Old 10-05-2019, 12:16 PM   #1
pacaveli420
Drives: Badass
Heated Seats Temp Range
I thought I had previously found some concrete info showing that Subaru swapped to warmer heated seats after the 2013 models. Does anyone have any info to corroborate this for the BRZ seats? There are plenty of threads talking about people being unhappy with how warm they get (and then other people saying they're fine). I would like to have some seats that get a bit warmer.
This is a quote from the 2013 TechTips
Subaru vehicles 2013MY and prior equipped with seat heaters generally have an operating range of
86 degrees F to 104 degrees F. See the March, 2003 issue of TechTlPS for information on older style
seat heaters. The 2014 Forester seat heaters have a different operating range. The 2014 Forester seat
heaters come on at 98.6 degrees F. and shut down at 109.4 Degrees
https://static.nhtsa.gov/odi/tsbs/20...67052-3639.pdf
pacaveli420 is offline   Reply With Quote
Old 10-05-2019, 09:45 PM   #2
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
first time I've ever seen an actual temperature range for any heated seat. Usually the issue is more about where they actually heat vs actual temperature.
why? is offline   Reply With Quote
Old 10-05-2019, 11:48 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
i've been waiting for the seats to get cheap enough that i can get a heated seat to take apart so i can figure out how to make mine actually heat up better, and put them back together.
i've got a heated seat cover that i put in the pickup truck for the winter, it works twice as well as the car. i just need to even out the fleet and make them work the same!
Old 10-06-2019, 04:27 PM   #4
daskaman
Drives: Burz
Japanese cars in my experience have seat "warmers" while European cars have butt "toasters" with more levels of adjustability from warm to ass on fire.
daskaman is offline   Reply With Quote
Old 10-06-2019, 06:45 PM   #5
pacaveli420
Drives: Badass
I'd prefer mine to stay a bit warmer. I know I've been in cars that have had a warmer seat. I can leave mine on either setting and never really find myself thinking they've gotten too hot (at least not on an actual cold day). Rather, as the high cycles through it's more like "is it still on?"
Old 10-06-2019, 07:54 PM   #6
soundman98
soundman98's Avatar
if the windows are down, the air circulation is enough to make them hot. i keep meaning to add fans underneath to make them do it all the time.
Old 10-07-2019, 09:33 AM   #7
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
My problem is not the temp of the seats but the duration they stay on.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following User Says Thank You to 8RZ For This Useful Post:
soundman98 (10-07-2019)
OEM heated seats in aftermarket seats Jive Turkey Cosmetic Modification (Interior/Exterior/Lighting) 6 06-09-2024 01:31 PM
DIY – OEM Heated Seats @Art_Mighty DIY (Do-It-Yourself) Guides 22 12-30-2020 06:38 AM
Heated seats gpvecchi Cosmetic Modification (Interior/Exterior/Lighting) 3 04-15-2018 10:02 PM
Ideal engine oil operating temp range SirBrass Engine, Exhaust, Transmission 36 05-31-2016 04:22 PM
How Do I get FR-S Heated Seats? 914_WHITE_FRS Cosmetic Modification (Interior/Exterior/Lighting) 5 03-01-2014 08:45 PM
