Old 10-10-2019, 01:09 PM   #1
xdavidx
Emperor McDuck
xdavidx's Avatar
Drives: 2019 86 GT; 2018 BMW S1000RR
Unusual Tire Wear - Test
Just got my 86 serviced and the dealer noted with confusion that my front tires were significantly more worn than my rear. They had not been rotated. Who knows why?
Instagram: @s1kmotodragon
YouTube: S1KMotoDragon
xdavidx is offline   Reply With Quote
Old 10-10-2019, 01:16 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Rear tires get changed much more frequently than the fronts ,and you have scrubbing from toe out for turn on response?
This is my final answer. Definitely am expecting increased wear from autocross usage - I know my fronts get hammered quick compared to the rears
Old 10-10-2019, 01:21 PM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Your alignment is off?
I LIKE TIRES!
Old 10-10-2019, 01:24 PM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
I suspect track or autoX use + possibly sub-optimal setup.
My car wears fronts WAY more quickly than rears at the track. But my setup is not optimal... Bottoming on cut-down front bump stops results in heavily loading the outside front in corners. Lost a ton of front bump travel due to camber plates and -1.25" ride height with springs...
Old 10-10-2019, 03:07 PM   #5
TunaNoCrust
TunaNoCrust's Avatar
Drives: 86, 981S, RX8, 2500HD, GenesisV8
I think I know why
PS, I am bringing the Motive Bleeder cap from my Porsche up to NHMS if you didn't get one already.
TunaNoCrust is offline   Reply With Quote
Old 10-10-2019, 03:21 PM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by TunaNoCrust View Post
I think I know why
Thanks man, I got it yestiddy but haven't trial-fitted it yet...
Old 10-10-2019, 03:21 PM   #7
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I too fail to achieve 'slow in, fast out' far too often.
ineedyourdiddly
Old 10-10-2019, 03:29 PM   #8
xdavidx
Emperor McDuck
xdavidx's Avatar
Correct! No power and understeer (no front camber adjustment), the fronts get lots of abuse and the rears get very little.
I found it kind of funny that the service techs didn't recognize why.. I mean my RE-71rs look like I put a blow torch to them they are so melted... Can't imagine I am the only 86 that comes in this way.
Old 10-10-2019, 03:42 PM   #9
Leonardo
Country Boy 4 Life
Leonardo's Avatar
For what those tires cost, wouldn't a set of camber bolts be a no-brainer? Or are class regulations keeping you from modifying your suspension?
I LIKE TIRES!
Old 10-10-2019, 03:46 PM   #10
xdavidx
Emperor McDuck
xdavidx's Avatar
I have a set of camber bolts in the glove box.... Doesn't seem to help
The Following 2 Users Say Thank You to xdavidx For This Useful Post:
churchx (10-10-2019), Leonardo (10-10-2019)
Old 10-10-2019, 04:00 PM   #11
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Cool! I have tried camber bolts in the bottom hole, top hole, and both holes on the strut; I haven't tried them in the glove box.
How much camber do you get from them in that location?
I LIKE TIRES!
Old 10-10-2019, 04:09 PM   #12
strat61caster
The upside to swapping between DD and autox tires - every event gets a rotation.
I'm still wearing the fronts faster with -4° but that's a nut behind the wheel problem... well at least my setup changes haven't moved the needle a bunch yet.
ineedyourdiddly
Old 10-10-2019, 05:32 PM   #13
ZDan
ZDan's Avatar
Drives: '23 BRZ
Not to mention 55/45 weight distribution! Doesn't seem that terrible until you realize that the fronts carry ~20% more weight than the rears do There should be a cab-rearward 2-seat version of this car, with rear wheels shoved about 10"-12" forward for 50/50 distribution!
Old 10-10-2019, 07:49 PM   #14
xdavidx
Emperor McDuck
xdavidx's Avatar
I only get about -0.0000000000000000000000001 due to a slightly lower ride height from the added weight.
Have noticed a strange rattling noise coming from the glove box though ever since I put them in. Super easy install though.
The Following User Says Thank You to xdavidx For This Useful Post:
How does my tire wear look? R_E_L Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 09-08-2018 07:34 AM
tire wear oppiee Tracking / Autocross / HPDE / Drifting 9 08-29-2017 12:55 PM
Tire Wear? Flo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-10-2017 03:19 PM
Tire Wear Help babykwiss Tracking / Autocross / HPDE / Drifting 10 07-14-2014 11:31 AM
Unusual tyre wear? (pics included) jourdanc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 05-09-2014 06:34 AM
