Old 09-03-2019, 03:52 PM   #1
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Track Day Preps: Dummy Check Me?
Hey guys, this isnt so much of a "what should I do for track day" so much as Im gonna list off what I am doing, and I would ask the group to change, direct, or approve of my listing. A Dummy Check
More often than not you get down a certain line of thinking and you miss over some basic stuff.
I have a track day Friday Morning at Buttonwillow and will be convoying up with my SUV and a friend's Miata, (Miata needed someone to haul tires. I can tow my own car so it works out)
So Heres my List
Saab: (tow rig)
Tire Pressure
Oil Level
Grease Tow Ball
Check Wiring for brake lighting and brake control
General Check on Tires, brakes
Saab: (storage)
Water
E85 (2 5 gallon jugs)
Oil (for FRS)
Oil 5w-30 (Saab)
DOT-4 Brake Fluid
Coolant
Tool roll
Craftsman tool kit
Jack
Jack Stands
Torque Wrench with adapter
EZ Up awning
Cooler with Food/Drinks
Chairs
Wood for car ramps
Helmet bag w/helmet
Long Sleeve Cotton Shirt
Change of socks
Gloves
Zip Ties
Duct Tape/EB Red
Paper
Car Journal
Pens
FRZ: Car
Torque Check- Wheels
Check Coolant level -cold
Check Oil Level- Cold
Check Brake Fluid Level
Visually check over hardware looking at paint pen markings and one last check of tires
Check Tire pressure
(Nut and bolt check completed prior by shop)
Im going to swap pads at the track just fronts to Winmax's W4's
Ill be beginner so I am not anticipating dealing with heat
I already have an Greddy oil baffle pan, Killer B pick up tube and perrin oil cooler kit installed. But largely the car is a standard STX-like modded car with e85
Anything I might have missed?
Clutch Dog is offline   Reply With Quote
Old 09-03-2019, 04:24 PM   #2
scoobydrew
Drives: 2001 Subaru Impreza
I'd bring a air/tire inflator with you if you have one. No big deal though since others will lend you one and the on-site tire shop has a hose.
scoobydrew is offline   Reply With Quote
The Following User Says Thank You to scoobydrew For This Useful Post:
Clutch Dog (09-03-2019)
Old 09-03-2019, 04:25 PM   #3
Clutch Dog
I forgot about that. we have an air dragon here at the house. It sone of the few as seen on tv shit I actually bought
Old 09-03-2019, 05:12 PM   #4
Code Monkey
Drives: Subaru BRZ
I always carry an assortment of bumper/fender liner clips, some usually go missing after an off, part numbers 46064AE000, 909140065, and 909140007.
Needle tire pyrometer.
Also, a cheap ODBII reader.
Code Monkey is online now   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
Clutch Dog (09-05-2019)
Old 09-03-2019, 06:58 PM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
The car doesn't like aggressively staggered pads, might be fine depending on how easy you take it.
ineedyourdiddly
Old 09-03-2019, 10:31 PM   #6
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
You dont check oil with a cold engine
strat61caster (09-03-2019)
Old 09-04-2019, 12:20 AM   #7
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Probably overkill. I've been enough times that what I pack in the FRS is usually enough.
  • Rags
  • Towels + detailer or window cleaner for windows
  • Duster or small vacuum, as Buttonwillow has sandy run-offs
  • Tire pressure gauge or pyrometer.
  • Install tow hooks.
  • Remove all loose objects from car.
  • Remove wheel/lug nut caps.
  • Vinyl or painter's tape for numbers.
  • Drive to the track on the track pads all 4 corners. They're not that aggressive, you'll want to preserve brake balance, and you'll save yourself a lot of trouble. Definitely not worth it if you're not going to swap wheels at the track.
You're might not have as much time as you think to do things after showing up, registration, and driver's meeting.
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
timurrrr (09-04-2019)
Old 09-04-2019, 05:28 AM   #8
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
+1, I would recommend using the same pads (and rotors!) on both axles if possible.
