Old 06-06-2012, 11:35 AM   #29
FRSpdDmn
Drives: 128i, Z3 Coupe, Fiero GT
Originally Posted by Koji_Online View Post
I just didn't want to mess with it yet; one thing I did modify
was the clutch grab point by screwing in the master cylinder threads into the clutch pedal bracket.
Lowered physical pedal height & now my clutch grab point is super close to the floor without any gear grinds/ hesitation shifting back & forth between 1st and Reverse
Could you provide a little more detail please? I would like to do this.
-Anthony
Former '13 Whiteout FR-S, BMW 128i, BMW Z3 Coupe, Pontiac Fiero GT
2017 Pirelli World Challenge TC Rookie of the Year
2012 NASA SpecE30 National Champion
www.DriveFasterNow.com
FRSpdDmn is offline   Reply With Quote
Old 06-06-2012, 01:38 PM   #30
Boosted2.0
Boosted2.0's Avatar
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
Allow me to propose an old school answer:
Add a return spring or two to the pedal assembly.
Boosted2.0 is offline   Reply With Quote
Old 06-06-2012, 02:26 PM   #31
Koji_Online
N7 Spectre
Koji_Online's Avatar
Drives: 2017 Toyota 86 (Ablaze - 6MT)
Smile
If you go under your steering column you will see the clutch master cylinder coming thru the firewall, just above the accel. pedal (I couldn't find it at first because cars I had before have it right behind the clutch... anyway) double-check you're looking at the right one by pressing the clutch with your left hand & watch the bracket/ cylinder move in & out.
You will see that the master cylinder bolt (w/e) threads into that bracket, & is held in place by a 12mm hex nut; pull out a 12mm open-ended, loosen the nut (too difficult to explain direction based on your orientational awareness; just be sure to note the thread pattern to know how you should turn to loosen it); slightly press clutch pedal with hand to remove tension from bolt, then with right hand screw the threads into the bracket; this will effectively bring your pedal closer to the ground & your grab point as well;
I've messed with different points all week & let me save you R&D; the most comfortable point for intuitive starts/ rolls off the clutch, & heel-toe downshifting; screw in until the clutch pedal sits ever so slightly lower than your brake pedal.
Test setup by getting in drivers seat, turn your car on, & test grab point by putting into first & letting out very slowly with no gas input; take note of when your car ever so slightly moves forward; next run forward a few feet, STOP completely, then immediately shift into reverse; if you get no unusual hesitation or grinding then move back & repeat this (forward, stop reverse) until you feel comfortable with your grab point & make sure you aren't grinding gears.
Tighten the bolt & one final thing, look at the front of your clutch pedal, the first sensor up is for your cruise control & I believe relates to your gear indicator display (if you have it enabled); basically the gear displays only with clutch out, but now that you put your pedal closer to the floor it does not engage the switch on the sensor.
In the same fashion that you loosened the clutch master cylinder nut, use a 14mm to loosen the nut attached to the sensor; it doesn't actually thread into the bracket, so you don't have to turn the sensor in; with the nut loose just slightly push it in to get the sensor switch in contact with the clutch pedal (fully depress the switch onto the pedal); just make sure it isn't pushing force down on your pedal, or this will probably put wear on your clutch ( my suggestion is to pull up on your pedal while you push the sensor into place; then tighten nut.
Now you are all set, you clutch point is optimally adjusted for all sorts of driving, & your cruise control/ gear indicator still functions =D
GT 6/ Sport PSN: Koji_Online
Koji_Online is offline   Reply With Quote
The Following 9 Users Say Thank You to Koji_Online For This Useful Post:
Calum (06-06-2012), cmspooner (06-09-2012), Dimman (06-06-2012), ducks (06-06-2012), ESBjiujitsu (06-06-2012), FRSpdDmn (06-06-2012), jcw99 (01-29-2015), jdrxb9 (06-07-2012), vividracingcom (06-06-2012)
Old 06-06-2012, 02:34 PM   #32
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
The clutch pedal is a turnover type to reduce pedal effort, according to the service manual. I've never heard of this being used in a Subaru before so I'm guess that's why the effort is so light. Seems like it will not be an easy fix.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 06-06-2012, 02:38 PM   #33
vividracingcom
vividracingcom's Avatar
Drives: FR-S, Porsche 997.2, CLS63 AMG
We're working on a new clutch and flywheel for the FR-S/BRZ. We've already got one being tested. Manufactured by one of the biggest names in the industry.
Clutch feel is much improved compared to stock.
Vivid Racing - Your #1 Source for Aftermarket and OEM Parts!
Cusco | Greddy | Agency Power | HKS | Clutch Masters | etc
Check out the VividRacing.com Scion FR-S Catalog
Arsha @ Vivid Racing | 480-966-3040 ext:225
vividracingcom is offline   Reply With Quote
Old 06-06-2012, 02:48 PM   #34
OrbitalEllipses
Drives: Attitude
Originally Posted by old greg View Post
On some cars, they are also set up to restrict the maximum flow rate of fluid from the slave cylinder to the master cylinder as a sort of anti-clutch-drop measure to help keep transmissions in one piece. A prime example is the WRX: 2002 = no damper, 2003 = damper.
Yep.
That's why I said y'all should look for it and remove it if it's there.
