#141 |
I made an attempt to emulate the PD with an Arduino and CANbus shield but was only able to get the car to respond to it if the car was up to temp and stationary. Not sure how you got around the coolant temp requirement. Is it possible to turn PD on/off while the car is moving? I was so excited when I was able to emulate PD but bummed when I noticed I could only turn it on when the car was stopped. It wasn’t practical to have to get it up to temp and then come to a stop to turn it on.
#142 |
My VTEC fluid is full
Drives: EFF JAY
#143 | |
Drives: MR2, Sliver BRZ
But if you think about it this way. your car if off. completely stopped. The moment you start your car. my PD doesn't care about temp or RPM so it engages. If your out in the track and you stall your car, you don't have to switch it to the off position then to the on then to crank. You typically just Crank again. and if your moving while cranking means your car never really goes to fully off. so PD would still be active. Only time i would worry about is if the car completely shuts off for some reason as your still moving. But that would mean there might be something wrong with your car.
Always looking to tinker with something..
#144 | |
Since beastronix is no more, what’s the alternative?
Technically PD is not made for track use. It’s a test mode used for diagnostics that just so happens to be useful on track. It’s not a Contra Code that someone stumbled on one day. It’s all documented in the service manual. The service manual explains how to enable this mode with the PD or with Techstream via canbus. Anyways, I use it frequently on and off track. TC is way to aggressive. Hell I’ll downshift to 3rd gear to make a pass on the interstate and I’m rewarded with a flashing TC light and a car running up on my ass. If I need to make a U-turn in heavy traffic it’s a death wish without doing a long hold first. I’d much rather have a toggle switch for this. Also there are plenty of times I’m coming up on a fun turn and do a long hold right before reaching the turn and some times I will turn it right back on when done. In my experience I could only emulate Techsteam’s test mode while stationary but turning it back off could be done while moving. So at least if it started raining I didn’t have to stop the car to turn TC back on. Last edited by ermax; 10-29-2019 at 12:40 AM. |
#145 |
ProCrastinationConsultant
Push start cars typically require 2 button presses to restart. At least mine does. First press turns everything off, 2nd press engages the starter
#146 | |
I’m a software dev so I fully respect the time it takes to develop stuff like this and you deserve to be paid. I would never try to rip off your work. When I said I wasn’t sure how you got around the temp issue I wasn’t expecting you to reveal your magic. It was more of a back pat to you for pulling it off. ![]() I’d love to hear back if it works while moving. At first I thought I had a bug in my code causing it to not work randomly but then realized it wasn’t random at all but simply related to speed. I did all the dev in the driveway while not moving. Hahaha |
#147 |
| The Following User Says Thank You to ermax For This Useful Post: | Clutch Dog (11-07-2019) |
#148 | ||
Drives: EFF JAY
I agree with you. I just don't see the logic or the inconvenience of waiting for a warm engine to enable the pedal dance. Would you drive the car to a point where TC is activated on a cold engine? |
#149 | |
I’m not really concerned about the temperature requirement. I’m not going to drive the car aggressively while it’s cold anyways. My concern is the requirement to be stationary. I agree this isn’t an issue at the track but I’d love to be able to turn it off while on the road and moving. I generally have the aids enabled on public roads but when I want them off it’s almost always while I’m already moving. |
#150 | |
Drives: EFF JAY
#151 | |
But as for PD being in there. Under techstream description says that it disables VSC and TC if no switch is available. So im sure it was somewhat intended but not "officially" there haha. @soundman98 really? if my car is on, and i stall it (i did once or twice lol) the car is in the "on" position, so all i have to do is press the clutch and power button and starter kicks in. it never "shuts down" or i never have a need to go into a completely off state. but to ermax point sometimes in cold weather it can take a long time for the car to get to "operating temp" so that PD could work. Even here, it take at least 10 minutes to be able to get to that temp.
#152 |
Drives: Subaru BRZ
When instructing, I often do not have the luxury to get the car completely up to temp for my session, especially when the temps dip below 50 F. In those cases, you start a car cold with the pedal dance already activated, and short shift for the first lap or two until everything is up to temp. It would be super inconvenient if I had to pit in to activate the pedal dance, at this point I can just do it manually.
| The Following User Says Thank You to Code Monkey For This Useful Post: | Pat (10-29-2019) |
#153 | |
Drives: 2015 Subaru BRZ Limited DGM
It can even happen in your own car. In fact it did happen to me this season. Rainy day in April. Barely above 40F for the first session. Scrambling a bit to get coffee and food in me and didn't start warming up the car soon enough to get the PD done. I went out anyway figuring if it was a problem I'd pit and the car would be warm by then. Well... at the end of the front straight at Palmer, the braking for T1 is rising up a hill, then flattening out. EBD freaked out, the pedal went hard, I lost all braking feel, swapped ends, and came to a stop just off the track staring out my driver's window at the front end of my buddy's car. He'd seen the whole thing happen and wisely just parked his car rather than try to squeeze through. I pitted, did the PD, and no problems the rest of the event. I just don't want to have to worry about it anymore, and the other goodies (fans, belt chimes, TPMS) are just a bonus. |
| The Following User Says Thank You to gcranston For This Useful Post: | Code Monkey (10-29-2019) |
#154 | |
Drives: Crapcan
Preordered today
| WTB a Beastronix 86 Nanny unit | tonylop33 | Want-To-Buy Requests | 0 | 09-25-2018 07:14 PM |
| FS: Beastronix 86 Nanny - SOLD | Agent_D | Engine, Exhaust, Bolt-Ons | 3 | 05-09-2018 01:57 PM |
| Beastronix Install | HoonThis | Software Tuning | 4 | 06-08-2017 10:02 PM |
| Flex Fuel Kit and Beastronix 86Nanny Trac/VSC | Juanito08 | Engine, Exhaust, Bolt-Ons | 7 | 05-10-2017 02:20 PM |
| Beastronix - 86 Nanny , Speed Academy version | brzaapi | User/Vendor/Sponsor Reviews, Feedback, Comments | 4 | 07-05-2016 11:17 AM |
