Old 09-30-2019, 04:52 PM   #1
Hybrid707
Drives: 2015 FR-S
OFT spark cut for LC to shoot flames and at rev limiter to not lose power drifting
Hello, as the title says I was wondering if there was any way to change the rev limiters to spark cuts instead of fuel cuts so I can A. Possibly shoot a flame with launch control and B. Not feel like I hit a brick wall when hitting rev limiter while drifting?
Hybrid707 is offline   Reply With Quote
Old 09-30-2019, 06:29 PM   #2
steve99
Drives: FT86
Fuel cut rev limiting is coeded into ecu, even with ecutek is not changeavle to spark cut.
Most modern ecu use fuel cut as its vetter for emmissiobs than fuel cut.
You can however use ignition retard to limit rpm to achieve a soft rev limiter prior to the fuel cut. Its also possible to lift the fuel cut to a higher rpm. Neither will acgive flames at rev limit though
But you can achive a limiter that you can jist drive at without harsh fuel cut
Old 10-01-2019, 04:52 PM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
FYou can however use ignition retard to limit rpm to achieve a soft rev limiter prior to the fuel cut. Its also possible to lift the fuel cut to a higher rpm.
I'm fairly sure you could mimic an ignition cut by running a very sudden ignition retard at the limit rather than the gradual soft ignition retard limiter you're on about.
Just set it to 25-50 RPM from full advance to full retard and see what happens Probably worth cutting some fuel out at the same time mind.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-01-2019, 05:04 PM   #4
ls1ac
ls1ac's Avatar
Wait a moment, you want to turn off the engine (either by fuel or ignition ) and not loose power??
Old 10-01-2019, 06:00 PM   #5
steve99
Drives: FT86
My current ignition retard limiter goes from full advance to -30 in 100 rpm, limits powe\rpmr but zero pops or bangs or flanes.
Old 10-02-2019, 05:09 AM   #6
tomm.brz
Drives: brz 2017 hksv2
Mine is more extreme like kodename said, - 35 of retard with a hysteresis of 30rpm
It just bounce back and fourth very quickly while at limiter but no appreciable pops
But i also have the fuel cut... What happens if we do not apply the fuel cut but only the ignition cut?
Old 10-05-2019, 05:38 PM   #7
erebuswarrior
Drives: 2015 Asphalt BRZ
From my testing nothing happens. I've tried leaving fuel cut rev limit at 7600 and hitting max retard just before it at 7500 and even as early as 7000, nothing. It skips right past it to the fuel cut rev limit. I think there's more then just the base map influence top end timing. I believe when I logged, it would hit -20 total timing before the fuel cut rev limit, and still pass up the full retard at 7k and start rev limiting at 7600. I haven't played around with it in awhile, but turning off fuel cut is risking engine damage unless we can get retarded timing to actually rev limit. Actually, I wonder if setting hysteresis to 0 or 1 and -20 (or more) retard, this should make fuel resume immediately as rev limit hysteresis is how many RPM's it must drop before resuming fuel injection. I wonder if that would risk engine damage though, because it could cause over revving maybe? Although it looks like rev limit fuel cut resume is managed by manifold pressure, I don't see a rev limit hysteresis for the main rev limiter. LC and FFS have hysteresis though. Gonna set that to 1 and see what happens.
erebuswarrior is offline   Reply With Quote
Old 10-05-2019, 06:57 PM   #8
Kodename47
Kodename47's Avatar
Drives: UK GT86
@erebuswarrior are you editing the correct ignition timing table?
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-06-2019, 05:25 PM   #9
erebuswarrior
Ignition Base Map VVT On? Here's my results from trying the below. It actually starts basically rev limiting and wouldn't go past 7k, but no pops. Looks like -30 isn't enough.
https://datazap.me/u/naroean/log-157...g=0&data=14-20
Old 10-07-2019, 07:57 AM   #10
gt7877
Drives: turbo frs
gt7877 is offline   Reply With Quote
Old 10-07-2019, 08:00 AM   #11
solidsnake11
Drives: brz
That should make your header a bright orange in a short period of time.
solidsnake11 is offline   Reply With Quote
Bee*R Rev Limiter Power Module 25th Anniversary Phoenix_gts86 Electronics | Audio | NAV | Infotainment 2 06-26-2019 10:36 AM
How much power to gain/lose? Timmy_Jones Engine, Exhaust, Transmission 40 04-08-2016 05:42 PM
I want to shoot flames from my exhaust. EZWood Engine, Exhaust, Transmission 77 08-28-2015 05:27 PM
Subaru Impreza WRX STi with Blitz Nur Spec R exhaust power sliding drifting @ wet Cur radroach Other Vehicles & General Automotive Discussions 0 07-05-2013 08:45 PM
San Francisco sunset shoot - another shoot with another set of wheels WheelDude.com BRZ Photos, Videos, Wallpapers, Gallery Forum 3 04-12-2013 03:35 PM
