Old 09-05-2019, 01:45 PM   #15
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Clean install so far! It's amazing how, in our engine bays, there appears to be a lot of empty space but when you try to install something there's always something else in the way. Maybe all engines are like that?
MJones_RB is offline   Reply With Quote
Old 09-05-2019, 05:45 PM   #16
RayRay88
Drives: 2017 86 860 Special Edition
I always wondered how this compared to the Jackson Racing Kit, in terms of efficiency and 2017+ friendly install.
Maybe @CounterSpace Garage or @CSG Mike can chime in.
RayRay88 is offline   Reply With Quote
Old 09-05-2019, 05:49 PM   #17
CSG Mike
CSG Mike's Avatar
Originally Posted by Chuckable View Post
Here’s the area behind where the cooler sits. The only obvious space for air to flow after exiting the cooler is noted by the arrow. I’m sure it would add a lot of cost, but I wonder if a vent in the wheel well might make any difference?
The airflow primarily goes up behind the headlight, and exits out toward the back of the engine bay.
Old 09-05-2019, 05:50 PM   #18
CSG Mike
CSG Mike's Avatar
Originally Posted by EndlessAzure View Post
I live in the high desert of SoCal, and I still think my Blitz needs a block-off for street use. I've never seen it over 200F on the street with ambient temp over 100
Your temps are post-cooler; you can safely add 30-40F to get a pre-cooler temperature reading.
Old 09-05-2019, 05:51 PM   #19
CSG Mike
CSG Mike's Avatar
I think as a gross rule of thumb you want to get the oil to at least 212F during operation to help boil out any water that inevitably gets absorbed into the oil.
That's why a block-off plate is advisable.
Water will evaporate off, even under 212F!
That said, if you have moisture in your oil, you got way bigger problems to worry about.
Old 09-05-2019, 05:51 PM   #20
CSG Mike
CSG Mike's Avatar
This is more effective than the JR kit, but costs a bit more.
Worth every penny.
Old 09-05-2019, 08:11 PM   #21
Chuckable
Drives: 2017 Toyota 86
Thanks for chiming in, CSGMike, and for the education and information.
Chuckable is offline   Reply With Quote
Old 09-06-2019, 09:18 AM   #22
Chuckable
The Greddy kit uses a different thread for the oil filter so the OEM filter doesn’t fit. Greddy makes their own filter, but any filter with the correct specs will work.
Attached is pic of the filter housing with rough measurements for ID and OD. Based on a phone call with Fram, it appears that a 3614 will work, or whatever cross references with that in your favorite brand.
I haven’t verified figment yet since I’ll be using the Greddy filters for the time being, but wanted to provide the information for anyone who’s interested.
Old 09-06-2019, 09:18 AM   #23
Chuckable
Greddy Oil Cooler
Double post by accident.
Old 09-06-2019, 10:01 AM   #24
Joon525
Joon525's Avatar
Drives: 2016 BRZ
*cut the picture out*
As seen here, the stock Subaru filter should work OK.
Joon525 is offline   Reply With Quote
Old 09-06-2019, 10:23 AM   #25
Chuckable
Thanks, Joon525. I’m confused, though, because multiple sources have confirmed that the OEM filter doesn’t work. I have an extra Toyota filter, and will try to spin it in and see if it fits.
Old 09-06-2019, 11:11 AM   #26
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Hmm, maybe that guy I linked to used a smaller sized OEM filter (it looks like the wider one to me though). That could be possible since the OEM filters come in different sizes. So you may not be wrong afterall. Regardless, more info is sure to be helpful for other members.
Old 09-06-2019, 01:58 PM   #27
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
As far as I'm aware, the OE filter threads into uses a M20 x 1.5.
The Greddy plate adapter changes the thread to 3/4"-16 UNF. It is stated on the Greddy website that the oil cooler kit "requires use of QX-1,3, SX-1,3 oil filter," which when identified on their product inventory is a 3/4" threaded filter with 65mm diameter. It looks like "O" part numbers have replaced Q or S. Google searches for inventory QX/SX turn up 3/4" / 65mm as well
http://www.greddy.com/products/ic-oil-rad/oilcooler/
http://www.greddy.com/products/engine/oil-filter/
EndlessAzure is offline   Reply With Quote
Old 09-06-2019, 03:38 PM   #28
Chuckable
Here’s a screenshot from Fram.com with the XG3614 filter as search criteria:
Based on the specs, I believe it will work. It’s 3/4 thread, has an anti-drainback valve, and the ID and OD of the gasket looks like it’ll fit on the filter housing.
Greddy oil cooler to cold mattlang89 Engine, Exhaust, Transmission 5 05-24-2015 12:47 PM
Question about Greddy oil cooler Captain Snooze Engine, Exhaust, Transmission 3 09-10-2012 03:40 AM
Greddy oil cooler coming soon DIG1992 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 08-20-2012 12:02 AM
Greddy Oil and Diff Cooler pdreams Engine, Exhaust, Transmission 3 06-13-2012 08:41 PM
