Old 05-01-2019, 07:59 PM   #1
Phoenix_gts86
Phoenix_gts86's Avatar
Drives: 2013 MY14 Toyota gts86 Turbo
Bee*R Rev Limiter Power Module 25th Anniversary
Hey guys 1st post on the forum so let’s make it a good one��
I own a Turbocharged 2013 Toyota GTS86
I’m here to talk about my Bee*R Rev Limiter Power Module 25th Anniversary
I’m fishing around for either one of these or all of these:
Auto lecky
Who has installed a bee*R
Who knows about Bee*R
Professional knowledge about 2013 gts86 wiring
I’m having issues with my Bee*R Unit:
The only dramas is that it’s not cutting ignition properly like it should,
It stops at the 2nd rev limiter, fuel continues to come out, but there are no bangs atleast like there should be, yes my system is hot at the time.
I had it setup differently before where it did work but to get it to work you had to try and once it worked the car wouldn’t run to its full capacity and as usual the CEL came on because the ecu isn’t programmed to perform with the Bee*R.
I do have diodes installed in the wiring line of all 4 ignition wires separately then going into the one green ignition wire to the Bee*R with the diodes striped side facing the Bee*R
Coloured wires coming from the Bee*R:
Red: 12+v going to the cigarette lighter socket
Black: Ground is going to the cigarette lighter socket
Green: Ignition wire is going to all 4 ignition wires with diodes
Yellow: Tachometer is going to the ecu pinout
White: Launch Control is going to the Handbrake
This is LITERALLY my last resort to come ask for expertise here on the forum.
Please if you need anymore further information to help you understand to solve this issue please either reply or pm me
My Instagram name is @Phoenix_gts86
I had gotten the unit to work once but then my car wouldn’t run to its full capacity so yeah
So when the unit worked I had it also tapped into the crank angle position sensor in the ecu, it worked but the car wouldn’t run to its 100% full capacity, so it might be an idea to go back to the old setup that kinda worked and “Disable” the codes that showed up for the crank angle position sensor ����*♂️
Phoenix_gts86 is offline   Reply With Quote
Old 05-05-2019, 10:02 PM   #2
Phoenix_gts86
“Bump”
Old 06-26-2019, 09:36 AM   #3
Phoenix_gts86
Solved: http://www.ft86club.com/forums/showt...94#post3231194
FS: OEM Electric Power Steering Column, with Motor and Module MicheleAbbate Interior Parts (Incl. Lighting) 12 12-31-2018 03:47 PM
WTT - 2014 Scion Bespoke Nav Module for Toyota AHA Nav Module Danklvr Audio/Visual, Electronics, Infotainment, NAV 1 09-04-2014 05:57 PM
Where Do You Set Your Rev Limiter? Chad86 Scion FR-S / Toyota 86 GT86 General Forum 38 06-10-2014 04:48 AM
Electric Power Steering control module? slicktop Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 11-21-2013 08:38 PM
<3 my rev limiter NESW20 Other Vehicles & General Automotive Discussions 1 05-02-2010 11:05 PM
