| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#29 |
Drives: 2013 Subaru BRZ
the parking garage who lost my key fob had 3 locksmiths come. only 1 seemed capable of doing it. but his software did not work with subaru brz or something. not sure why not.
luckily i was able to uber home and get my only backup fob which im using now. |
#30 |
do you think i should replace my OBD2 port? Mike at Xero-Limit suggested that. But i was then able to use my OBD2 port and software (Carista) just fine to connect. Maybe the dealership requires a better connection? Who knows. Maybe I should replace it?
#31 |
Drives: Toyota 86 2017
Just for fun do you have tried to read your ecu with techstream ?
#32 |
#33 |
Drives: '15 Subaru BRZ
Not that is helpful due to the problems you currently have, but every Subaru will have a code for the AC Sunload sensor if you scan it inside a building. This is not a problem. If you put the car outside and scan it the code won’t be there. Do not try to “fix” this code.
| The Following User Says Thank You to Ragin Gti For This Useful Post: | Opie (10-30-2019) |
#34 |
Techstream is the software toyota use for all is model, you can do anything with this like programming key etc, the only thing you cannot do is play with the odometer, im sure it's will work with the brz, if it's work with the 86 it's will work with your car,
For the cable with a copy of the sotware here : https://www.amazon.com/capital_auto-...=fsclp_pl_dp_9 You can find more recent software problably on this forum or on the web |
| The Following 2 Users Say Thank You to misterfly For This Useful Post: | Lantanafrs2 (10-29-2019) |
#35 | |
my check engine light has been on for months due to the sunload sensor and my car is always parked outside. my car is never inside. not sure what your talking about. i scanned it using my own tool outside, it shows the ac sunload sensor. how does that have anything to do with being inside then?
#36 | |
thanks but i would have absolutely no clue on how to use that tool to reprogram my key and i would be hesitant in using it because who knows if i mess something up in using it, but thx tho.
#37 |
That code will not turn the check engine light on. There’s something else causing it.
#38 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#39 | |
Site Moderator
Drives: Stuff
-Dave
#40 |
well when i run the diagnostics for the check engine light. thats what the code returns. Code B14A1. Sunload sensor circuit. No other codes are shown except that.
#41 |
true my mistake,i did run the diagnostics using my car and its always outside, but when the dealership ran it using their software they are inside.
#42 | |
ok thx ill consider it
| Tags |
| brz, ecu |
| Tuners like "Mugen" or "Spoon" for Subaru? | Seiryuu | BRZ First-Gen (2012+) — General Topics | 21 | 09-08-2018 03:33 PM |
| dealership thats willing to fix timing cover leak for "heavily modified" brz | iarefluffy | Southern California | 14 | 12-28-2017 11:53 PM |
| Will the dealership "ECU Flash" be reset to factory after disconnecting battery? | spatcha88 | Engine, Exhaust, Transmission | 5 | 04-02-2015 02:35 AM |
| Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? | davidchoi | Cosmetic Modification (Interior/Exterior/Lighting) | 49 | 11-22-2014 10:17 PM |
| Collection of "Subaru axing BRZ" & "Subaru making next-gen BRZ" rumor threads... | mav1178 | Other Vehicles & General Automotive Discussions | 42 | 07-07-2014 03:52 PM |
