Old 09-18-2019, 03:04 PM   #1
wrb.brz
Drives: 2015 Series.Blue BRZ
Unusual hole in the driver’s side carpet
Hey guys,
Recently while vacuuming my interior, I discovered a very unusual hole in the driver’s side carpet. It is centrally located a few inches behind the floor mat (see attached picture), and almost indiscernible from a cigarette burn. Kicker is, I purchased the car brand new and have been very cautious to prevent any unnecessary wear. It has approximately 45k miles, and the interior is otherwise in excellent condition.
Upon further inspection, there’s a sharp plastic piece directly under the hole. Almost like the edge of a cable tie used to hold a harness in place, but I can’t see much through the small hole. It appears that whatever is under there eventually wore through from tension/pressure in that area while getting in and out of the car. Has anyone else seen this before, or perhaps have a remedy for the situation?
The plan is currently to shave some carpet fibers in an inconspicuous area, then create a plug to patch the hole. It’s a small area that most people won’t notice, especially if the seat isn’t all the way back.
But being somewhat meticulous in attempt to preserve a limited production model, this situation is extremely frustrating as you could imagine. Any input would be greatly appreciated, thanks in advance!
wrb.brz is offline   Reply With Quote
Old 09-18-2019, 06:44 PM   #2
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Damn roach burns !!! My s10 used to be riddled with those
mswbrz is offline   Reply With Quote
The Following 3 Users Say Thank You to mswbrz For This Useful Post:
Leonardo (09-19-2019), soundman98 (09-18-2019), Tcoat (09-19-2019)
Old 09-18-2019, 06:52 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Oh my god!!!
Are you ok? Can I call you my grief counselor to talk about this?
Joking aside, burn the whole car. Don't even bother trying to fix it.
Normally I would offer you a brand new Honda Civic SI, but I feel it's too much car for you.
Sorry I can't help.
The Following User Says Thank You to Mr.ac For This Useful Post:
Old 09-18-2019, 06:53 PM   #4
Impureclient
Drives: 2015 FR-S
Looks pretty serious, pretty sure that's going to be totaled out. Sorry to be the bearer of bad news.
Sometimes it's the little things that make a difference. So much for preserving a limited production model.
The Following User Says Thank You to Impureclient For This Useful Post:
Old 09-18-2019, 07:07 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
^ LOL
OP, that hole under your seat is TINY!!! I would not worry about it!
If you must fix it, you could replace the carpet or install these cool quilted covers.
https://www.ft86club.com/forums/showthread.php?t=107305
I LIKE TIRES!
Old 09-18-2019, 07:15 PM   #6
YIKES! - tough crowd today -
Yep, OP, like you are contemplating, I suggest you fill up the hole with epoxy, then sprinkle carpet shavings on top of it.
wrb.brz (09-18-2019)
Old 09-18-2019, 07:17 PM   #7
wrb.brz
Thanks for all the helpful information! Obviously this is a surmountable issue, and not the end of the world. This post is primarily to see if anybody else has a similar wear pattern. Much appreciated guys
As for Mr.ac, nice comment about the Civic. My fun car is an FD, the BRZ is merely the nice daily. But woe is me for trying to keep my things nice
The Following 4 Users Say Thank You to wrb.brz For This Useful Post:
humfrz (09-18-2019), Impureclient (09-18-2019), Mr.ac (09-18-2019), Spuds (09-19-2019)
Old 09-18-2019, 07:54 PM   #8
Impureclient
Drives: 2015 FR-S
I checked and I don't have any bump there. Maybe the way you sit in the car, you are pushing on it enough to have worn through it faster?
I use these floor mats so it would cover it even if it was there. https://www.amazon.com/3D-MAXpider-C...8851226&sr=8-1
Much better than the stock floor mats.
The Following 2 Users Say Thank You to Impureclient For This Useful Post:
norcalpb (09-18-2019), soundman98 (09-18-2019)
Old 09-18-2019, 07:59 PM   #9
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
You got one with the "long distance" package. That is where you put the catheter tube thru the floor. Do you also have a second gas tank in the trunk?
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
gravitylover (09-19-2019), Mr.ac (09-18-2019), soundman98 (09-18-2019)
Old 09-18-2019, 08:45 PM   #10
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Same year, same series.blue interior, same hole, same reason. Just over 53,000 miles.
The front bumper is also sagging a bit after removing it earlier this year, and the side bolsters of the driver's seat have deformed in a way that it hurts to sit in it for a long period of time. Still love driving the car so let the cosmetic stuff slide. I am considering an aftermarket seat, though. If it bugs you I suppose filling it in will be fine, but it also isn't unique to your car if that helps.
The Following 2 Users Say Thank You to ScoobsMcGee For This Useful Post:
Spuds (09-19-2019), wrb.brz (09-19-2019)
Old 09-19-2019, 02:07 PM   #11
wrb.brz
Thank you, good to know I'm not alone lol. Oddly enough, I checked my buddies 2014 and it doesn't appear to have that plastic piece under the carpet like we do. Anyway, good luck on the seats should you decide to go that route!
The Following User Says Thank You to wrb.brz For This Useful Post:
ScoobsMcGee (09-19-2019)
Old 09-19-2019, 03:25 PM   #12
JD001
JD001's Avatar
Drives: Subaru BRZ
Why is there so much wear immediately under the seat area? General pattern is usually around the vicinity of the foot pedals..
The Following 2 Users Say Thank You to JD001 For This Useful Post:
humfrz (09-19-2019), Tcoat (09-19-2019)
Old 09-19-2019, 04:01 PM   #13
I put Weathertech trays in a long time ago. Not even sure if I have carpet there.
soundman98 (09-20-2019)
Old 09-19-2019, 04:14 PM   #14
ScoobsMcGee
In my case the seat covers were replaced under warranty due to tears in the leather after ~20,000 miles. Got the car back with new seat covers on, but the seat belt wasn't bolted in and the carpet had two new holes in it over top of two plastic clips as described. Also may have something to do with how the side bolsters are warped, but hesitant to really say that seeing as how I've put 30,000 miles on the car over 2.5 years since.
Driver Left Side Exhaust Hole Delete Cover 2017-2020 Toyota 86 coolguy1o1 Exterior Parts (Aero, Lighting, Etc.) 7 05-22-2020 11:59 PM
Hole in driver side door Detroiter Scion FR-S / Toyota 86 GT86 General Forum 46 03-10-2017 09:48 PM
Wtb brz driver side headlight and driver side fender ikeryder13 Want-To-Buy Requests 1 10-06-2016 06:18 PM
driver side Windows cant contrl by driver side button athlon816 Issues | Warranty | Recalls / TSB 12 12-13-2014 10:06 AM
Hole in driver seat, where can I get OEM fabric to repair it? speedy racer Cosmetic Modification (Interior/Exterior/Lighting) 2 10-18-2013 11:16 AM
