Old 10-27-2019, 10:28 PM   #29
morswestford
morswestford's Avatar
Drives: 2013 Subaru BRZ
the parking garage who lost my key fob had 3 locksmiths come. only 1 seemed capable of doing it. but his software did not work with subaru brz or something. not sure why not.
luckily i was able to uber home and get my only backup fob which im using now.
Originally Posted by Decep View Post
That does sound like quite a mess. I'd try an indie locksmith, i had one copy my current key to an aftermarket key (obviously doesnt help your AC issues)
morswestford is offline   Reply With Quote
Old 10-27-2019, 10:30 PM   #30
morswestford
do you think i should replace my OBD2 port? Mike at Xero-Limit suggested that. But i was then able to use my OBD2 port and software (Carista) just fine to connect. Maybe the dealership requires a better connection? Who knows. Maybe I should replace it?
Originally Posted by ls1ac View Post
Back to really simple. Had a friend that my "good" reader would not work, but the cheep one would. It seems that the connecter in the car is not great. I used an extender cord with the good reader and all worked well.
Just a thought.
Old 10-28-2019, 10:38 AM   #31
misterfly
Drives: Toyota 86 2017
Just for fun do you have tried to read your ecu with techstream ?
misterfly is offline   Reply With Quote
Old 10-29-2019, 02:42 AM   #32
morswestford
no, no idea what techstream is, please inform
Old 10-29-2019, 08:09 AM   #33
Ragin Gti
Drives: '15 Subaru BRZ
Not that is helpful due to the problems you currently have, but every Subaru will have a code for the AC Sunload sensor if you scan it inside a building. This is not a problem. If you put the car outside and scan it the code won’t be there. Do not try to “fix” this code.
Ragin Gti is offline   Reply With Quote
The Following User Says Thank You to Ragin Gti For This Useful Post:
Opie (10-30-2019)
Old 10-29-2019, 09:09 AM   #34
misterfly
Techstream is the software toyota use for all is model, you can do anything with this like programming key etc, the only thing you cannot do is play with the odometer, im sure it's will work with the brz, if it's work with the 86 it's will work with your car,
For the cable with a copy of the sotware here : https://www.amazon.com/capital_auto-...=fsclp_pl_dp_9
You can find more recent software problably on this forum or on the web
The Following 2 Users Say Thank You to misterfly For This Useful Post:
Lantanafrs2 (10-29-2019)
Old 10-29-2019, 10:33 AM   #35
morswestford
my check engine light has been on for months due to the sunload sensor and my car is always parked outside. my car is never inside. not sure what your talking about. i scanned it using my own tool outside, it shows the ac sunload sensor. how does that have anything to do with being inside then?
Old 10-29-2019, 10:36 AM   #36
morswestford
thanks but i would have absolutely no clue on how to use that tool to reprogram my key and i would be hesitant in using it because who knows if i mess something up in using it, but thx tho.
Old 10-29-2019, 11:24 AM   #37
Ragin Gti
That code will not turn the check engine light on. There’s something else causing it.
Old 10-29-2019, 12:10 PM   #38
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
To be fair you never mentioned where you scanned it but did mention your local shop tried to fix it. *They* would have scanned it indoors, so it's not unreasonable for him to assume it was scanned indoors.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-29-2019, 12:11 PM   #39
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Outside of getting it running the first time, it's an easy tool to use. You won't mess anything up by going through the key programming. Granted I haven't used it for that since I haven't needed to. I think @Opie might have though. We've used it to troubleshoot other stuff on these cars though...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-29-2019, 12:34 PM   #40
morswestford
well when i run the diagnostics for the check engine light. thats what the code returns. Code B14A1. Sunload sensor circuit. No other codes are shown except that.
Old 10-29-2019, 12:35 PM   #41
morswestford
true my mistake,i did run the diagnostics using my car and its always outside, but when the dealership ran it using their software they are inside.
Old 10-29-2019, 12:36 PM   #42
morswestford
ok thx ill consider it
brz, ecu
Tuners like "Mugen" or "Spoon" for Subaru? Seiryuu BRZ First-Gen (2012+) — General Topics 21 09-08-2018 03:33 PM
dealership thats willing to fix timing cover leak for "heavily modified" brz iarefluffy Southern California 14 12-28-2017 11:53 PM
Will the dealership "ECU Flash" be reset to factory after disconnecting battery? spatcha88 Engine, Exhaust, Transmission 5 04-02-2015 02:35 AM
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? davidchoi Cosmetic Modification (Interior/Exterior/Lighting) 49 11-22-2014 10:17 PM
Collection of "Subaru axing BRZ" & "Subaru making next-gen BRZ" rumor threads... mav1178 Other Vehicles & General Automotive Discussions 42 07-07-2014 03:52 PM
