Old 10-11-2019, 01:39 PM   #1
thornad
Drives: 2016 GT86 N/A
Reverse lockout ring pin is missing, but acting like it is there.
My reverse lockout ring pin is missing, I can shine a light through the hole with a flashlight or put a very thin screwdriver through the hole, the pin is not there. Nevertheless, I cannot remove the lockout and the whole thing behaves like the pin is there.
I only noticed this because I was trying to remove the lockout to put some Teflon tape on the shaft to stop the rattling.
Any ideas what is going on and how to remove he lockout ?
thornad is offline   Reply With Quote
Old 10-11-2019, 03:07 PM   #2
MX-5RACER
Drives: 1999 Miata
Keep in mind the pin is a roll pin (also known as a spring pin), which is spring steel that is not a complete pin. There is a split on one side and a hole in the middle. You compress the pin to keep tension on the joint and keep the pin in place.
DJ
1999 Miata VVT swap "Maggie"
2013 BRZ "Nancy-Drew BRZ"
MX-5RACER is offline   Reply With Quote
The Following User Says Thank You to MX-5RACER For This Useful Post:
thornad (10-11-2019)
Old 10-11-2019, 03:24 PM   #3
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Yep. Use a 3/32" roll pin punch (has a small bearing on the end).
It is best to use an actual punch. If you try and knock it out with something that is close in size but not quite right you might flare the pin and then you have to drill it out. I bought a cheap one on amazon and it did just fine.
wolffbite is offline   Reply With Quote
The Following User Says Thank You to wolffbite For This Useful Post:
Old 10-11-2019, 03:31 PM   #4
StraightOuttaCanadaEh
Wes
^ this
having the exact sized punch is the difference between getting the pin out in a few seconds (literally) vs huffing and puffing and getting nowhere for half an hour
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Old 10-11-2019, 03:49 PM   #5
I use a 3 mm socket head cap screw to drive it out. They're a common hobby store item. Screws right into the plastic. Easy peezy & no trauma.
Old 10-11-2019, 04:15 PM   #6
thornad
This makes sense. Mystery solved. Thank you.
Old 10-11-2019, 05:01 PM   #7
thornad
Brilliant! It did the trick.
Old 10-11-2019, 10:45 PM   #8
reverse lockout, shift knob
Where can I find a reverse lockout pin for the stock lockout? tracerit Cosmetic Modification (Interior/Exterior/Lighting) 0 05-15-2019 04:41 AM
Perrin Reverse Lockout Ring Installation and Review! Sony Engine, Exhaust, Transmission 21 07-17-2018 07:19 PM
Missing Hub-Centric Ring Apex_BRZ Tracking / Autocross / HPDE / Drifting 7 04-28-2015 02:40 AM
Reverse lockout? MrMarinakos Cosmetic Modification (Interior/Exterior/Lighting) 0 04-28-2014 09:47 PM
Aftermarket Reverse Lockout Ring Available? was385 Cosmetic Modification (Interior/Exterior/Lighting) 9 02-17-2013 03:28 PM
