Old 09-17-2019, 01:36 PM   #169
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Originally Posted by Pat View Post
How is overall light output with these compared to OEM HIDs?
I had halogens so I am curious as well. The cutoff is amazing on these.
Sent from my ONEPLUS A6010 using Tapatalk
Rican_D is offline   Reply With Quote
Old 09-21-2019, 08:52 PM   #170
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I believe the light output quality will be more than halogen, but less than HIDs. Watch the video:
[ame]https://www.youtube.com/watch?v=0KbZBgrEk_w&t=496s[/ame]
Old 09-21-2019, 10:44 PM   #171
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by shadow_772 View Post
I'll have to sort out an issue. I wired in an aux fuse box at the same time I did headlights. Everything works well with the exception of the dimming feature on the clock and radio. I'm either full bright or nothing on the clock and dim on the radio, then when headlights are on I'm in max dim on clock and radio... hmm
Keep in mind that video is discussing retrofitting bulbs into OEM housings. that does not necessarily apply to the XB morimoto LED system.
Old 09-22-2019, 03:25 AM   #172
Irace86.2.0
Did you mean to be quoting me or him?
In case you did mean to be quoting me, the LEDs will not out perform the HIDs. This is a common complaint among high end cars like with the optional LED headlights on the Porsche 911; sure, they look unique, but the HIDs will have better illumination and penetration. Don't believe me? Here is a quote from TRS to a reply in the comments of their Youtube video:
Charles Lin ...Hey TRS, how's the light output compare to say D2S 4.0 with CBI bulb. Roughly speaking... Because the website says ~2600lm for the LED, and ~3400lm for the HID bulb.
TheRetrofitSource Inc ...The D2S 4.0 with CBI would be the performance winner here
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Pat (09-22-2019)
Old 09-22-2019, 10:16 AM   #173
Pat
Pat's Avatar
Drives: 2023 BRZ
Yes, thank you.
The Following User Says Thank You to Pat For This Useful Post:
Irace86.2.0 (09-22-2019)
Old 09-22-2019, 11:23 AM   #174
Irace86.2.0
Yes, thank you.
I meant to post this too for more context.
https://www.autoevolution.com/news/p...4s-116411.html
The Morimotos and FT86SF headlights have a single LED projector, unlike the Intecs. I don’t know if this was because Intecs had a high and low beam that was separate, or perhaps it was a dual setup to get the light output to meet or exceed HIDs, and maybe that is what Porsche does. Regardless, the video demonstrates that at 10 feet the LEDs average better, and they also disperse light brighter in his driving video, but they probably scatter light more like HIDs in a reflector housing. You get that impression from the comments below, and that also matches the data from TRS’ video, that LEDs don’t have the same focused penetration for down road visibility.
Pat (09-22-2019)
Old 09-24-2019, 12:39 AM   #175
Irace86.2.0
Old 10-02-2019, 12:57 PM   #176
Rican_D
Rican_D's Avatar
Haven't posted a pic in a minute
The Following User Says Thank You to Rican_D For This Useful Post:
zeal86 (01-02-2020)
Old 01-01-2020, 09:19 PM   #177
ssidd
Drives: 2015 Scion FRS - Asphalt
Finally got around to installing mine, wired everything up and it works fine. However, just came across the DRL Harness, and a bit confused if it is needed and where to add the connection in the fuse box...
Any insight? - Thanks
ssidd is offline   Reply With Quote
Old 01-02-2020, 11:28 AM   #178
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Not sure about a harness but for my Spec-D headlights DRL I tapped into the fuse box so they're always on.
https://www.ft86club.com/forums/showthread.php?t=71480
Clueless
YamahaR86 is offline   Reply With Quote
The Following User Says Thank You to YamahaR86 For This Useful Post:
ssidd (01-03-2020)
Old 01-03-2020, 06:28 PM   #179
ssidd
Thanks, that helped!
I think it worked but... cant check for sure. Apparently, battery is dead because i'm an idiot and can't find my jump cables...
Old 01-10-2020, 03:52 PM   #180
mrhayes1
Drives: 2013 Scion FRS white
For anyone wondering, the light output on these is amazing. I had the FRS with base model headlights retrofitted with HIDs. The light output on these Morimotos is still better. cant speak for the OEM BRZ headlights tho. LEDs have come a long way....
mrhayes1 is offline   Reply With Quote
Old 01-10-2020, 03:58 PM   #181
mrhayes1
Also, Mr. Eye asked about the high beam cover moving on bumpy roads. I don't think this is the case. My wife was driving ahead of me and told me my driver side headlight was flashing. After a bit of investigating, I don't believe the headlight is moving or flashing at all, it is simply just pointed too high so every bump I hit makes the bright low beam look like a strobe light. This is evident by looking at the front of the car with the headlights on while the car is parked and then lowering your head until you are looking directly at the beam. You can easily see how bumps on the road would make it seem like the headlight is flashing if you are going in and out of the direct beam.
I think the solution is to just adjust the headlights which I have not done yet and will try to do this weekend. It is pointed too high. Had one guy flash his lights at me prob because he thought my brights were on when they were not.
Old 01-10-2020, 04:38 PM   #182
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Quality Projectors make a world of difference even with crappy bulbs. I got into them when I was modifying motorcycles. I dropped some HIDs into some aftermarket halogen head lights and it was so bad. I did a morimoto projector upgrade and reminded again why it is worth it.
Headlight adjustment is the #1 factor on why people complain about bright, blinding lights these days.
I love ChrisFix's automotive videos and used his headlight video to aim my headlights here:
Went behind a grocery store where no one was around, drove up to the wall and marked the tape. Then I drove back 25 ft using a tape measure and adjusted it down/L/R. Easy.
Clueless
Spec-D Headlights & Morimoto D2S HID Kit FyeaFRS Cosmetic Modification (Interior/Exterior/Lighting) 9 03-10-2017 12:19 AM
6K H11 Morimoto HID Kit Zero90 Exterior Parts (Aero, Lighting, Etc.) 2 05-20-2014 12:49 PM
FS: FRS HID Retrofit Kid (Morimoto) Khyron686 Exterior Parts (Aero, Lighting, Etc.) 2 04-21-2014 10:08 PM
Stock FR-S Headlights & Tail Lights, Morimoto Elite HIDs, and OEM Mud Guards tbox Exterior Parts (Aero, Lighting, Etc.) 14 01-11-2014 02:18 PM
Help Morimoto HID kit Jacob G. Cosmetic Modification (Interior/Exterior/Lighting) 4 02-18-2013 02:03 AM