According to the graphs on this page, you should be fine driving to the track on W4s, maybe with some extra caution, especially the first dozen of braking after the putting them in. This page specifically says "Effective for road racing, rally racing, and occasional street use".
If you haven't used these pads before, you might consider bedding them in first, although I'm not an expert on that matter.
Old 09-04-2019, 07:14 AM   #9
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
Have you upgraded brake fluid? Motul RBF660 or 600 is OK
Don't go on track with stock brake fluid.
Just don't do it...
Fish Eagle is offline   Reply With Quote
The Following User Says Thank You to Fish Eagle For This Useful Post:
Old 09-04-2019, 11:18 AM   #10
ZionsWrath
Thanks
ZionsWrath's Avatar
Change of clothes, not just socks
Old 09-04-2019, 11:58 AM   #11
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
Sunscreen
Hat (wide brim preferable)
snacks
more water (can't have too much)
camera
cordless electric impact (you'll be thankful)
CrowsFeast is offline   Reply With Quote
Old 09-04-2019, 12:28 PM   #12
korhun
Database error
korhun's Avatar
Really? The manual says check it cold. And I was doing it with cold engine for years.. (I hope this is not a very stupid question)
korhun is offline   Reply With Quote
Old 09-04-2019, 12:41 PM   #13
Tristor
Tristor's Avatar
Honestly y'all pack way overkill for the track compared to what I go with. Part of that may be different facilities. The track I'm a member of has a clubhouse with a kitchen and snacks/drinks in a vending machine, and a shop with a lift and necessary tools for the most part. I drive on my track pads and my preferred wheels/tires to get there, so I don't need to swap when I arrive anyway.
What I consider the essentials is:
On the car:
1. Inspect your car fully on a lift to ensure that everything is in good working order, put a wrench on all your suspension bolts to make sure they're snugged tight, if they move torque them to spec.
2. Ensure you have appropriate brake pads and brake fluid for track use
3. If you are nearing a maintenance interval for anything, do the maintenance early to ensure it's in good condition for track use.
4. Torque your wheel lug nuts to spec when putting them back on (don't impact them down).
5. Take everything out of the car which isn't absolutely essential, including emptying your glove box, removing the cup holder from the center console, and taking out the junk in the trunk.
6. Wash your car.
To take with you:
1. A good helmet
2. Sunglasses and a wide brim hat
3. A high quality tire pressure gauge
4. A high quality needle pyrometer
5. A datalogger which you can mount in the car
6. A camera (or your phone) which you can mount in the car.
I put the pyrometer with my helmet in the helmet bag and everything else gets tossed into a canvas reusable shopping bag along with my registration/insurance information (in case I get pulled over on the way there or back, although it's unlikely). Stop at a gas station close to the track and fill to full with your preferred fuel and grab the caffeinated beverage of your choice. Eat something light that is easy on the stomach. Go have fun.
Don't overthink it. You don't need to take a full service mechanics shop with you to the track.
Tristor is offline   Reply With Quote
Old 09-04-2019, 01:57 PM   #14
CSG Mike
CSG Mike's Avatar
Have you checked out the sticky at the top of the forums?
http://www.ft86club.com/forums/showthread.php?t=25485
Tristor (09-04-2019)
Track day guys, check this out. Apexer Tracking / Autocross / HPDE / Drifting 8 05-16-2017 07:37 AM
Track day check-in daiheadjai CANADA 28 10-10-2015 09:53 PM
Check engine light at the track Thongpocket Issues | Warranty | Recalls / TSB 7 05-12-2014 09:54 PM
Detailer's Domain preps a BMW 135i for sale DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 05-07-2013 12:17 AM
Can you cram all of your track day gear into the BRZ...yes, check it out. JRitt BRZ First-Gen (2012+) — General Topics 18 06-01-2012 10:00 AM
