Old 09-28-2019, 02:44 AM   #29
blown
Drives: ft86
are the semi active ones out for other cars?
blown is offline   Reply With Quote
Old 09-28-2019, 03:19 AM   #30
949 Racing
FT86Club Official Vendor
949 Racing's Avatar
Drives: Miata, GT350, FR-S
Yes. 90-05 and 2016-2019 Miata, Mustang GT350/R
Working on Mustang S550 GT, EcoBoost and 86 platform.
My 2019 Miata daily driver has ACE and the touchscreen controller.
949 Racing is offline   Reply With Quote
Old 09-29-2019, 02:11 AM   #31
blown
Drives: ft86
the semi active is more for the street?
Old 09-29-2019, 09:35 AM   #32
949 Racing
949 Racing's Avatar
Ace are for whatever you want them for.
Old 09-30-2019, 01:19 PM   #33
turbofan
949Racing Support
turbofan's Avatar
Drives: 1999 Mazda Miata Turbo
The standard Xida options do a far better-than-average job of working across a wide range of scenarios. With stiff spring rates they ride better than you'd expect, and with soft rates they still handle better than you'd expect.
Ace takes that versatility to 11.
Ed @ 949Racing
949Racing
Supermiata
EMAIL US at info@949racing.com
turbofan is offline   Reply With Quote
The Following User Says Thank You to turbofan For This Useful Post:
wparsons (10-01-2019)
Old 09-30-2019, 02:58 PM   #34
949 Racing
949 Racing's Avatar
Successful test at Sonoma this weekend. Temps were good but high winds kept us from going under 1:50 on street tires. Finally saw the right temperature gradients across the tire with the prototype strut flanges. At race ride height, with camber plate and highest offset camber chips installed, it's possible to crank in -6° camber up front. From past experience and pyrometer data, we started at -4° and that ended up being pretty close. Before this event, we had been limited to -1.7° on LF and I think -2.8° on the right side. As a result, we had been frying the outside shoulders of the front tires and never getting full grip from the tires. That's sorted now.
For pure competition use, most 86's on 255's will want between -3.5 and -5° depending on the spring rates, surface and tire being used. Ideal camber is dialed in by getting pyrometer reading, looking at lap data and driver feedback. On track or autocross, the tires wear evenly at those camber settings. On a daily driver though, that much camber makes the car tramline (follow pavement grooves) and wears the inside edges of the front tires. It's up to each driver to decide if they want a full highway friendly camber setting closer to -.5° , full race camber above -3.5° or a compromise in between. For dual duty cars that see some occasional track/autocross use, mostly canyon on the weekends and very little highway use, a setting between -1.5° and -2.5° might be a decent compromise.
The more straight line highway driving you do, the more you want the front tires around -.5°. The more hard cornering you do, the more camber you want. When the car is turning hard, body rolling a few degrees, the higher camber setting keeps the tire flatter for increased grip and also results in better wear.. but only if the car spends almost all its tire life cornering hard.
On our Mustang GT350 (also front struts like 86) with slightly lowered suspension and 305/30/19's, we ran -4.5° up front. That car was perfect on track.
So anyway, track testing successful, no problems encountered. We go into production in a week or two. Our custom springs will take a bit longer to produce so our best guess on when we can start shipping to customers is perhaps 2nd week December. We will make an announcement here and also an email blast to our mailing list when the site is open for pre-orders. Pricing should be finalized in a few weeks. We are really stoked to be wrapping up the R&D process and getting these launched.
The Following 9 Users Say Thank You to 949 Racing For This Useful Post:
churchx (09-30-2019), Code Monkey (10-01-2019), DAEMANO (10-03-2019), Icecreamtruk (10-02-2019), PulsarBeeerz (10-01-2019), RayRay88 (09-30-2019), strat61caster (09-30-2019), turbofan (09-30-2019), wparsons (10-01-2019)
Old 10-01-2019, 07:08 PM   #35
AngelGT86Racer
AngelGT86Racer's Avatar
Drives: 2013 FR-S, 2007 Acura TL 5AT
Originally Posted by venturaII View Post
Actually, I didn't consider the body being smaller than OEM...was just struck by the piston to body ratio in the picture and assumed it was huge...lol
EDIT: there's probably a joke in there about how pictures can make stuff look bigger than real life...
