Old 09-25-2019, 12:40 AM   #1
juniorrr
Drives: Scion Frs
Squaking noise when turning left. Please Help!
Hey guys so today i began to hear this squeaking noise whenever I TURN LEFT and it seems to only be that side but im not sure whats causing the noise? I believe its the front left side since it occurs while turning left but im not sure. ALSO the car only squeaks when I'm in motion at more than 5mph, if im at a stop and turn the wheels there is no squeaking I'm running Tein Flex Z coilovers and i've had them on for a couple months already. Not two long ago I made just to retighten everything except for the maybe the top hats. I honestly don't know anything about suspension so i thought i'd come on here for some help. Thanks!
juniorrr is offline   Reply With Quote
Old 09-25-2019, 01:00 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
I'd check wheel hub bearing.
juniorrr (09-25-2019)
Old 09-25-2019, 01:23 AM   #3
juniorrr
Drives: Scion Frs
No i highly doubt it’s the wheel bearing since it only happens when turning and not in a straight line even going 80mph
Old 09-25-2019, 01:42 AM   #4
When its squeaking, does it stop if you apply the brakes?
Old 09-25-2019, 02:01 AM   #5
juniorrr
Drives: Scion Frs
I’m not 100% on that but I will check I’m on you tomorow about that. But I do know that if I’m taking a turn, the fast I go the worse the sound gets
Old 09-25-2019, 02:35 PM   #6
juniorrr
Drives: Scion Frs
Okay so the car makes the squeaky noise in a straight line now at times and when I go over terrain that isn’t flat. It makes a noise at a certain rotation but then I turn left all the way it squeaks all the way through. The wheel has to be pointed tiny bit for it to squeak. And the noise gets worse with acceleration but doesn’t make noise at all going right. I found that it does actually stop or lower the squeak when I begin to brake so there’s that. Any ideas guys?
Old 09-25-2019, 05:54 PM   #7
It might be that you have a brake pad dragging or a sticking or loose caliper. I suggest that you take off the front wheel, rotate the caliper and check the pads, rotor and caliper.
Or, do it the humfrz way. Drive up to a local automotive shop, describe the symptom to them, ask them to find out what's causing it and fix it. Have a cup of coffee, smoke a cigarette (optional), read part of a car magazine, lean back in a chair and take a snooze. They will wake you when it's finished. Pay them, drive home and take a proper nap -
Old 09-27-2019, 01:57 AM   #8
juniorrr
Drives: Scion Frs
One quick question bro, I’m suspecting it could be the front end links and I was just wondering if you knew how to test if the end links have indeed gone bad? It’s definately not the wheel bearing and I took out the brakes and caliper and they seem fine resintalled everything and it’s still screeching. Someone is rubbing like metal on metal when the car is in motion.
The Following User Says Thank You to juniorrr For This Useful Post:
humfrz (09-27-2019)
Old 09-27-2019, 02:19 AM   #9
I'll have to defer to others. My front end suspension knowledge ended when the took the solid front axle out from under cars. -
Common gang, help this fellow out -
juniorrr (09-27-2019)
Old 09-29-2019, 10:51 PM   #10
juniorrr
Drives: Scion Frs
Sooo... I found the problem... it was some old masking tape that I never took off that got stuff behind my rotor and hardened over time. It was grinding up against the rotor I guess when I go left? Anyways took it out and no more noise now... I’m actually dumbfounded
The Following 2 Users Say Thank You to juniorrr For This Useful Post:
humfrz (09-29-2019), SuperTom (06-22-2025)
Grinding Noise When Turning Left ThatAsianBradah Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 03-20-2023 11:55 AM
Clicking/cloncking from left front when turning wheels cawith Issues | Warranty | Recalls / TSB 14 02-08-2019 05:14 AM
Noise when turning Autoenthusiastasm BRZ First-Gen (2012+) — General Topics 7 01-21-2019 10:14 PM
Heavy steering when turning left... Venator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-10-2015 03:07 PM
metalic screeching turning left raptor87 Issues | Warranty | Recalls / TSB 2 01-18-2013 01:41 PM
