Old 09-24-2019, 08:58 PM   #61041
One of the few times I thanked a post and meant "thanks" as opposed to "lol".
It turns out my car came with pre-stripped seat bolts as a dealer installed option. 3 weren't terrible and I was able to hammer the torx socket onto them to get them out. The fourth is all but completely rounded off. I hammered down the socket, but felt it slip with next to no pressure. I live in a townhouse and was working in my driveway, so don't want to make too much noise after dark. I'll take a look in the daylight tomorrow and see if it is something I even want to try to take care of, or just take it to a shop and pay the lazy tax. I'll also have stop by Subaru and pick up 4 new bolts.
So ummmm why did the dealer have the seat bolts out in the first place? Or at least why did they attempt to take them out?
Tcoat is offline
soundman98 (09-24-2019)
Old 09-24-2019, 09:07 PM   #61042
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
The seat covers were replaced under warranty due to rips in the leather at around 30,000 miles.
When I got it back the plastic cover on the bottom of the seat wasn't installed properly so the seat back wouldn't latch fully (handle stayed up a bit), the airbag sensor cable was loose which caused the light to come on, and the tech forgot to bolt the bottom of the seat belt back in. Although I'm not entirely sure why they unbolted that in the first place.
To be fair, I guess it is possible that some vandal broke into the car without setting off the alarm and stripped the bolts knowing that one day I would regret it, but my money is on the dealer tech over-torquing them while reinstalling. I also wouldn't be surprised if the issues I'm having with the seat are somehow related to the cover replacement, but saying so feels like a stretch even with how pissed off I am about the whole mess.
ScoobsMcGee is offline
The Following 3 Users Say Thank You to ScoobsMcGee For This Useful Post:
Spuds (09-25-2019), Tcoat (09-25-2019), why? (09-25-2019)
Old 09-24-2019, 10:12 PM   #61043
soundman98
ProCrastinationConsultant
soundman98's Avatar
Well I would be screwed since I haven't even had a cheque in 20 years much less wrote one I could take a picture of.
i, a millennial, write 2 checks a month.
1 for the water bill, because the town charges a fee to accept credit card payments.
1 for the mortgage, because the bank it's through requires me to have a checking/savings account to do online payments that i don't have and have no need for.
soundman98 is offline
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
p1l0t (09-24-2019), Sapphireho (09-25-2019)
Old 09-24-2019, 10:23 PM   #61044
Check the axle oil level.
I plead ignorance. Is this to check for a cause, or a symptom?
edit: NVM. I found the thread.
Ultramaroon is offline
ScoobsMcGee (09-25-2019), Will BRZ (09-24-2019)
Old 09-25-2019, 02:00 AM   #61045
Shit, one of my trucks has an axle problem. One of the rear tires is wobbling slightly. Couldn't tell if it was a bent rim or worse. Swapped rear tires left and right, same slight wobble on same side. Crap.
What kind of a rear axle/suspension does the truck have?
humfrz is offline
Old 09-25-2019, 02:07 AM   #61046
Also, be very careful removing the seat bolts. I found they are easy to strip the head. I ended up hammering a 7mm socket onto one of the bolts to be able to remove it. I had to go to the store to by the special sockets that work on the seat bolt heads. "e" type torx. Then, IMO, I made a stupid mistake and used an impact driver on the bolts. Which removed 7 of them very quickly (I did both front seats) and stripped the 8th and final bolt very quickly too!
I used a torch to heat up the bolt and a wrench wit a long cheater-bar on the handle. Then it finally came out! (careful not to scorch your carpet like I did! LO!)
Good luck!
Do you folks know WHY the bolts for the seats have that skinny, little, weird shaped head?
Because they are to DISCOURAGE PEOPLE FROM TAKING OUT THE SEATS!
If you have worn out the seat, it's time for a new car.
humfrz is offline
Leonardo (09-25-2019)
Old 09-25-2019, 05:58 AM   #61047
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Regular solid axle. I don't get it. My dad ran the truck up a flag pole once, but that was like over 2 years ago. I've driven it back and forth from California to Idaho several times, even pulling the car hauler. You think we would have noticed a problem. It is like it came out of nowhere.
Sapphireho is offline
Old 09-25-2019, 06:03 AM   #61048
Sapphireho
Famous Potatoes
Sapphireho's Avatar
4 in the morning and I'm up. My stomach is aching. I ate way too many hot wings last night. I am a total pig.
Ultramaroon (09-25-2019)
Old 09-25-2019, 06:16 AM   #61049
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I finally got some raw milk to try. This stuff is awesome yummy.
humfrz (09-25-2019), Ultramaroon (09-25-2019)
Old 09-25-2019, 06:46 AM   #61050
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Those bolts are really easy to take off with the proper tool. I'm not exactly the best at this mechanic thing, but I was able to remove the bolts and take out my passenger seat in a reasonable amount of time.
why? is offline
The Following User Says Thank You to why? For This Useful Post:
humfrz (09-25-2019)
Old 09-25-2019, 09:25 AM   #61051
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Turns out coconut oil was definitely the right call! My beard is so soft.
Nevermore is offline
Old 09-25-2019, 09:58 AM   #61052
Ya but now you smell like a pina colada!
Tcoat is offline
Old 09-25-2019, 10:02 AM   #61053
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Nope, I mixed in some arabian sandalwood fragrance oil with a pear and redwood fragrance oil. I smell like fruity wood.
Old 09-25-2019, 10:11 AM   #61054
Oh be careful!
Tcoat is offline
Nevermore (09-25-2019), soundman98 (09-25-2019)
