Old 09-10-2019, 11:34 PM   #29
Tristor
Tristor's Avatar
One last thing, all of the above part numbers are not for the PP Brembos. They require a different rotor and pad. Based on this and your other threads, I believe you have the normal brakes and not the PP Brembos on your BRZ. If you do have the PP Brembos I can give you correct part numbers.
Tristor is offline   Reply With Quote
The Following User Says Thank You to Tristor For This Useful Post:
soundman98 (09-11-2019)
Old 09-11-2019, 08:09 AM   #30
GrantedTaken
Sorry. I've been trying to engage in this thread from work, on my phone. I'm missing bits of detail provided. When I get home from work on Thursday, I'll check everything out on ROCK with my PC.
As for brake feel, I think my pads are getting low anyway, and I always replace scored/lipped rotors while I'm in there.. since cheap.. If there is no improvement in brake feel, I still need to replace. But let's see.
GrantedTaken is offline   Reply With Quote
Old 09-11-2019, 10:30 AM   #31
LancePower
Drives: 2020 BRZ tS
+1 for the TRD pads. I really like them. Initial bite was much improved.
LancePower is offline   Reply With Quote
Old 09-11-2019, 11:00 AM   #32
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Best thread in a long time.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following User Says Thank You to venturaII For This Useful Post:
wparsons (09-13-2019)
Old 09-12-2019, 10:55 AM   #33
Tristor
Tristor's Avatar
It certainly won't hurt to replace them, especially since the rotors are already lipped. After you replace them bleed your brakes using the two-person method, bed them in sufficiently, and then bleed a second time. Usually I find that the ABS and brake booster systems can sometimes hold air at the top of the system but it can be pushed down with sufficient repeated hard braking, which can be part of bedding. That second bleeding usually fully evacuates any air from the system.
If bleeding isn't sufficient, the only way to make them any harder might be stainless steel lines and a master cylinder brace, both of which will reduce "slop" in the pedal. The brakes in this platform have a lot of take-up with easy travel before they feel hard /even when brakes are being applied/ because of the way the electronic brake assist works. It kind of annoys me too. With some BBKs you get much harder brake pedal due to piston sizing, but they wouldn't be suitable for primarily street driving.
Generally though, bleeding properly should get you where you need to be.
The Following 2 Users Say Thank You to Tristor For This Useful Post:
GrantedTaken (09-12-2019), Summerwolf (09-13-2019)
Old 09-12-2019, 07:25 PM   #34
GrantedTaken
Maybe I will consider some "performance" non-track pads that have a little more bite than OEM.
If OEM pads last 70k miles, maybe they are designed to have less friction.
I am willing to trade lifespan for more sacrificial pad that translates to harder bite.
Old 09-12-2019, 07:53 PM   #35
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Did you miss this one?
https://www.ft86club.com/forums/showthread.php?t=136737
Spuds is online now   Reply With Quote
The Following 3 Users Say Thank You to Spuds For This Useful Post:
soundman98 (09-12-2019), venturaII (09-13-2019), wparsons (09-13-2019)
Old 09-13-2019, 08:31 AM   #36
venturaII
venturaII's Avatar
Yeah, I saw it as well...I tried to give the benefit of a doubt though since it was just the General forum, and there's all sorts of nonsense posted there. I tend to stick to more topic-specific forums usually...better info and generally a higher degree of knowledge/experience. At least, I thought so until now...
The Following 2 Users Say Thank You to venturaII For This Useful Post:
Spuds (09-13-2019), Tcoat (09-13-2019)
Old 09-13-2019, 09:35 AM   #37
wparsons
wparsons's Avatar
Initial bite != a firm pedal... are you after a lot of bite with minimal pedal pressure, or do you want a firm pedal (or both)?
flickr
Old 09-13-2019, 09:38 AM   #38
wparsons
wparsons's Avatar
Wow.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Spuds (09-17-2019), Ultramaroon (09-15-2019)
Old 09-13-2019, 01:43 PM   #39
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Rockauto probably only lists them as "daily driver" because they're not the "performance brand" that is slotted or drilled.
EBC has always done well by me across multiple platforms and I've had good luck with hawk as well, but all the advice in this thread is on point.
Rather than question the forum the same thing in multiple ways, why not use google and get a variety of experiences across the board with the names and products. Stoptech is a pretty big name and so is centric to have not heard of either.
The Following User Says Thank You to Summerwolf For This Useful Post:
Tristor (09-13-2019)
Old 09-13-2019, 09:49 PM   #40
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
While not a pro, I probably have more DIY experience and more tools than the average body kit ricer on this forum.
yet you think the factory brakes on this platform is the "worst design ever".
you're not a pro but you're also not far from the ricers you're hating on.
The Following 3 Users Say Thank You to mav1178 For This Useful Post:
finch1750 (09-13-2019), Spuds (09-13-2019), Tristor (09-14-2019)
Old 09-13-2019, 09:52 PM   #41
mav1178
mav1178's Avatar
So premium centric and stoptech are considered legit? They're not some cheap Chinese eBay AutoZone garbage? I mostly own German cars, so these other brands are new to me. Zimmerman, sebro, etc.
Originally Posted by Joon525 View Post
100% legit.
Centric and Stoptech are 100% legit..... and made in China. not like anyone cares other than "oh this is made in this country so it must be crap"
Old 09-13-2019, 09:58 PM   #42
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
For fuck sake just Google Centric if you dont believe the "ricers" here. These are the same rotors recommend by most people that track since they are quality and cheap
They are one of the biggest brake companies around.
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
Tristor (09-14-2019), weederr33 (09-14-2019)
Bad ball joint;possible to just replace balljoint or do I have to replace control arm kev0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 01-03-2019 03:07 PM
Have to replace entire assembly to replace fuel filter? tobkin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 08-04-2017 02:26 PM
Vinyl on driver's seat split open; dealer will replace babydriver Cosmetic Modification (Interior/Exterior/Lighting) 2 12-20-2014 08:55 PM
Why do my Stoptech brakes squeel so loudly? Fix or replace? eikond Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-20-2014 02:17 PM
Help me replace my rear brakes? PoWn3d_0704 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-28-2014 03:55 PM
