Old 09-24-2019, 12:27 PM   #1
redwine
Front Axle Oil ?
Hi,
Just want to confirm.
Beside the Engine/Transmission/Diff Oil,
is there any other oil that need to replace ... eg. Front Axle ?
Thanks
redwine is offline   Reply With Quote
Old 09-24-2019, 12:51 PM   #2
Do you have the AWD BRZ?
KR-S (09-24-2019), soundman98 (09-24-2019), WolfpackS2k (09-25-2019)
Old 09-24-2019, 12:58 PM   #3
extrashaky
Drives: 2014 BRZ Limited
You don't really need to worry about the oil in the front differential unless you have driven through high water with the breather tube disconnected.
The Following User Says Thank You to extrashaky For This Useful Post:
Old 09-24-2019, 01:20 PM   #4
redwine
Haven't peek underneath.
You mean only the "driving or powered" axle need oil replacement ?
Old 09-24-2019, 01:38 PM   #5
CoolHandMoss
Drives: 2013 FRS
If you care about your car you should go ahead and do the front axle fluid and the blinker fluid at the same time. Don't forget the muffler bearings too.
CoolHandMoss is offline   Reply With Quote
The Following User Says Thank You to CoolHandMoss For This Useful Post:
Old 09-24-2019, 01:39 PM   #6
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Only the powered wheels have axles...
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
redwine (09-24-2019)
Old 09-24-2019, 03:55 PM   #7
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
To be fair, OP may have just said "front axles" as an example... or he may be referring to a different car entirely.
Old 09-24-2019, 04:01 PM   #8
KR-S
Sporadic Member
KR-S's Avatar
To add to this, check to see if your brake calipers allow you to see your pads, and make sure your powered mirror does something. If not, your BRZ is literally the worst piece of shit car ever made, and you should burn it and buy something else.
The Following 5 Users Say Thank You to KR-S For This Useful Post:
HKz (09-24-2019), soundman98 (09-24-2019), Spuds (09-24-2019), Stang70Fastback (09-25-2019), Tcoat (09-24-2019)
Old 09-24-2019, 04:20 PM   #9
Grady
Grady's Avatar
Don’t forget to keep your blinker fluid full! It goes in the end of the turn signal stalk.
BMW’s run around with theirs empty all the time, never see the turn signals work.
The Following User Says Thank You to Grady For This Useful Post:
Spuds (09-24-2019)
Old 09-24-2019, 04:23 PM   #10
Excellent thread cross over!
KR-S (09-24-2019), Mr.ac (09-24-2019), soundman98 (09-24-2019), Stang70Fastback (09-25-2019), ~el~jefe~ (09-24-2019)
Old 09-24-2019, 04:23 PM   #11
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Would also help to check the rear view mirror to see if it does anything fancy. If not, then it’s truly the WORST car EVER.
In all seriousness, just follow the required services by mileage OP. Other than the ones you listed, I think the only other fluid or oil service would be the brake fluid
Will BRZ is offline   Reply With Quote
The Following User Says Thank You to Will BRZ For This Useful Post:
KR-S (09-24-2019)
Old 09-24-2019, 04:27 PM   #12
KR-S
Sporadic Member
KR-S's Avatar
Can't quote you, but I already got that rear view mirror covered. Still good to see if maybe the side mirrors shoot double rainbows or something.
The Following User Says Thank You to KR-S For This Useful Post:
Will BRZ (09-24-2019)
Old 09-24-2019, 04:36 PM   #13
Will BRZ
Drives: 2015 BRZ
Thought it was poured inside the headlight? Fuck..
Old 09-24-2019, 05:10 PM   #14
Clearly it goes in the tail lights!
OEM Axle + Axle Nut vroom4 Brakes, Suspension, Chassis 3 02-02-2016 02:12 PM
Nameless axle back or front pipe/over pipe in SoCal kevin.nguyen Engine, Exhaust, Transmission 0 07-30-2014 11:04 PM
MI: FS: FRS BRZ Greddy SP Elite Axle Back and DC Sport Front Pipe Bao Engine, Exhaust, Bolt-Ons 0 07-23-2014 12:03 PM
Just installed my PPE Engineering front, mid, and axle back Evil86 Engine, Exhaust, Transmission 7 02-21-2013 11:10 AM