Old 06-06-2012, 05:09 PM   #35
Calum
That Guy
Drives: 2013 asphalt FRS MT
Mods please move this to the DIY section. That's a great write up on something I bet a lot people will be doing.
The Following User Says Thank You to Calum For This Useful Post:
Koji_Online (06-06-2012)
Old 06-06-2012, 05:35 PM   #36
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
As someone who is used to lighter clutch pedals (though I have driven and enjoyed many heavier pedals as well), I found the clutch pedal in the FR-S to be very direct and while light, very easy to control.
I would not change it purposely unless it was just the result of putting in a heavier pressure plate, etc.
I thought it felt great.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 06-06-2012, 07:13 PM   #37
Zoomie
Drives: VW R32
I think if it bothered me that much I might initially try the extra or heavier return spring trick and if that didn't do it for me I would remove the pedal TIG up the pivot hole for the pushrod going to the master cylinder and redrill it slightly lower down the pedal. Personally stuff like this to me seems idiocyncratic to this cool little car and truthfully, I'd just get used to its wierdities rather than trying to change them to match mine.
Zoomie is offline   Reply With Quote
Old 06-06-2012, 07:58 PM   #38
ESBjiujitsu
MUST HAVE MORE 86 ! ! !
ESBjiujitsu's Avatar
Drives: Mazdaspeed 6 2.3 AWD Turbo
last night i drove a manual frs for the first time and was taken by shock at the softness of the clutch pedal. Ido agree that it is crazy easy to control and get use to but i like having a bit of resistance and that kick!!!! but it certainly is not a reason to NOT get the car, because im sure i can find a nice stiff clutch to throw in there Its the softest clutch I think its one of the softer clutches on a sports car i have ever felt. But again....the car is too awesome to give a $h!t
WISH LIST: Whiteout FRS- Bronze 18' race rims, Cooper Zeon RS3-S tires,
Cusco Coilovers, Cusco 6 point cage, CF Lip spoiler, CF F1 Mirrors, HKS GT-86 SC
92 carmy -> 86 corolla-> Honda S2000 -> Audi TT -> Mazdaspeed6 -> NEXT UP TOYOTA FT-86!!!!
ESBjiujitsu is offline   Reply With Quote
Old 06-07-2012, 12:27 AM   #39
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
If you go under your steering column you will see the clutch master cylinder coming thru the firewall....
Just wanted to say thanks for this! I don't think I went quite as far as you did - my clutch pedal is about even with my brake and I didn't have to adjust the sensor position for the CC/GI to work. I was surprised that what looks like a small adjustment feels totally different to the feet. Even though the effort is unchanged, the throw is now so much more in tune with the other controls, it really is an amazing improvement.
jdrxb9 is offline   Reply With Quote
The Following 2 Users Say Thank You to jdrxb9 For This Useful Post:
jcw99 (01-29-2015), Koji_Online (06-07-2012)
Old 06-07-2012, 02:32 AM   #40
Koji_Online
N7 Spectre
Smile
Definitely changes the feel of the whole driving experience for me as well!; I'm glad it worked out well for you & thanks for the 'thanks' =D
Old 07-19-2012, 01:49 PM   #41
FRSpdDmn
Originally Posted by Draco-REX View Post
Yeah, the delay valve appears to be built into the master cylinder.
Has anyone figured out if there is a master cylinder from another car that can be swapped in, without a clutch delay valve? The CDV is infuriating.
Thanks.
-Anthony
Old 07-19-2012, 02:17 PM   #42
wu_dot_com
Drives: accord
so here is the experience from someone who actually have an aftermarket prototype clutch, pressure plate and flywheel installed on the BRZ.
with the new pressure plate and clutch. the grab point is more define. however, the clutch still feels plushy. the pressure plate did increased the peddle stiffness and resistance. however, it is very light by feel, and the actual gain can only be more easily realized through test data. on the other hand, going to a even heavier pressure plate is not desirable. since this car produces relatively low torque, having a extra heavy pressure plate may reduce the longevity of the axial bearing of the engine.
also. the design of this car have massive damping in the OEM spring center clutch hub. couple with a relatively heavy clutch (by mass), what you get is a chatter free gear operations throughout the RPM ranges. if you were to reduce the mass of the clutch , and stiffen up the spring center(to allow more torque carrying capability), your system will not be able to damped out the vibration chatter between the input shaft and the transmission gears at certain RPM. For my car, I have a chatter zone around 35-3700 RPM with full engine load (clutch is couple, AC on).
so beware of what you are asking for. there is a trade off in every choice you make.
wu_dot_com is offline   Reply With Quote
The Following User Says Thank You to wu_dot_com For This Useful Post:
SkAsphalt (06-30-2015)
Clutch/brake smell mr2lor Scion FR-S / Toyota 86 GT86 General Forum 8 05-24-2012 01:45 PM
Clutch wear? Pakjk89 Engine, Exhaust, Transmission 102 04-12-2012 07:21 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
Steering Wheel Feel ap5512 BRZ First-Gen (2012+) — General Topics 8 12-08-2011 11:16 AM
Feel like a Post Whore. Siriusly.Andrew Off-Topic Lounge [WARNING: NO POLITICS] 60 03-14-2010 05:42 PM
