Old 09-27-2019, 09:49 PM   #1
Chuckable
Drives: 2017 Toyota 86
Single gauge pod steering column mount?
I searched on this forum and on Google and don’t see anything like what I’m looking for. Does anyone know of a mount for a 52mm gauge on the steering column trim panel to place the gauge offset to the left in front of the speedometer?
I know Ortiz custom gauges makes one that puts the gauge pod in the center. But I’m looking for an offset one.
Anyone know of a solution?
I see Cravenspeed has this but not sure if anyone has any experience with it?
https://www.cravenspeed.com/the-belmont/
Chuckable is offline   Reply With Quote
Old 09-28-2019, 12:23 AM   #2
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
There is One where it's an entire thing that molds into the upper dash comming out in Japan. I would just wait for that unless you are in a hurry.
Old 09-28-2019, 10:30 AM   #3
Chuckable
Thanks. Think I’ll keep looking since I just want a single pod.
Old 09-28-2019, 11:55 AM   #4
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Like this? I think you can use one or two.
https://www.perrin.com/shop/interior-gauges/gauge-pod
https://frsport.com/craven-speed-crs...iABEgJpCPD_BwE
Old 09-28-2019, 01:24 PM   #5
Jonboy73
Jonboy73's Avatar
Drives: Toyota GT86 GTS
Any pictures or links???
Jonboy73 is offline   Reply With Quote
Old 09-28-2019, 01:42 PM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The cravenspeed gauge pod is incredible. If you want one, choose them. You won't be disappointed
Old 09-28-2019, 09:29 PM   #7
Chuckable
Thanks for the recommendation. Do you have one? Does it remain steady while driving?
Old 09-28-2019, 09:30 PM   #8
skylinekin
skylinekin's Avatar
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
Cravenspeed, clean mounting, works great with one or two gauges and super easy to install.
skylinekin is offline   Reply With Quote
Old 09-28-2019, 09:56 PM   #9
DarkPira7e
DarkPira7e's Avatar
I installed one for a friend in their wrx. Rock solid, unless you have steering column vibration I assume.
Old 09-28-2019, 10:10 PM   #10
Chuckable
Thank you. Have any pics of it mounted in your car by chance?
Old 09-28-2019, 10:36 PM   #11
norcalpb
norcalpb's Avatar
Do you have any more info? Will it look like this?
The Following 2 Users Say Thank You to norcalpb For This Useful Post:
sroby (10-02-2019), Ultramaroon (09-28-2019)
Steering Column BizzMan Transmission and Driveline 1 07-02-2019 01:44 PM
FS: 52mm Steering Column Gauge Pod skylinekin Interior Parts (Incl. Lighting) 2 02-11-2017 10:35 AM
Ticking/Rattling coming from steering column/gauge cluster Imprezzave Issues | Warranty | Recalls / TSB 24 09-17-2016 10:38 AM
Steering column gauge option? HuntingtonFRS Electronics | Audio | NAV | Infotainment 5 11-26-2015 07:30 PM
Steering Column Gauge Pod options TmP Cosmetic Modification (Interior/Exterior/Lighting) 3 05-16-2014 04:07 PM
