Old 10-01-2019, 05:27 PM   #2437
Cookiemonster
Cookiemonster's Avatar
Drives: '17 BRZ M6 & '17 Corvette Z06 M7
Originally Posted by HachirocksU View Post
Since you are going 2JZ,..
Forgeline GS1R
18x10
Sorry should have mentioned budget...90% of my budget is going into the swap itself, so a set of wheels costing 4K+ are out of the question.
Cookiemonster is offline   Reply With Quote
Old 10-02-2019, 09:36 AM   #2438
Leonardo
Country Boy 4 Life
Leonardo's Avatar
These are 18x10 5x100 +38 RPF1
https://www.ebay.com/itm/Enkei-RPF1-...IAAOSwe9VcRmuJ
I also really like these Forged 527F XXR 18x10 +40
https://www.ebay.com/itm/XXR-527F-18...ry!97404!US!-1
I LIKE TIRES!
Old 10-02-2019, 05:40 PM   #2439
Cookiemonster
Thanks, those are some good options...totally forgot about teh ebehyyy.
Would like to know, though, for a 9.5" wheel...is 285 too wide for say, Ventus RS-4's or Michelin SS? Don't want too soft of a sidewall bc tire is too wide for the rim..but at the same time, would love to have as much contact patch as I can get.
Guess in the meantime I'll jump on ebay to look at more 18x10"ers
The Following User Says Thank You to Cookiemonster For This Useful Post:
Leonardo (10-02-2019)
Old 10-02-2019, 06:16 PM   #2440
Leonardo
Country Boy 4 Life
Leonardo's Avatar
You're welcome!
RS-4's are not available in a 285/30/18. I would suggest a 265/35/18 RS-4, for a 18x9.5 or 18x10 wheel. A 265/35 RS-4 has a tread width of 9.8". Tire compound has more to do with traction than contact patch.
I think you will need: LCA, swaybars, endlinks, toe arms, coilovers, camber plates (if the coils don't have them), and possibly trailing arms. I would also suggest a bumpsteer kit. Additionally, to get max grip, you will want -3.0 or more front camber, and somewhere around -2.4 rear camber.
The suspension you choose will effect how well you can use your contact patch. It will have to be quite a bit stiffer that OEM.
Seriously, with how much an engine swap costs. I would suggest building the "heart" of your car first and then buy it new shoes.
Good Luck!
I LIKE TIRES!
Cookiemonster (10-03-2019)
Old 10-11-2019, 06:58 AM   #2441
Jdmuscle
Drives: Supra, Viper, Z06, GT350 and GX460
Seeking expert advice here..
19 PP BRZ... just bought Tein Flex Z coilovers and Titan7 T-S5 wheels (18x9.5 +40 offset). Planning to get 255/35s all around. Do you guys think it’s an absolute necessity that I get adjustable rear LCA etc? Would leaving the stock setup in place work with the wheel/tire combo?
IG: @vipraz 94 Supra Turbo // 15 Viper GT // 16 Corvette Z06 // 18 Shelby GT350 // 19 BRZ LTD // 18 GX460 Premium // 13 Vrod Muscle
Jdmuscle is offline   Reply With Quote
Old 10-11-2019, 07:55 AM   #2442
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The rear LCA are for adjustability when you drop the car. If you don't lower the car much, the need for rear LCA is not there. But if you bought such huge wheels and coilovers as your first mods, I'm anticipating you're going to be lowering the car, so I'd bite the bullet and get them. Easier to swallow the pill now then after you pay for an alignment and they can't do anything because of your stock LCA.
Old 10-11-2019, 10:27 PM   #2443
Jdmuscle
Thanks ... Ended up getting the adjustable LCA and the toe arms. Might as well just do the alignment once and be done.
What alignment specs do y’all recommend? Mainly for street use.
Old 10-12-2019, 04:04 AM   #2444
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
0 Toe Front, Slight Toe in rear, -3 degree front and -2 degree rear
The Following User Says Thank You to N1rve For This Useful Post:
Jdmuscle (10-16-2019)
Old 10-16-2019, 01:08 PM   #2445
Daedex
That One Guy
Daedex's Avatar
Drives: White 2017 BRZ
I see you stated you needed those suspension parts to have this tire and wheel setup. Would this tire hit the stock suspension? Is that why u needed coilovers?
Yeah it would definitely hit the stock suspension. you for sure need coils.
you will definitely need LCA's if you want to adjust the rear camber and toe.
"I am not bound to win, but I am bound to be true."
Daedex is offline   Reply With Quote
The Following User Says Thank You to Daedex For This Useful Post:
Old 10-16-2019, 07:30 PM   #2446
Jdmuscle
Yes sir.. got them all!!
1) Tein Flex Z
2) SPC LCA
3) SPC toe arms
Old 10-23-2019, 10:13 PM   #2447
scottbmonroe
Drives: 01 Chevy Silverado 1500 5.3L engine
Where is the speedometer odometer sensor on a 05 Toyota Tundra 4.7 automatic transmission
Sent from my SM-J737P using Tapatalk
scottbmonroe is offline   Reply With Quote
Old 10-23-2019, 11:52 PM   #2448
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Will BRZ is offline   Reply With Quote
Old 10-24-2019, 02:22 AM   #2449
86MLR
86MLR's Avatar
Camber setting are gained by working out a few things.
Street settings according to me, so take with a grain of salt.
Tyre compounds and pressures, different tyres take different camber and pressure settings (is the car in fact using the tyre, soft compound/hard compound/cold tyres/warm tyres/hot tyres)
For the street a alignment settings will be comprised to a point, do you want long tyre wear, to you want handling more than caring about tyre wear? A bit of in between by adjusting your toe settings?
Currently, my settings are -2.0° front and -1.5 rear, zero toe everywhere.
Tyres are Bridgestone RE003 235/45 17 on a 8" rim, running 34 psi, tyres are wearing evenly.
Car handles extremely well (also running MCA Street Performance coil overs, 6kg front, 4.5kg rear, also with the MCA Traction mod)
A more aggressive set up would work better for when I hit the twisties, but that only happens about monthly.
A aggressive setup for a daily can and does reduce tyre life, and, more importantly, braking.
My recommendation is to set a moderate setting and drive around for a few weeks, then look at your tyres, where are they wearing.
Q: are you running up over the shoulder? A: not enough camber.
Q: Are your not getting to the edge of the tyre? A: to much camber.
For a dedicated street car I would be doing this with zero toe everywhere to maximize tyre life.
99% of the time, a well thought out tested setting will smoke an aggressive setting.
Opinions may vary.
Have fun.
The Following User Says Thank You to 86MLR For This Useful Post:
Jdmuscle (10-24-2019)
Old 10-24-2019, 02:39 AM   #2450
churchx
churchx's Avatar
Drives: 2014 GT86
Zero toe everywhere is not exactly best choice. There is reason why some rear toe-in is there even in OE alignment. Slight toe-in doesn't wear tires excessive and is acceptable trade-off for more stable, less nervous rear, so that one can baby throttle less accelerating out of turns and has to fight less to keep car straight in lacking grip conditions, eg. when wet or in winter. Hence the reason, why some toe-in there is advised for most RWD cars, and not just for tracked ones.
86TOYO2k17 (10-24-2019)
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
