Old 09-28-2019, 10:35 AM   #15
Grady
Grady's Avatar
What flywheel do you have? Also try turning off the A/C when it rattles to see if that fixes it.
Old 10-04-2019, 09:36 AM   #16
msaikhan
Drives: frs
stock flywheel, i also feel like the noise is more consistent when ac is on.
msaikhan is offline   Reply With Quote
Old 10-04-2019, 11:38 AM   #17
Grady
Grady's Avatar
Transmission harmonic rattle probably normal. I have a light weight flywheel and it sounds like the engine is coming apart at times.
Old 12-04-2021, 01:41 AM   #18
BleedingRust
Drives: BRZ S
You ever figured out what it is? I notice it only happens when cold. After awhile it goes away.
BleedingRust is offline   Reply With Quote
Old 05-24-2022, 03:11 PM   #19
jrhudson
Drives: 2016 scion frs
Freaky. I've heard of times when one of the retaining clips has fallen out after TOB service. If you pull the clutch fork forward and try to twist it back and forth before the pushrod comes back out, does it feel nice and tight? It should not wiggle.
This is an old thread but, did you mean it shouldnt have this amount of wiggle? I can wiggle the clutch fork side-to-side. Terrible rattle but when i press in the clutch it goes away.
jrhudson is offline   Reply With Quote
Old 05-24-2022, 03:38 PM   #20
That bit of sideward play is fine. Is that your transmission knocking in the second clip? Does it go away when you tap the clutch pedal a bit, or do you have to completely disengage?
Old 05-24-2022, 04:16 PM   #21
jrhudson
Yes, i think my transmission is rattling/knocking and it only goes away when i fully press in the clutch
https://youtube.com/shorts/aRhbkgfNqf8?feature=share
Old 05-24-2022, 05:00 PM   #22
That's your throwout bearing for sure. See how it goes away as soon as you start pressing the pedal. Just start pushing slowly.
Old 05-24-2022, 05:34 PM   #23
jrhudson
Ahh poo. The noise is becomes really bad when the ac clutch kicks on. Maybe thats what i get for using a not brand new TOB. I know the TOB installed was around 10k miles old, it was the updated(white dot) one. Welp, trans getting pulled again. 😭
Old 05-24-2022, 05:44 PM   #24
Now hang on. Did you confirm by just pushing the clutch pedal partially? Post a video of you pushing it only a third of the way down, just some so there's pressure on the TOB but the transmission keeps spinning.
jrhudson (05-25-2022)
Old 05-25-2022, 02:06 AM   #25
jrhudson
I havent yet but the motor was already being pulled in a few weeks. Ill do the video when i have a chance.
i forgot to mention, i think my TOB is loose or the clips are loose or off. I reused some old ones like 55k miles old clips but i bent them to shape. maybe stressed them out too much?
Old 05-25-2022, 02:30 PM   #26
jrhudson
Hmm, yea only when the clutch is fully depressed the noise completely disappears. @Ultramaroon
Old 05-25-2022, 03:04 PM   #27
I take back the TOB call. Does the transmission whine when driving? That's a pretty loud rattle.
Old 05-25-2022, 03:41 PM   #28
jrhudson
It might be the TOB still since the car is warmed up and i dont really hear it and/or its not as bad. I suspect it the retainer clips, its probably barely holding onto the TOB. I only drove around for a short time but there wasn’t any whining or weird noises.
Transmission Noise in Neutral @ Cold Start Jackal84 Issues | Warranty | Recalls / TSB 57 03-01-2021 04:21 PM
FRS Rattle when clutch engaged in neutral savioita Issues | Warranty | Recalls / TSB 20 11-26-2017 05:00 AM
cluck cluck clutch rattle in neutral to engagement??? Packofcrows Issues | Warranty | Recalls / TSB 32 11-15-2015 12:28 AM
Car rattle at neutral. IloveBaldEagles Issues | Warranty | Recalls / TSB 3 12-23-2012 07:55 PM
Weird rattle when put into neutral SleekMachine Issues | Warranty | Recalls / TSB 1 10-18-2012 11:25 AM
