced
Ohhhhhh. Well not to scare you but that opens up a whole new range of possibilities. When messing with ECUs anything can happen. Best get it in to somebody that can actually see what is going on.
I’m going to go to my local auto zone and have them load test my battery because it looks like the oem battery so the previous owner probably never changed it. In regards to the tuning, he was going to give me an oft tune for pops and crackles but it couldn’t flash to my car because it was “married” to his car and I guess the oft only allows for one car to be married with a tune so, I believe it reset my ecu but I don’t think anything really bad happened from it because that was a couple of weeks ago and my car has been fine since.
Flunoir is offline   Reply With Quote
The Following User Says Thank You to Flunoir For This Useful Post:
Tcoat (10-31-2019)
Old 10-31-2019, 12:24 PM   #30
Good plan. It sounds like a battery or contact issue to me. If all he did was attempt to flash with a married OFT then all should be fine there.
Wouldn’t totally rule out the custom light yet though since they have been known to cause some weird issues.
Old 10-31-2019, 12:51 PM   #31
p1l0t
p1l0t's Avatar
I tried that! And it still didn’t work!
The car didn't go to ON? Or the OBD-II just didn't connect?
Old 10-31-2019, 01:37 PM   #32
Flunoir
Drives: stanced
Both
Old 10-31-2019, 01:38 PM   #33
Flunoir
Drives: stanced
I’m at Autozone and the guy wants me to get my Vin and call Scion
Old 10-31-2019, 02:21 PM   #34
Flunoir
Drives: stanced
At this point I believe my immobilized has stopped my car from working properly
Old 10-31-2019, 03:21 PM   #35
We are back to the ECU possibly being messed up then.
http://www.ft86club.com/forums/showthread.php?t=122100
http://www.ft86club.com/forums/showthread.php?t=100168
http://www.ft86club.com/forums/showthread.php?t=120838
Old 10-31-2019, 03:22 PM   #36
p1l0t
p1l0t's Avatar
Both
That's actually good news. If the car won't go ON than that's why the OBD-II isn't talking. So it isn't a complicated software issue most likely just a power issue. Maybe a bad battery or a loose wire?
Spuds (10-31-2019)
Old 10-31-2019, 04:58 PM   #37
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I did have a custom reverse light installed but that was a couple of weeks ago and I also had a friend of mine try to tune my car but he said it didn’t work but I don’t know what he did to my ecu or if he messed anything up on accident.
So this is all what you should put in the original post. Go through all the reverse light wiring. Talk to your friend who may have damaged your ECU or OBD connector.
Old 10-31-2019, 05:18 PM   #38
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
My initial guess would be the alternator. I had mine go out on a '98 200SX that I owned,and when it went bad(while driving) a bunch of weird electrical stuff started happening,like weird flashing lights.I'm not mechanic so take that for what it's worth,but that would be my very first guess from past experience.
Th3rdSun is offline   Reply With Quote
Old 10-31-2019, 05:48 PM   #39
EAGLE5
Dismember
EAGLE5's Avatar
If it's the alternator, I have a slightly used one I'll sell you for $25 bucks picked up.
Old 10-31-2019, 06:33 PM   #40
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Battery tests fine, so you would see it start then drain the battery. This one won't let him turn the car on, or operate the windows, or...
The Following User Says Thank You to Spuds For This Useful Post:
Tcoat (10-31-2019)
Old 10-31-2019, 08:15 PM   #41
Flunoir
Drives: stanced
Thank you all for your responses but it has to be the immobilizer.
Old 10-31-2019, 08:30 PM   #42
Spuds
The Dictater
Spuds's Avatar
Agreed. Was just explaining why it wasn't the alternator.
2013 FRS Engine Died Jamesallen45 Issues | Warranty | Recalls / TSB 24 05-31-2018 04:30 PM
Beatrush Catless Equal Length Exhaust Manifold Subaru BRZ 2013-2015 / Scion FR-S 2013 RallySport Direct Engine, Exhaust, Bolt-Ons 21 06-03-2015 02:21 PM
Takeda Intake System; Stage 2 Wrinkle Black; PRO 5R; Scion FR-S 2013 H4-2.0L TM-2013 AMPLIFIED MOTORSPORT Engine, Exhaust, Bolt-Ons 16 10-03-2012 08:03 PM
2013 Subaru BRZ and 2013 Scion FR-S: A Study in Comparison and Contrast Zgrinch Scion FR-S / Toyota 86 GT86 General Forum 124 02-21-2012 02:43 AM
