Old 08-31-2019, 10:35 PM   #1
GrabTheWheel
Drives: 16' BRZ
High temp diff gaskets?
Does such a thing exist? I’m loosing diff fluid and am wondering if there are better replacement gaskets than oem?
GrabTheWheel is offline   Reply With Quote
Old 09-01-2019, 01:22 AM   #2
86TOYO2k17
Drives: 2017 toyota 86
Its Red RTV no gasket, just redo it. But are you sure its leaking from there and not from a bad axle seal? Did you recently pull out the axles?
Old 09-01-2019, 10:16 AM   #3
GrabTheWheel
Drives: 16' BRZ
Thanks for the reply! Yes, you are correct it is the axle seals. They are DSS 600hp axles. Do you have any advice? On a side note I was able to find a high temp diff gasket online and I’ll give it a try.
Old 09-01-2019, 10:30 AM   #4
86TOYO2k17
Possibly nicked the seal on install, or the garter spring popped off. Either way new seals should do the trick, just make sure to grease the axle tip and the seal when installing to make sure it doesn't get damages.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
GrabTheWheel (09-01-2019)
Old 09-01-2019, 11:37 PM   #5
ka-t_240
No need for gaskets. You need to replace the seals.
Confirm that your DSS axles do in fact require the stock seals and not something else.
ka-t_240 is offline   Reply With Quote
Diff and Transmission Gaskets/Crush washers Lakitu Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 06-11-2018 11:59 PM
High coolant temp at idle with A/C off extrashaky Issues | Warranty | Recalls / TSB 11 11-11-2014 04:50 PM
p0198 code oil temp sensor malfunction circuit high kingkai23 Forced Induction 10 06-17-2014 01:22 PM
Where to order trans/diff gaskets? ZionsWrath Scion FR-S / Toyota 86 GT86 General Forum 4 11-11-2013 01:46 PM
Volunteers to help install my high temp brake fluid and pads with me? stockysnail Northwest 9 07-22-2013 05:15 PM