I'm fairly certain all Tractive shocks use a 46mm piston and a shaft diameter of 16mm. For comparison, Bilstein use a 46mm piston for their SLA shocks and I believe(don't quote me on this) a 37mm piston for their inverted struts with 14mm shafts.
2013 FR-S Raven, AutoX/Track/Daily Driver
Build: Angel's Dual Duty FR-S Build
YouTube: Angel Christov
AngelGT86Racer is offline   Reply With Quote
Old 10-02-2019, 01:31 AM   #36
AngelGT86Racer
So it's sounding like the camber chips will give us the ability to run close to -3* static without the use of camber plates?
I'm currently using RaceSeng plates on a stock shock/spring setup and I get about -3* with those maxed out. But I have issues with spring perch/inner fender clearance as well as endlink clearance. My hope is to be able to get pretty close to -3* and return to factory upper mounts for better NVH. I've also recently added adjustable control arms in the front if I need a nudge more to get the static camber I want. I'd rather get most of it through the strut flange, so as to not push the bottom of the tire too far past the path of the front bumper for drag reasons.
Old 10-02-2019, 11:52 AM   #37
949 Racing
949 Racing's Avatar
Yup.
The Following 2 Users Say Thank You to 949 Racing For This Useful Post:
AngelGT86Racer (10-02-2019), wparsons (10-03-2019)
Old 10-04-2019, 12:23 PM   #38
949 Racing
949 Racing's Avatar
86 Xida Pricing Announced
Tentative pricing posted on our site now. http://949racing.com/xida-coilover-86.aspx
I emphasize that this pricing is tentative. It may change before we begin accepting pre-orders but we're pretty confident it will stay in that range. We plan to start accepting pre-orders in November for December shipment.
It's important to note that most owners will not need camber plates to reach -3° camber up front. If you have camber plates already, you probably won't need them. If you don't have camber plates, you don't need to budget for them. The adjustment range with included camber chips should be around -.5° through around -3.5° depending on ride height. So factor in any budgeting that you will simply re-use your OEM top mounts front and rear.
Code Monkey (10-04-2019), NoHaveMSG (10-04-2019)
Old 10-04-2019, 12:52 PM   #39
churchx
churchx's Avatar
Drives: 2014 GT86
Love the insert bit, would love to see such more widespread among aftermarket suspension makers. Hate the bit that you guys are on other side of pond. By chance, do you have some reseller shop on EU side to make shipping/import/servicing simpler?
churchx is online now   Reply With Quote
Old 10-04-2019, 01:10 PM   #40
949 Racing
949 Racing's Avatar
No EU dealers, sorry. Any Tractive distributor can service but only we have the Xida.
Old 10-04-2019, 01:26 PM   #41
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I'm sure it's posted elsewhere but who is your spring supplier?
ineedyourdiddly
Old 10-04-2019, 01:40 PM   #42
turbofan
949Racing Support
turbofan's Avatar
Spring supplier is proprietary. Hyperco springs will be available at additional cost.
Ed @ 949Racing
949Racing
Supermiata
strat61caster (10-04-2019)
949 racing, blub, xida
BC Racing Coilovers, Tax Season Specials! WE stock BC Racing @OAKOS! OAKOS Automotive Brakes, Suspension, Chassis 162 04-17-2017 03:14 PM
*** Feal Suspension, Megan Racing, BC Racing, KSport, ISIS Coilovers - ON SALE!!! *** Sonic Motor Brakes, Suspension, Chassis 489 07-29-2016 02:15 PM
WTB: Ksport Control Pro Coilovers or BC Racing Extreme Low Coilovers ProjectBrz Brakes, Suspension, Chassis 1 04-15-2014 12:21 AM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 08:56 PM
