Old 10-19-2019, 11:26 AM   #1
toast
Drives: 14 BSP Edelbrock BRZ
Rich transient fuel condition
All,
In the process of tuning my Edelbrock kit with Zach from CSG. Everything is pretty much dialed in, but we have an issue with throttle transients from a stop. He has already removed over 30% of the fuel from the transient tables but when leaving a stop my AFR goes very rich for a second before recovering. This causes a very slight but very annoying stumble when taking off from a stop. Zach suspects one of my injectors may have a small leak since the fueling is dead on when driving normally. I'm going to get a pair of new injectors and start swapping them out one side at a time.
Anyone else ever run across this?
toast is offline   Reply With Quote
Old 10-19-2019, 09:25 PM   #2
steve99
Drives: FT86
Do you have fairly large port injectors fitted ?
If you have aftermarket pump fitted check fuel pressure isnt too high should be arround 60psi
Try running 100% direct injection only till say 0.7 load if its not already done.
Old 10-19-2019, 10:44 PM   #3
toast
Everything is stock.
I'll let Zach do the tuning parts, just wondering if anyone ever had experience with a leaking injector and what the symptoms are.
Old 10-22-2019, 11:23 AM   #4
toast
That makes sense, thanks.
Old 10-23-2019, 01:39 AM   #5
Mr_Eyo
Drives: 2017 Toyota 86
Originally Posted by toast View Post
All,
I've got the same thing. Large IPW and retarded timing starting on the gas. 2017 AT. Not sure anything can be done since it prevents knocking.
Mr_Eyo is offline   Reply With Quote
Old 10-23-2019, 06:54 AM   #6
freerunner
freerunner's Avatar
Drives: GT86
Load limits ok, not too high?
freerunner is offline   Reply With Quote
Old 10-23-2019, 10:18 AM   #7
toast
Who did your tune? Zach said that the richness that he sees in my log is not on purpose and not normal. I thought the small stumble I always felt leaving a stop was me not being able to drive with the new clutch until I caught it one particularly cold morning when the car was outside. Just giving it a little gas while sitting still made it almost stall and I caught it in a log.
Old 10-24-2019, 05:51 PM   #8
steve99
Drives: FT86
Racerom​ 10 had a bunch of strange bugs. Racrom 11 fixed quite a few. But racrom 9.1 seems reliable but lacks some of the advanced features of 10/11 like closed loop fueling and intergrated flex.
But might be worth trting to get tune using racerom 9.1 if you think everything mechanical is ok
Transient Fueling ~ DI/PI Kodename47 Software Tuning 2 07-17-2015 07:27 AM
Rotrex vs Turbo (AVO) for Track use (transient response, IATs, heat management, etc) glamcem Forced Induction 56 08-25-2014 07:07 PM
Transient ignition and knock count brn12345 Software Tuning 19 06-11-2014 12:46 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 08:48 AM
Rich man's FR-S (WRB BRZ) Hamza7 Cleaning and Detailing 9 06-24-2012 12:36 PM
