Old 10-01-2019, 05:40 PM   #1
Inteze
Drives: Toyota GT86
Clicking noise while Driving stops when Clutch is pressed
Hello,
I have searched the forum but didn’t seem to find a solution.
I have noticed that, while I am driving, I get this moderate loud “Clicking” Noise coming from the front left wheel, watch the video, i’ve put the link down there. It happens often while applying load to that side (while turning right, downshifting) and it “stops” as soon as I press the Clutch Pedal. It doesn’t happen all the time but very often.
Also while breaking nothing happens, it only goes away once I pressed the Clutch pedal down. Once I release it, it comes back.
VIDEO :
Can please somebody help me?
Thank you very much
Inteze is offline   Reply With Quote
Old 10-01-2019, 11:17 PM   #2
Originally Posted by Inteze View Post
Hello,
VIDEO :
Thank you very much
Hello Inteze and welcome to the forum -
Your video doesn't help me.
What year is your car? How many miles on your car?
You may have two things working there.
The sound from the front end sounds like a wheel bearing may be going bad.
The other sound you hear when activating the clutch sounds like it may be a TOB going bad.
Old 10-01-2019, 11:31 PM   #3
Lantanafrs2
Drives: 2013 frs red
Once again the radio is your best friend. This car has noises that come and go. No rhyme or reason. Just moving parts and a cost effective interior
Lantanafrs2 is offline   Reply With Quote
Old 10-02-2019, 07:53 AM   #4
Inteze
Drives: Toyota GT86
Hello,
Year : 2013
KM : 52.000
The wheel bearing has been changed like 2000km ago, so don’t know what it could be
Old 10-02-2019, 07:54 AM   #5
Inteze
Drives: Toyota GT86
It comes while I turn slightly to the right, and stops as soon as I press the Clutch pedal. Restarts once I release it
Old 10-02-2019, 11:20 AM   #6
Was your car under the valve spring recall? If so, have you had that work done?
As far as the noise in the front, I would suggest that you take off the front wheel and inspect the wheel bearings and brake parts.
The clutch noise could very well be a bad TOB (Throw Out Bearing).
Has the TOB ever been replaced?
Old 10-03-2019, 07:23 PM   #7
Inteze
Drives: Toyota GT86
I think the TOB not.
Yes I have to go to the Toyota dealer to do the Valvespring fix.
And the wheel bearing has been changed
Thank you though
Old 11-18-2019, 06:03 AM   #8
Inteze
Drives: Toyota GT86
Other suggestions?
It’s so annoying ... and happens only while i turn slightly to the right.
Once i release the clutch it ticks quickly 3 times and stops
Old 11-19-2019, 02:12 AM   #9
alan.chalkley
Drives: 4wd zooks
Loose mounting bolts clutch to flywheel or loose flywheel mounting bolts?
alan.chalkley is offline   Reply With Quote
Old 11-22-2019, 05:01 PM   #10
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
If it goes away when the clutch is pressed then it could be where the slave cylinder connects to the clutch fork. Checked to see if it's properly lubricated. If it looks dusty or dry, squeeze a whole bunch of waterproof grease (or Honda lube) at the point they connect and press your clutch in and out several times. See if that helps.
MJones_RB is offline   Reply With Quote
Old 11-25-2019, 06:02 PM   #11
Inteze
Drives: Toyota GT86
Alright ill check thanks
Old 11-25-2019, 06:05 PM   #12
Inteze
Drives: Toyota GT86
Also it is 100% audible from the outside (noise coming from outside of the cabine) and it is on the driver side near the front wheel
Old 04-09-2020, 01:07 PM   #13
Inteze
Drives: Toyota GT86
Broken CV Joint, axle had to be replaced
Clicking noise from clutch when depressed/released? BaeK Issues | Warranty | Recalls / TSB 30 02-05-2025 05:20 PM
Clutch Pedal "Clicking" Noise on new BRZ Shizuka Engine, Exhaust, Transmission 6 05-31-2019 01:57 PM
What is this OTHER clicking noise? radroach Issues | Warranty | Recalls / TSB 0 02-16-2019 01:10 PM
Wilwood BBK Clicking Noise AlexK Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-24-2016 07:38 PM
Clicking / tapping sound + fuel pump noise + clutch grinding Mikeez Issues | Warranty | Recalls / TSB 11 04-26-2015 11:19 PM
