Old 10-30-2019, 10:59 PM   #1
Flunoir
Drives: stanced
Ayo what da dog doin’
Hello all! I am new to this site so please bare with me but I decided to create an account to reach out to my 86 family for some help. A couple of days ago, I was driving on the road and my car abruptly turned off and made some beeping noises and threw some lights on and the power steering went out. I managed to drive to the am empty parking lot and then I couldn’t shift out of gear to put it into park so I came to an complete stop and held on the brake and took the me out. I used the shift bypass button and got into park and tried to start my car. It didn’t start and didn’t make any noises like it was even trying to start. Here is what is also wrong: the windows won’t roll up or down, the radio doesn’t work, and the windshield wipers don’t work yet the lights and everything else still do. I went to get my battery tested and it was all good and didn’t need to charge or anything. My main guesses after doing some research are that the alternator, starter, or spark plugs have gone bad. Please help me find out what is wrong with my car! There are no mods to this car other than muffler delete. Has 68k miles and has stock everything! If you need any additional info I’d be more than happy to provide you with it! Thanks!
Flunoir is offline   Reply With Quote
Old 10-30-2019, 11:24 PM   #2
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
None of those items will cause window issues. Need to get a real OBD2 scanner or techstream to look at all the modules. Windows up/down seems BCM related for sure. I'd suspect a ground/wiring fault. Any history on this car? Flood etc?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 3 Users Say Thank You to Dave-ROR For This Useful Post:
JesseG (10-31-2019), p1l0t (10-31-2019), Spuds (10-30-2019)
Old 10-30-2019, 11:44 PM   #3
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
+1 for wiring fault. Easiest thing to do without getting it towed is to get a cheap OBD2 reader, see if you can pull codes, and do a search on what comes back, but that might not have enough information. That might not work if the ECU isn't starting up though...
Also, any chance any critters might have chewed through something?
Spuds is online now   Reply With Quote
The Following User Says Thank You to Spuds For This Useful Post:
JesseG (10-31-2019)
Old 10-31-2019, 12:04 AM   #4
Flunoir
Drives: stanced
It’s a used car I bought in April and it had one owner and was well maintained but mostly kept in the garage.
Old 10-31-2019, 12:04 AM   #5
Flunoir
Drives: stanced
If love to do that! Where are good places to get one?
Old 10-31-2019, 12:29 AM   #6
Spuds
The Dictater
Spuds's Avatar
Just search "OBD2 reader", Amazon or Walmart should have them. Should be $10-20 for a basic one which is all you need. As for stores, chain auto parts stores or something like a Walmart or Target might have some in stock. Not something most people pick up at a store, but might be a quicker way to get it.
Just checking, when you turn the key to the On position, do all the warning lights in the instrument cluster turn on or is it completely dead? If they turn on, you should be able to pull the codes. If it's dead, that might not work.
Old 10-31-2019, 12:38 AM   #7
Flunoir
Drives: stanced
Yes, some of the lights come on but definitely not all of them. Also I’ll check for some at Walmart next time I visit one.
Old 10-31-2019, 01:14 AM   #8
Welcome to our forum -
I'd suggest you drive your car (or have it towed) to a dealership or an automotive shop. Even if you read and lookup the codes, it sounds like the car is eventually going to wind up in a shop to be fixed.
JesseG (10-31-2019)
Old 10-31-2019, 01:21 AM   #9
Flunoir
Drives: stanced
Thank you for your input!!
Old 10-31-2019, 01:44 AM   #10
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Sounds like a bad ground or bad circuit board somewhere. Did you check fuses yet?
Old 10-31-2019, 02:13 AM   #11
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
I am not an expert but just wanted to share my experience regarding the fuses at a dealer for my regular service check on my MY19 brz.
While they opened the hood somehow they pulled the fuse taps that I used for my dashcam. Those idiots, did not know the slot for the fuses and were not able to start the car. I watched them through the window. They tried jump stating without letting me know and changing the battery of the key!!! After witnessing all this I asked them what’s going wrong and why it took 3 hours for a oil change.
Finally they told me the situation and I told them the fuse slots (I think it was the radio stop lights) and the car started immediately.
Maybe it’s not even close to your situation but checking the fuses would be the first thing I would do.
Thanks
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
The Following 2 Users Say Thank You to Busybee For This Useful Post:
JesseG (10-31-2019), korhun (10-31-2019)
Old 10-31-2019, 02:45 AM   #12
Flunoir
Drives: stanced
I haven’t checked the fuses yet. I just got home from buying an obd code reader so now I’m going to see what shows up if anything.
Old 10-31-2019, 03:09 AM   #13
Flunoir
Drives: stanced
So I just plugged in my new obd2 into my FR-S and it isn’t working! I went to go try it in my other car and it worked perfectly fine! What could be causing my car not to start and for the scanner to not work?! This is infuriating!
Old 10-31-2019, 03:23 AM   #14
EAGLE5
Dismember
EAGLE5's Avatar
Check the fuses. I think there's even one on the positive battery cable.
2013 FRS Engine Died Jamesallen45 Issues | Warranty | Recalls / TSB 24 05-31-2018 04:30 PM
Beatrush Catless Equal Length Exhaust Manifold Subaru BRZ 2013-2015 / Scion FR-S 2013 RallySport Direct Engine, Exhaust, Bolt-Ons 21 06-03-2015 02:21 PM
Takeda Intake System; Stage 2 Wrinkle Black; PRO 5R; Scion FR-S 2013 H4-2.0L TM-2013 AMPLIFIED MOTORSPORT Engine, Exhaust, Bolt-Ons 16 10-03-2012 08:03 PM
2013 Subaru BRZ and 2013 Scion FR-S: A Study in Comparison and Contrast Zgrinch Scion FR-S / Toyota 86 GT86 General Forum 124 02-21-2012 02:43 AM
