Old 07-19-2012, 11:29 PM   #1
ArKiTeCkT
ArKiTeCkT's Avatar
Drives: 2010 Gen Coupe, 2013 BRZ 6MT S.Tech
Catch Can
Anyone planning to install a catch can on their car?
ArKiTeCkT is offline   Reply With Quote
Old 07-19-2012, 11:30 PM   #2
Unleashed
Unleashed's Avatar
Drives: 13' WRX
I am. Plan on buying the Cusco Oil Catch Can soon. I like the blue color that cusco parts come in so i will be going cusco everything.
Unleashed is offline   Reply With Quote
Old 07-19-2012, 11:32 PM   #3
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
I just locally bought a Top Fuel can for cheap. The only issue I have is the catch can cannot be laid sideways, or else the volume gauge becomes useless. I had a perfect place to install it too. Shucks.
http://www.frsport.com/Top-Fuel-Zero...ty_p_8134.html
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
The Following User Says Thank You to markmatley For This Useful Post:
Hawaiian (07-20-2012)
Old 07-19-2012, 11:48 PM   #4
ArKiTeCkT
ArKiTeCkT's Avatar
^Does it matter if its vertical or sideways? Where did you install it?
Old 07-19-2012, 11:58 PM   #5
markmatley
markmatley's Avatar
I wanted to install it on the top near the Toyota D4S logo, but then realized that plastic cover is not bolted down, just clipped in. I'm thinking I need to make a bracket since my second hand kit didn't come with a bracket.
Sorry that wasn't much help. I really haven't had time to investigate more. Gotto love grad school.
~Matt
Old 07-20-2012, 12:38 AM   #6
ArKiTeCkT
ArKiTeCkT's Avatar
You can put it here. Thats where I might put mine. The Cusco Oil Catch Can is not baffled.
ANYONE KNOW OF A GOOD BAFFLED OIL CATCH CAN?
Old 07-20-2012, 08:12 AM   #7
Apex Chase
El Presidente
Apex Chase's Avatar
Drives: it like I stole it!
When I get my car a catch can will be installed ASAP.
Apex Chase is offline   Reply With Quote
Old 07-20-2012, 08:21 AM   #8
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Why do you need a baffled catch? Im still waiting for results to show that catch cans are even useful on this setup.
chulooz is offline   Reply With Quote
Old 07-20-2012, 08:37 AM   #9
nix
nix's Avatar
Drives: AVO BRZ
I will install one when I go FI.
nix is offline   Reply With Quote
Old 07-20-2012, 08:38 AM   #10
Apex Chase
El Presidente
Apex Chase's Avatar
Because the oil vapor needs something to condense on, otherwise it stays in suspension and the majority will pass right though. In modern engines, especially performance applications, catch cans are always beneficial.
Old 07-20-2012, 08:52 AM   #11
nix
nix's Avatar
Drives: AVO BRZ
They are built to handle that blow by sludge, it's minimal to non existent on modern NA engines anyway. There's nothing wrong with installing one on the stock engine but there is no need to.
Old 07-20-2012, 11:18 AM   #12
ArKiTeCkT
ArKiTeCkT's Avatar
^Is there any proof that the catch can provides very little benefits on NA car?
Old 07-20-2012, 11:43 AM   #13
Apex Chase
El Presidente
Apex Chase's Avatar
You are sorely mistaken. When I get back to the office I have some photos of the inside of some modern NA engines for you. After about 50k miles it gets pretty nasty in there if you do not take steps to keep it clean.
The Following User Says Thank You to Apex Chase For This Useful Post:
Hardrock4445 (09-15-2013)
Old 07-20-2012, 11:58 AM   #14
Genomaxter
Drives: 2013 firestorm FRS
You definatly want a can even NA. My 2zz develops puddles of oil in the manifold from blow by. The cylinder walls are MMC so they are not worn or out-of-round. There will always be blow-by.
Genomaxter is offline   Reply With Quote
Oil Catch Can? eblamble3 Engine, Exhaust, Transmission 4 03-15-2013 11:58 AM
where to plug the oil catch can hose... :S dompower Engine, Exhaust, Transmission 29 11-14-2012 01:30 PM
Cusco Oil Catch Can for BRZ/FR-S at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 0 07-01-2012 04:16 AM
Purpose of oil catch can? denverizzles Engine, Exhaust, Transmission 1 06-28-2012 04:55 PM
Cusco Street Oil Catch Tank 0.6L in stock!!! IslandImportPerformance Engine, Exhaust, Bolt-Ons 0 06-05-2012 01:56 AM
